Zahnriemenriss am T4 AAB - (doch kein Umbau auf ABL) | Posts 16+
Go to page: Previous  1, 2
Post04-07-2014, 22:10    Subject: Quote
Translated on 03-10-2026, 19:57.
Karma: +590 / -0   Thank you, like it!
Post05-07-2014, 0:12    Subject: Quote
Yes, I think so too.
That's a better approach, installing a suitable engine.
Post05-07-2014, 0:20    Subject: Quote
Steffen G wrote:
It's better to install a suitable engine.
No, that's just simpler.
Translated on 03-10-2026, 19:58.
Post10-07-2014, 11:58    Subject: Quote
SO.
The "new" AAB is installed and running.
Now, there are still some finishing touches to be done, such as...
- Neatly arrange the cables.
- Reinstall fuel lines to original configuration (after PÖL waiver icon_wink.gif).
- AGR and Oxicat.
Post11-07-2014, 15:57    Subject: Quote
Here's a brief analysis of what likely happened:
The idler pulley of the ZR shows excessive play.
That probably led us to use too high a Z-ray voltage.
This causes the camshaft to move downwards.
The first layer effectively transfers heat and friction to the head.
The bridge will suffer damage at the second location.
The bridge and the cam before it are broken.
The ZR was nothing but crumbs.
Translated on 03-10-2026, 20:00.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post11-07-2014, 17:09    Subject: Quote
Evening.
Even with a lot of play, I can't imagine that the timing belt would experience significantly more tension.
"For that higher tension to develop, it would need to have more than 10mm of play in one direction."
There are no visible marks on the CV joint boot indicating whether anything foreign has entered.
Would you rule out simple material fatigue as a cause?
Translated on 03-10-2026, 20:01.
Post11-07-2014, 18:55    Subject: Quote
Well...
The engine had 330,000 kilometers on it, but the cylinder head only had 80,000.
Furthermore, the engine has been consistently operated at high power levels since it came to "us" with 251,000 km - its primary area of use is "the Alps."
He also had a whining sound (which was probably the recirculation valve), but as far as I remember, that only started after the last timing belt replacement.
"Definitely, the 'new' one, with its 200,000 km, runs much smoother and is more agile. The old ESP system was probably just a shadow of its former self, and even with 100% diesel, it wasn't really willing to release the fuel properly."
Vmax was good, but a sudden press of the accelerator pedal was ignored without enthusiasm.
The new one runs smoothly when you press the accelerator, almost like a 5E feeling. icon_rolleyes.gif
Sure, here's the translation:
"One more question:"
Can someone identify the two wire colors of the two oil pressure switches?
Greetings.
 File size:  275.29 KB
 Viewed:  17973 times
Translated on 03-10-2026, 20:03.
Post12-07-2014, 22:04    Subject: Quote
Yellow is coming to the bottom.
Translated on 03-10-2026, 20:04.
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Hard landing - no error entry - troubleshooting? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1Z zuerst kein Motorstart dann doch und von alleine VOLLGAS Diesel Engine Technology
No new posts Wastegate: AFB or VTG? Diesel Engine Technology
No new posts Engine Damage: 2.5 TDI Failure Due to Timing Belt Diesel Engine Technology
No new posts Oil Consumption: 2L/100km After Timing Belt & Head Re... Diesel Engine Technology
