Auxiliary Heater Errors: AutoScan Diagnostics
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
StreifLicht
Post02-07-2014, 21:30    Subject: Auxiliary Heater Errors: Autoscan Diagnostics Quote
I performed an Autoscan today using VCDS version 12.12.
Dabei fÀllt der Fehler am Zuheizer auf. I had last.
October: Have the auxiliary heater replaced at the Webasto dealer for a standing heater.
have it rebuilt.
Im Dezember gings dann mit "Rauchproblemen" los. The dealer.
He said it was due to the auxiliary heater and that there was nothing he could do about it.
I should have started using the software earlier.
Okay, so the error log now says the following:
(see the complete Autoscan below:)
01407 - Flame arrestor
000 - - - Sporadically
Freeze Frame:
Error status: 00100000
Error priority: 3
Error frequency: 26
Lost Count: 191
Time: 0.
Freeze Frame:
text
Start
Temperature: 1.0°C
Temperature: -48.0°C
Voltage: 11.71 V
02251 - Heating device locked
000 - -
Freeze Frame:
Error status: 01100000
Error priority: 2
Error frequency: 1.
Lost Count: 188
Time: 0.
The following are the remaining 2 errors:
01412 - Spark plug with flame monitoring (Qicon_cool.gif at 111,743 km.
01406 - No flame detected at 112067 km.
Current mileage: 115,080 km.
I unlock the auxiliary heater according to the following scheme - correct?
* Access the control unit of the auxiliary heater using VCDS, address 18.
* Then select "Adaptation/Adjustment" and proceed to unlock it.
Store the value 1 in channel XX.
VW Touran (1T) has XX = 42.
But how do I deal with a flameout?
Could it be due to a "blocked" diesel supply line?
What error does the error message indicate?
I would really appreciate any suggestions.
Greetings from Swabia.
Andreas.
Please provide the text you would like me to translate from German to English. I need the text to be able to translate it.
"Der schnelle braune Fuchs springt ĂŒber den faulen Hund."
Wednesday, July 2, 2014, 3:57:33:29602
VCDS -- A Windows-based VAG/VAS emulator.
VCDS Version: RKS 12.12.2.0
Data as of: 20140225
Vehicle Identification Number: WVGZZZ1TZAWxxxxxx
License plate:
Mileage: 115,080 km. Repair order:
Vehicle type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 69 72
Mileage: 115,080 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate control/heating unit -- Status: OK 0000
09-Central Electrical System -- Status: OK.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-inch heater -- Status: Error 0010.
19-Diagnosis interface -- Status: OK 0000.
Immobilizer system -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
56-Radio -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
69 followers -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine Control Module
Label file: RKS\03G-906-021-BLS.clb
Part number SW: 03G 906 056, HW: 03G 906 021 AB.
Part: R4 1.9L EDC G000SG 2832
Revision: --H11--- Serial Number: VWX7Z0J13NO0Q2
Encoding: 0000072
Operating number: WSC 01324 020 00200
VCID: E4C1420E27289D3E9FF-80B1
No error codes found.
Readiness: 0 0 0 0 0
Address 03: Brake Electronics
Label file: RKS\1K0-907-379-MK60-F.lbl
Part number SW: 1K0 907 379 AC, HW: 1K0 907 379 AC.
Component: ESP FRONT MK60 0101
Revision: 00H11001
Encoding: 0021190
VCID: 73E3B15212C68A86965-8026
Address 08: Climate Control/Heating. Label file: RKS\1K0-820-047.lbl
Part number SW: 1K0 820 047 JN
Part number HW: 1K0 820 047 JN
Component: Climatic PQ35 143 1515
Revision: 00143034 Serial Number: 00000000000000
Operating Number: WSC 00000 000 00000
VCID: 79FF837A30AAF0D6DC9-802C
Address 09: Central Electronics
Label file: RKS\3C0-937-049-30-M.lbl
Part number SW: 3C8 937 049 D, Hardware: 3C8 937 049 D.
Component: On-board network module H54 2602.
Revision: 00H54000 Serial Number: 00000003724653
Encoding: 00890F2100040F0047120C000000000000097B075C000120000000000000
VCID: 326D7456AD5CC38E5D3-8067
Subsystem 1 - Part number: 1T1 955 119
Label file: RKS\1KX-955-119.CLB
Part: Wiper 230210 021 0512
Encoding: 00038805
Address 15: Airbag
Label file: RKS\1T0-909-605.lbl
Part number SW: 1T0 909 605 D, HW: 1T0 909 605 D.
Part: 1D AIRBAG VW8 021 0100
Revision: 02021000 Serial Number: 003B9D0FZS0S
Encoding: 0012612
VCID: 366548464134DFAE71B-8063
Subsystem 1 - Serial number: 6332QSME22502B1EC
Subsystem 2 - Serial number: 6342QSME335022180.
Subsystem 3 - Serial number: 6352QSME274E5002B.
Subsystem 4 - Serial number: 6362QSME334C063AJ
Address 16: Steering wheel electronics
Label file: RKS\1K0-953-549-MY9.lbl
Part number SW: 1K0 953 549 CQ
Part number HW: 1K0 953 549 CQ
Component: J0527 853 0111
Coding: 0000034
VCID: 83036192C2663A06065-80D6
Address 17: Control Panel Module
Label file: RKS\1K0-920-xxx-17.lbl
Part number SW: 1T0 920 874 D, Hardware number: 1T0 920 874 D.
Component: COMBINATION INSTRUMENT VDD 2420
Revision: V0005000 Serial Number: VWX7Z0J13NO0Q2
Encoding: 0003101
Operating number: WSC 00011 888 96745
VCID: 377B4542463E26A66AD-8062
Address 18: Auxiliary heater
Label file: RKS\1K0-815-071.clb
Part number: 1K0 815 071 T
Component: Portable heater 050 2504
Revision: 00050000 Serial number: 09009839000000
Encoding: 0001012
Operating number: WSC 01324 785 00200
4 error codes found:
01407 - Flame arrestor.
Freeze Frame:
Error priority: 3
Error frequency: 26.
Lost Count: 191
Time: 0.
Freeze Frame:
text
Start
Temperature: 1.0°C
Voltage: 11.71 V
008 - implausible signal - sporadic.
Freeze Frame:
Error status: 00101000
Error priority: 3
Error frequency: 2.
Lost Count: 198
Mileage: 111,743 km
Time: 0.
Freeze Frame:
text
Start
Temperature: 50.0°C
Temperature: 48.0°C
Voltage: 14.45 V
01406 - No flame formation.
000 - -
Freeze Frame:
Error priority: 3
Error frequency: 5
Lost Count: 188
Mileage: 112,067 km
Time: 0.
Freeze Frame:
text
Start
Temperature: 63.0°C
Temperature: 63.0°C
Voltage: 14.45 V
02251 - Heating device locked.
000 - -
Freeze Frame:
Error priority: 2
Error frequency: 1.
Lost Count: 188
Time: 0.
Address 19: Diagnostic interface
Label file: RKS\1K0-907-530-V4.clb
Part number SW: 1K0 907 530 AD, HW: 1K0 907 951.
Component: J533, Gateway, H07 0112.
Revision: H07 01 Serial Number: 230210F1000295
Encoding: E9807F46000A02008002
VCID: 69DFD33A400A40562C9-803C
Address 25: Immobilizer
Label file: RKS\1K0-920-xxx-25.clb
Component: IMMO VDD 2420
Address 42: Door electrical driver
Label file: RKS\1K0-959-701-MIN3.lbl
Part number SW: 1T0 959 701 T Hardware number: 1T0 959 701 T
Component: Door Seal 009 2101
Encoding: 0000181
VCID: 489936BE3BC0595E137-801D
Address 44: Steering Assist
Label file: RKS\1Kx-909-14x-44.clb
Part number: 1K0 909 144 J
Component: EPS_ZFLS, Size 70 3001
Revision: 00H17000
VCID: 316F7B5AA85AF896249-8064
Address 46: Comfort System
Label file: RKS\1K0-959-433-MAX.clb
Part number SW: 1K0 959 433 BT, Part number HW: 1K0 959 433 BT.
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial Number: 00000000000000
Encoding: 8090020851030C7F2D06840560084F03E0FC00
Subsystem 1 - Component: Sounder (not mounted)
Subsystem 2 - Component: NGS, not mounted.
Subsystem 3 - Component: IRUE, not mounted.
Address 52: Power door lock, front passenger side.
Label file: RKS\1K0-959-702-MIN3.lbl
Part number SW: 1T0 959 702 R. Hardware: 1T0 959 702 R.
Encoding: 0000181
VCID: 479B358236DE56261AD-8012
Address 56: Radio (J503)
Label file: RKS\5M0-035-1xx-56.clb
Part number SW: 1K0 035 156 B HW: 1K0 035 156 B
Component: Radio H21 0057
Revision: R0000000 Serial Number: VWZAZ1K8650472
Encoding: 0000020002
VCID: 224D84163DBC530EAD3-8077
Address 62: Door electric, left/right.
Label file: RKS\1K0-959-703-GEN3.lbl
Part number SW: 5K0 959 703 A, Part number HW: 5K0 959 703 A.
Component: Door Seal 007 2102
Encoding: 0000144
Operating number: WSC 01324 020 1012552
Address 69: Trailer Label file: None
Part number SW: UNV 301 003 2
Part number HW: UNV 301 003 2
Component: TRAILER_MODULE UN 0030
Encoding: 0000001
VCID: 52AD14D6CD9CE38E7D3-8007
5 error codes found:
02562 - Lights for the trailer's brake light.
014 - defective
02563 - Lamp for the right tail light on the trailer (M61).
011 - Interruption - Warning light ON.
02564 - Lamp for the left tail light on the trailer (M60).
013 - Please read the error memory - Warning light ON.
02565 - Right-hand indicator lights on the trailer (M63).
000 - -
02566 - Left indicator lights on the trailer (M62).
010 - Short circuit/overload after positive terminal.
Address 72: Door electric strike, high, right.
Label file: RKS\1K0-959-704-GEN3.lbl
Part number SW: 5K0 959 704 A, HW: 5K0 959 704 A.
Encoding: 0000144
VCID: 336371525246CA86565-8066
End.
Translated on 23-09-2026, 5:48.
Post03-07-2014, 10:15    Subject: Auxiliary Heater Errors: Autoscan Diagnostics Quote
How do I deal with a flameout?
Here are some possible causes:
- No combustion air is available, or exhaust gases cannot escape.
- No fuel available (due to pump issues/air bubbles), or the amount/dosage is incorrect.
- Combustion chamber/related components defective.
Often, for cost-saving reasons, existing fuel lines are tapped into instead of installing a dedicated line to the tank. This can work well, depending on how it's done and the specific circumstances. However, poorly planned DIY solutions can lead to unreliable fuel delivery, for example, due to air bubbles. Alternatively, the line may simply not be completely airtight, which can also cause air to be drawn in.
Since injected air bubbles do not burn, unlike fuel, the heating system then shuts off.
Translated on 23-09-2026, 6:22.
StreifLicht
Post03-07-2014, 20:56    Subject: Auxiliary Heater Errors: Autoscan Diagnostics Quote
Since this is the standard-installed auxiliary heater that was simply retrofitted with a "standby heating function," there shouldn't be any issues with the fuel lines.
How can I check the dosage?
I probably need the Webasto Thermotest software for that.
Otherwise, I'm going to disassemble the auxiliary heater and take a look at the combustion chamber to see what it looks like.
Translated on 23-09-2026, 6:24.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post06-07-2014, 11:34    Subject: Auxiliary Heater Errors: Autoscan Diagnostics Quote
The unlocking procedure is correct. After that, you can clear the errors and, for example, perform a forced start using the default settings. This will help to clear any issues and obtain current error messages. Also, end the heating cycle using the default settings and then restart it.
Warning: If the part is heavily encrusted, it will produce a lot of smoke. If you do this, do it outdoors.
"In the described problem, the burner in the heating unit is usually the cause. Typically, in Touran/T5 vehicles, heating units that have already been sufficiently stressed as auxiliary heaters are upgraded to become parking heaters, without being overhauled. However, problems soon follow."
If the original ZH unit was installed, Webasto does not supply any spare parts for it. As soon as they realize it's an original equipment (OE) part, they will refer you (or your heating technician) to VW. You can also ask the car dealership if they can send your heating unit for refurbishment.
"The coolant hoses were shorted out, so I removed the part. On my last Touran, this cost around 300 euros. The heater core was also damaged. The glow plug is included, which I think is reasonable."
Be glad you noticed it in the summer. In the winter, it's often difficult to find spare parts and get appointments (wait times) for things like auxiliary heaters. Everything is much more relaxed in the summer.
Have you disassembled anything? A common mistake is connecting fuel lines from heating systems to each other using a piece of rubber hose (like a pipe coupling), but then re-connecting them with a tight fit *inside* that coupling. This can sometimes create an air bubble within the coupling between the lines, which could also cause the problem.
Passat Variant BGW 2005
Translated on 23-09-2026, 6:27.
StreifLicht
Post13-07-2014, 19:42    Subject: Auxiliary Heater Errors: Autoscan Diagnostics Quote
Then I'll remove the auxiliary heater.
I need a "double nipple" for the short circuit.
Do you happen to know the diameter of the heater hose fittings?
Are all VW auxiliary heaters the same? Hopefully, they don't all have different hose diameters.
Andreas.
Translated on 23-09-2026, 6:29.
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Heater Error 02085: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Auxiliary heater Audi, Seat, Volkswagen, unlock, error co... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Auxiliary Heater for Audi A4 2.5 Qtip Transmission, Chassis, Body & Interior
No new posts Auxiliary Heater Upgrade for Parking Heaters Transmission, Chassis, Body & Interior
No new posts Auxiliary Heater Unlock for Parking Heater On-Board Diagnostics (OBD)
No new posts Auxiliary Heater Conversion to Stand Heater On-Board Diagnostics (OBD)
