blackblizzard Blaumann
20-08-2014, 11:17 Subject: PD Marking Tool: Precise & Reliable |
Short question: I ordered a timing tool (from Famex) for the 1.9 PD-TDI engine, but the crankshaft stop didn't fit (on the AVB engine).
Are there multiple variations?
Translated on 10-10-2026, 2:15.
matthiasTDI96 Profi-Schrauber
20-08-2014, 11:55 Subject: PD Marking Tool: Precise & Reliable |
If positioned correctly, it means inserting it from the front at the marked location. The rear wheel (KW Rad) is slightly "oval," so it only fits in this specific spot.
Translated on 10-10-2026, 2:16.
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
20-08-2014, 15:15 Subject: PD Marking Tool: Precise & Reliable |
What is the VAG part number for this item? There are two different ones.
As mentioned before, it can be somewhat "difficult" to use.
Profile PM Garage |
20-08-2014, 16:49 Subject: PD Marking Tool: Precise & Reliable |
Unfortunately, it doesn't have a VAG number, I can only post a photo.
There are two versions of the Famex, but according to the description, only the 2.0 version has an oval kilowatt wheel.
Translated on 10-10-2026, 2:17.
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
20-08-2014, 20:43 Subject: PD Marking Tool: Precise & Reliable |
The difference is: on one, the marking is roughly in the middle, while on the other, it's on the right! Otherwise, they are the same in terms of shape. They can only be inserted from the side.
NA,Gehörlose wie ich können auch Schrauben! Ihr HĂRT ich FĂHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Profile PM Email Garage |
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: NĂ€he DĂŒsseldorf
20-08-2014, 23:00 Subject: PD Marking Tool: Precise & Reliable |
Quote: | | The placement of the marking is about in the middle for one, but on the right for the others! Otherwise, they are the same in shape. It can only be inserted from the side. |
In addition... the tool with the marking on the right side is for the oval version, while the one with the marking in the middle is for the older, round version.
It can only be attached in an axial direction. It's impossible to do it from the side. Also, the wrong tool can't be inserted into the sprocket, at least not with my tools.
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
Translated on 10-10-2026, 2:18.
21-08-2014, 19:28 Subject: PD Marking Tool: Precise & Reliable |
Hmm... then my tool should have fit.
| Description: |
| Kurbelwellenstopp fĂŒr Pumpe-DĂŒse TDIs |
| File size: |
1.1 MB |
| Viewed: |
1261 times |
Translated on 10-10-2026, 2:19.
21-08-2014, 21:20 Subject: PD Marking Tool: Precise & Reliable |
Hm, in my case, it fails on all 1.9 and 2.0 PD engines. The game was so good that there was hardly any difference - so far, countless TDI engines have had a smooth ZR change with it. It's a shame I don't remember which manufacturer it's from.  Anyway, it's working so far.
21-08-2014, 21:22 Subject: PD Marking Tool: Precise & Reliable |
Quote: | | Hmm.... then my tool should have actually fit | .
It should be possible, but without the vehicle data, our research will be difficult.
Did you also try to push it in exactly parallel and axially? These things are manufactured with extreme precision - a rough approach won't work.
Translated on 10-10-2026, 2:20.
22-08-2014, 5:53 Subject: PD Marking Tool: Precise & Reliable |
"Yes, it looks very good so far. I completely agree with the previous comment. You need to rotate the crankshaft (KW) so that you can slide the tool parallel to the crankshaft axis. To do this, the marking on the crankshaft/tool should be roughly at the 11 o'clock position."
Translated on 10-10-2026, 2:21.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
22-08-2014, 11:00 Subject: PD Marking Tool: Precise & Reliable |
...and the small triangle in the picture should be aligned with the corresponding mark on the timing belt pulley of the crankshaft.
Perhaps the crankshaft was not at Top Dead Center (TDC). Observe the mark on the clutch bell. Since the locking tool fits quite tightly, it may be helpful to gently move the crankshaft back and forth when inserting it.
I'm putting a wrench on the central bolt on the crankshaft, which you're not really supposed to do, but the crankshaft turns so easily that only a complete... well, let's not use that word... idiot would accidentally loosen that bolt, because it's really tightened down.
Translated on 10-10-2026, 2:22.
Profile PM WWW Garage |
22-08-2014, 16:33 Subject: PD Marking Tool: Precise & Reliable |
dieselschrauber wrote: | ... and the small triangle in the picture is then located opposite the same marking on the timing belt pulley of the crankshaft.
Perhaps the crankshaft was not at Top Dead Center (TDC)? Observe the mark on the clutch bell. Since the locking tool fits quite tightly, it may be helpful to gently move the crankshaft back and forth when inserting it.
I'm putting a wrench on the central bolt of the crankshaft. You're not really supposed to do that, but the crankshaft turns so easily that only a complete... well, let's not use that word... idiot would accidentally loosen that bolt, because it's really tightened down.
Best regards, Rainer |
Okay, usually nothing works because it's very secure. For example, with older AFN & 1Z and similar models, you sometimes randomly discover that it's loose.
Translated on 10-10-2026, 2:23.
