Viscous Fan Screw Stuck / Jamshed Defective
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
kmrlange
Post25-07-2014, 19:27    Subject: Viscous Fan Screw Stuck / Jamshed Defective Quote
There's nothing I can do; I can't get the 32mm nut off the ViscolĂŒfter (blower motor) (rotation direction: clockwise). In the process, I broke the 3212 retaining clip (see picture).
Does anyone have any ideas before I have to resort to using the torque wrench? The stock is almost empty, and since the timing chain is being replaced, I also want to replace the flange shaft bearing. I'm a bit stuck right now.
Best regards, Kai.
'Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BÀume, und die BlÀtter rascheln leise. Es ist ein wunderschöner Tag, um spazieren zu gehen.'
'The sun is shining brightly, and the birds are chirping merrily. A gentle breeze is blowing through the trees, and the leaves are rustling softly. It's a beautiful day for a walk.'
 File size:  267.85 KB
 Viewed:  1378 times
Translated on 25-08-2026, 23:15.
Post25-07-2014, 20:50    Subject: Viscous Fan Screw Stuck / Jamshed Defective Quote
icon_eek.gif Oops... it should be opened counter-clockwise!
Tip: Use a hot air gun or a small soldering iron to get it off!
Translated on 25-08-2026, 23:16.
kmrlange
Post25-07-2014, 20:53    Subject: Viscous Fan Screw Stuck / Jamshed Defective Quote
Great. I was told 'right-hand thread' because it's a left-hand thread...
Luckily, my son emptied the butane torch, probably to use it for his silly shisha coals.
Translated on 25-08-2026, 23:17.
Post25-07-2014, 21:00    Subject: Viscous Fan Screw Stuck / Jamshed Defective Quote
Hmmmm, which car are we talking about here? Isn't there an Allen screw on the back, near the water pump? If so, the Allen screw is opened to the LEFT. If there's a thick nut behind the fan, it's opened to the RIGHT, I hope I'm not mistaken icon_redface.gif.
kmrlange
Post25-07-2014, 21:49    Subject: Viscous Fan Screw Stuck / Jamshed Defective Quote
Nicht geirrt! 1000 Dank. icon_biggrin.gif Linksrum ging sie auf. Ist ja auch die Drehrichtung des Visko. Etwas WD40 und warmgemacht. A6 C4 TDI Quattro. MKB = AEL
So nun nicht genug der Probleme... I would like to.
I need to replace the bearing. But how do I get to the bearing?
Does the entire bracket need to be removed for the Klima and Lima components? Will it be accessible then?
Best regards, Kai.
 File size:  244.8 KB
 Viewed:  1944 times
Translated on 25-08-2026, 23:18.
kmrlange
Post25-07-2014, 22:25    Subject: Viscous Fan Screw Stuck / Jamshed Defective Quote
Here's what the carrier 046903143C looks like from the bottom... (image)
It seems like this is only available as a complete set with storage. Hmm.
 File size:  137.3 KB
 Viewed:  1305 times
Translated on 25-08-2026, 23:19.
Post25-07-2014, 22:36    Subject: Viscous Fan Screw Stuck / Jamshed Defective Quote
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
mullemaus
Post25-07-2014, 22:49    Subject: Viscous Fan Screw Stuck / Jamshed Defective Quote
A6 C4 TDI Quattro. Engine code: AEL.
Post25-07-2014, 23:00    Subject: Viscous Fan Screw Stuck / Jamshed Defective Quote
Depending on the VIN, there are likely two variants: one with a fitting and one without. icon_wink.gif If there is no fitting, a single bearing is also not offered. }
Translated on 25-08-2026, 23:20.
mullemaus
Post25-07-2014, 23:05    Subject: Viscous Fan Screw Stuck / Jamshed Defective Quote
Remove it with a puller and press it back in?
Post25-07-2014, 23:08    Subject: Viscous Fan Screw Stuck / Jamshed Defective Quote
That makes sense. It's already broken anyway, so I have nothing to lose.
kmrlange
Post25-07-2014, 23:41    Subject: Viscous Fan Screw Stuck / Jamshed Defective Quote
hm...
The plate, including the thread, is a single piece and appears to be pressed onto the shaft. Is it possible to remove it?
I'll need to get a puller.
But then the storage unit needs to be removed. Has anyone ever disassembled one of these before?
Best regards, Kai.
Translated on 25-08-2026, 23:21.
kmrlange
Post26-07-2014, 11:14    Subject: Viscous Fan Screw Stuck / Jamshed Defective Quote
I can't get to it with the puller. The flange won't come off the shaft. I've even tried heating it up.
So, NEW...
It appears that model 046 903 143C has been replaced by model 046 903 143 D and costs a hefty 389 EUR plus VAT.
Does anyone have good deals on spare parts from the VAG group?
Best regards, Kai.
mullemaus
Post26-07-2014, 11:44    Subject: Viscous Fan Screw Stuck / Jamshed Defective Quote
I wouldn't feel compelled to install anything new on that old car.
http://www.ebay.de/itm/Audi-100-C4-A6-C4-MKB-AAT-2-5l-Tdi-Viscolufter-Halter-4A0121350-046903143-/190918400241?pt=DE_Autoteile&hash=item2c739f98f1
Translated on 25-08-2026, 23:22.
Karma: +1344 / -0   Thank you, like it!
Post26-07-2014, 12:32    Subject: Viscous Fan Screw Stuck / Jamshed Defective Quote
"Can't the flange and shaft be pulled out together? They don't necessarily have to be separated. You would need to create a device that rests on two bolts through the holes and against the flange, and then pushes the latter outwards. There's probably a needle bearing inside, which might be available as a standard part. Before pulling it out, measure the insertion depth and the distance to the housing!"
Translated on 25-08-2026, 23:23.
kmrlange
Post26-07-2014, 20:10    Subject: Viscous Fan Screw Stuck / Jamshed Defective Quote
There are people who put a lot more money into even much older cars... icon_smile.gif I want to continue driving it in 2025 with an H-plate (historical vehicle registration). That part from eBay is probably just as finished as mine. } What would be the point then?
I have such low running costs with the A6 that I can afford to replace parts occasionally. Instead of having to improvise with tools and uncertain results, I just get a new part.
Falls jemand jedoch 10-20% beim VAG bekommt möge er sich melden. Sure.
Best regards, Kai.
Translated on 25-08-2026, 23:24.
No new posts T4 crankshaft pulley locking tool Troubleshooting & Guides
No new posts Passat gibt SchlÀge - ESP Leuchte geht an Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Timing Belt Tensioner: AEL (A6/C4) - Doesn't Fit! Diesel Engine Technology
No new posts Clutch, sometimes it works, sometimes it doesn't. Transmission, Chassis, Body & Interior
No new posts Defective Car Control Unit: What Can You Do? Diesel Engine Technology
No new posts 1Z fails to start/shuts down during operation (not relay ... Diesel Engine Technology
