Antenna fault in old (MJ08) car phone system
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Post07-10-2014, 17:56    Subject: Antenna fault in old (MJ08) car phone system Quote
Hi.
Is this the Bluetooth antenna located *inside* the hands-free system? Because these units don't have external (GSM) antennas.
It's strange that everything is still working!
Can you access it and potentially fix something?
Something like a cold solder joint?
I have a spare part number 3C0 035 729 F (MJ07 from a 3C model) lying around; I might need to replace it sometime.
Code:
Adresse 77: Telefon        Labeldatei: RKS\3C0-035-729.lbl
   Teilenummer SW: 3C0 035 729 G    HW: 3C0 035 729 G
   Bauteil: Telefon             7609
   Revision: 00012000    Seriennummer: 0000B6A004801
   Codierung: 0016041
   Betriebsnr.: WSC 00000 785 00200
   VCID: 27566BDE96966426FAD-8072
1 Fehler gefunden:
01524 - Antenne für Telefon
            007 - Kurzschluss nach Masse
             Freeze Frame:
                    Fehlerstatus: 01100111
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 69
                    Kilometerstand: 160227 km
                    Zeitangabe: 0
                    Datum: 2000.00.00
                    Zeit: 11:26:29
Translated on 17-07-2026, 0:41.
No new posts Vintage VP34: 10 Cent Challenge? Diesel Engine Technology
No new posts Photo of 03G 103 954 - additional insulation for old PD u... Diesel Engine Technology
No new posts Crankshaft Failure: Common at 220k km / 7 Years Diesel Engine Technology
No new posts Vag-Com Adapter: Compatible with New Audi A3? Diesel Engine Technology
