A3 2,0 TDI BKD seltsames Leistungsverhalten Gang 1-3 | Posts 16+
Go to page: Previous  1, 2
Kitwing
Post14-08-2014, 10:53    Subject: Quote
Okay, so when the engine is off, the VTG (Variable Turbine Geometry) is not activated.
When the engine is running, does the vacuum pull the VTG rod towards the diaphragm?
While idling, disconnect and kink the vacuum hose leading to the VTG valve – this will put the VTG into a state as if the engine is off.
It should be fine as long as you just bend the hose; of course, nothing will change with the trailer coupling if you're not allowed to disconnect it.
I expressed myself somewhat ambiguously. Sorry about that.
A6 Allroad BJ 2016 3.0 TDI
Translated on 22-08-2026, 18:46.
Post14-08-2014, 12:12    Subject: Quote
Yes, then it fits like that.
Translated on 22-08-2026, 18:47.
Kitwing
Post18-08-2014, 8:11    Subject: Quote
Attached is the log file, unfortunately a bit late, showing data from the 4th gear with the turbo starting to engage.
LOG-01-008-011-xxx4.Gang-versuch1.csv
 File name:  LOG-01-008-011-xxx4.Gang-versuch1.csv
 File size:  3.66 KB
 Downloaded:  314 times
Kitwing
Post18-08-2014, 14:42    Subject: Quote
Oh yes, I completely forgot to mention: in the meantime, the EGR valve and throttle body have been completely cleaned and reinstalled.
Post18-08-2014, 15:22    Subject: Quote
Too bad, but the log looks good.
I would continue investigating in this direction: Either the variable geometry turbine (VTG) is intermittently malfunctioning, or there is intermittent loss of vacuum at the control valve.
Translated on 22-08-2026, 18:48.
Kitwing
Post18-08-2014, 15:40    Subject: Quote
I'm thinking of replacing the N75 sensor just in case...?
What is the price of this extremely strange-looking N75 part from the tractor...? Does anyone know?
Post18-08-2014, 17:20    Subject: Quote
I think I'll just replace the N75 part as a precaution...?
What is the price of this extremely strange-looking N75 part from the tractor... does anyone know?
Why? Perhaps one of the other control elements, or pressure regulators/actuators, is intermittently leaking, or the connections are reversed, or something else... I've seen it all before icon_wink.gif.
Therefore, you should check the vacuum pressure at the moment the error occurs, or systematically replace everything one by one icon_wink.gif.
Translated on 22-08-2026, 18:49.
Kitwing
Post19-08-2014, 8:28    Subject: Quote
Okay, I will do that!
What is the purpose of the pressure regulator/controller?
The turbocharger boost pressure is regulated by the VTG (Variable Turbine Geometry) on the tractor.
The connections to the N75 are all correct; they have already been checked twice and confirmed to be accurate.
I would love to exchange everything with the rich person... but financially, it's simply not feasible for the owner.
Translated on 22-08-2026, 18:51.
Post19-08-2014, 10:10    Subject: Quote
Okay, "pressure sensor" would be the correct term. So, for example, the N75 is a pressure sensor.
The EGR valve is also powered by a pressure sensor.
Look: http://download.ms-motor-service.com/ximages/pg_si_0065_de_web.pdf
A single leak in the vacuum line... and the N75 valve no longer receives the correct vacuum pressure.
Therefore, we check icon_exclaim.gif.
P.S.: Right now, you're just as knowledgeable as when you started – you still don't know whether the target landing point (TL) is being correctly aimed for or not.
Translated on 22-08-2026, 18:52.
Post19-08-2014, 11:13    Subject: Quote
A single leak in the vacuum line... and the N75 no longer receives the necessary vacuum pressure.
For example, connect a vacuum gauge somewhere in the system and then run the VTG actuator diagnosis.
Translated on 22-08-2026, 18:53.
Kitwing
Post19-08-2014, 12:24    Subject: Quote
Okay, as I said, we'll test it today to see if there are any bugs or issues.
I understand exactly what is being targeted.
We also checked that the vacuum lines were correctly assembled according to the diagram.
http://simplement.skoda.free.fr/technique/egr/egr-05.jpg
We will connect a vacuum gauge to the VTG (Variable Turbine Geometry) sensor and observe how the vacuum changes when the turbocharger is engaged and when it is not.
If both situations provide the same vacuum conditions, then the problem must be with the transmission line (TL).
Translated on 22-08-2026, 18:54.
Post19-08-2014, 12:40    Subject: Quote
For example, you could integrate a vacuum gauge somewhere and then run the VTG actuator diagnosis.
Check for faults during driving (if no boost pressure is building up). If I understood correctly, the VTG system probably functions when the vehicle is stationary.
Translated on 22-08-2026, 18:56.
Kitwing
Post19-08-2014, 13:07    Subject: Quote
Absolutely correct! Everything is top-notch when it's stationary/standing still!
Therefore, both test scenarios will be tested during the drive.
Post19-08-2014, 13:27    Subject: Quote
Does the VTG have enough traction to accelerate quickly when stationary?
Or is the lever moving towards its limit?
You would need something like that on the VTG container during transit.
Attach the pressure gauge to the outside of the windshield using adhesive and connect it to the VTG with a T-connector.
Yes, the additional volume of approximately 80 cm of supply line will further dampen the VTG (voltage transient generator), but not as much as the error you described.
This is the system vacuum pressure (measured at the supply to the swirl flap valve of the BMR) while the VTG is in actuator diagnosis mode.
A3 2,0 TDI BKD seltsames Leistungsverhalten Gang 1-3 | Posts 16+ - MVI7961.flv
 Unterdrucktest VTG
 File size:  1.78 MB
 Viewed:  597 times
Translated on 22-08-2026, 18:57.
Kitwing
Post19-08-2014, 14:15    Subject: Quote
After the engine starts, the variable geometry turbocharger (VTG) immediately moves to its operating position. We will use a pressure gauge exactly like that one.
However, we need to test the behavior while it's in motion; everything seems fine when it's stationary.
The throttle lever only works under load and at low speeds (or, it only functions properly when you briefly release the pedal and then press down on it fully to move forward).
Translated on 22-08-2026, 18:59.
Post19-08-2014, 14:40    Subject: Quote
Here's another piece of information about the VTG (Variable Turbine Geometry): If you unscrew the housing on the turbocharger (it's only held in place with two M6 screws), then the adjustment lever and its housing should simply fall downwards.
The adjustment mechanism moves more smoothly than butter (in working condition and with the adjustment housing removed). If there is a hard or stiff spot along the adjustment range, or if the adjustment lever only moves with resistance, this is not normal.
Translated on 22-08-2026, 19:00.
No new posts Document: Gear Noise, 6-Speed Transmission Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documented noises from the dual-clutch transmission, 6-sp... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gearbox 02K: 3rd Gear Hard to Shift Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts seltsames "Zischen" unter Turbolast bei A6 `04 BDG Diesel Engine Technology
No new posts Sharan/Alhambra/Galaxy(AFN) 5-Gang. Ändern 5.Gang? Diesel Engine Technology
No new posts Golf 5 1.9 TDI 5-speed 6-speed gearbox ZMS clutch Diesel Engine Technology
No new posts Speed signal at 6th gear is the same as 5th gear? Transmission, Chassis, Body & Interior
