T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
23-05-2014, 22:08 Subject: |
dokky wrote: | So prematurely happy.
After a week and 2000 km, this morning, right after starting, it made a brief whistling sound from the engine compartment. Then, while waiting at a red light today, I smelled something again coming from the ventilation system. I opened the cover, and it smells bad again at the first cylinder.
Could the head be warped? I can rule out the DPF and catalytic converter, the engine is running at its maximum speed. |
No, it's more likely that the exhaust manifold is warped again. This is probably due to the casting material, which causes the same problem in many Fiat engines.
Are you sure the DPF isn't full and constantly regenerating? NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 14-10-2026, 21:13.
Profile PM Email Garage |
dokky Blaumann
Joined: 11/14/2003 Posts: 67 Karma: +7 / -0 Location: im Grünen 2013 Volkswagen Golf Free account, no CAN development support
23-05-2014, 22:31 Subject: |
It's not even an original part, and it looks much more stable.
The DPF has regenerated once.
Translated on 14-10-2026, 21:14.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
23-05-2014, 22:36 Subject: |
Errors in all files.
Buying an Audi, Seat, Skoda, or VW, I wouldn't know of any diesel models that have such problems.
There are other options for that.
You can at least use VCDS to monitor the exhaust gas temperature, and perhaps your car also has that capability. At least for most 2.0 TDIs, the exhaust gas temperature limit is around 820°C.
Translated on 14-10-2026, 21:15.
Profile PM WWW Garage |
vwSchrauber Profi-Schrauber
18-06-2014, 15:23 Subject: |
What does the valve control do? Could the valve timing be off, or are the valve tappets/lifters worn, resulting in insufficient air entering the cylinder?
I've seen this happen in various engines with clogged intake manifolds - they get very hot very quickly under load.
EDIT: There might be a stainless steel exhaust bend from the motorsports or tuning industry that can withstand higher temperatures better than the cheap cast iron part. selber schrauben - statt Werkstattpfusch
Translated on 14-10-2026, 21:16.
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
27-06-2014, 19:13 Subject: |
I would only grind off the manifold in the areas where it bulges, perhaps creating a slight 2 mm concave shape that would flatten out again under hot operating conditions.
But the cause is either the head or the temperature. Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 14-10-2026, 21:17.
Steffen G Profi-Schrauber
Joined: 10/26/2006 Posts: 2554 Karma: +590 / -0 Location: bei Zwickau
28-06-2014, 0:57 Subject: |
Hello!
I've had warped exhaust manifolds before (mostly on gasoline engines, but also on T3 diesel engines).
"If they weren't cracked, I had them milled flat at a machine shop in the neighboring town. He can't grind them (it's difficult to clamp manifolds securely), but if he mills them at a high speed with a slow feed rate, the surface is okay, and it works fine."
I also read that once a manifold is warped, it won't straighten out again.
That also aligns with my long-standing experience.
Furthermore, there's another issue: sometimes the studs in the head break off, or sometimes the threads become partially stripped due to the forces exerted during warping.
This should also be considered, checked, and, if necessary, corrected. Grüße, Steffen!
Translated on 14-10-2026, 21:18.
dokky Blaumann
04-07-2014, 16:25 Subject: |
Even a planned exhaust manifold can warp. A fault was also found, the DPF was almost clogged, and the differential pressure sensor was defective, which is why there was no message from the engine control unit. A new DPF was installed from the internet, the exhaust manifold was replaced with a new gasket, and lo and behold, everything is now quiet.
The car has also been sold, and now there's a VW parked outside.
Translated on 14-10-2026, 21:20.
Profile PM Garage |
04-07-2014, 16:56 Subject: |
Thank you for the feedback!
So, it got too hot after all.
