VCDS - Communication Interrupted. WIN 8.1 (Solved)
milledriver
Post18-10-2014, 19:12    Subject: VCDS - Communication Interrupted. WIN 8.1 (Solved) Quote
Hello everyone, I've recently been experiencing an issue where, when trying to read data from various vehicles (engine control unit), I receive the error message "Communication with engine control unit not possible" after about 2 minutes. When trying to read the data again, it stops after 2 minutes.
Not every vehicle in the appendix has a log from the Polo showing where the problems occur.
The PC data is attached along with the VCDS data.
VCDS is up to date and has already been reinstalled.
Hi Dani,
 Ueber VCDS
 File size:  199.4 KB
 Viewed:  1949 times
 File size:  237.35 KB
 Viewed:  1422 times
 File size:  269.21 KB
 Viewed:  1391 times
Log-Log.txt
 Polo
Polo
 File name:  Log-Log.txt
 File size:  719 Bytes
 Downloaded:  895 times
Post18-10-2014, 20:28    Subject: VCDS - Communication Interrupted. WIN 8.1 (Solved) Quote
Have you tried connecting to the vehicle with a different computer or laptop to rule out the vehicle itself as the source of the problem?
I would first uninstall it again, then download the version from the store and install it again. The same applies to the Rosstech USB driver package; if it needs to be installed separately under Windows 8?
milledriver
Post18-10-2014, 20:38    Subject: VCDS - Communication Interrupted. WIN 8.1 (Solved) Quote
Thank you for the quick response!
"It worked perfectly with the XP calculator, but the version I downloaded from the store didn't work. Are there any other settings I need to adjust in Windows 8?" Does anyone have any experience with this?
Hi Dani,
Post18-10-2014, 21:43    Subject: VCDS - Communication Interrupted. WIN 8.1 (Solved) Quote
Please check which background services are currently running (your computer isn't exactly a high-performance machine).
If programs that temporarily halt the computer's operation, such as antivirus scanners, are running, the communication may be interrupted.
milledriver
Post19-10-2014, 11:43    Subject: VCDS - Communication Interrupted. WIN 8.1 (Solved) Quote
Hello Rainer,
I managed to get VCDS working smoothly again.
First, I turned off all the visual effects to make the laptop run faster. After that, I right-clicked and ran the compatibility troubleshooter.
I've been able to test it on 4 vehicles without any problems.
Here's the guide in case this problem occurs for someone else:
Here's how to adjust all visual effects to optimize performance.
To access performance information and tools, first click the "Start" button, and then click "Control Panel." In the search bar, type "performance information and tools" and then click on "performance information and tools" in the results list.
Click on "Customize visual effects." Administrator privileges required. If you are prompted to enter an administrator password or confirmation, please enter the password or confirmation.
Click the "Visual Effects" tab, then click "Adjust for best performance," and then click "OK." (A less drastic solution is the "Let Windows choose what's best for my computer" option, which allows Windows to select the effects to disable.)
Thank you very much.
Hi Dani,
Post19-10-2014, 14:13    Subject: VCDS - Communication Interrupted. WIN 8.1 (Solved) Quote
Thank you for the feedback icon_wink.gif.
It would be interesting to know which of the two changes ultimately led to the desired outcome.
It's unfortunately well-known that Windows 8.1 sometimes tends to be problematic.
No new posts Lupo 6X1 MJ 2002: Broken Flap Lock Lever Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wastegate actuator for turbocharger stuck. Solved Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts [Poll] VAG-COM/VCDS on Mac OS X Leopard: Solved! On-Board Diagnostics (OBD)
No new posts A4 B6 AYM: Boost pressure dropping Diesel Engine Technology
No new posts Engine power drops at 3800 RPM: ARL On-Board Diagnostics (OBD)
No new posts Audi CAGA: Engine Failure & Complete Breakdown Diesel Engine Technology
