G28 Where is the error?
TDI Butze
Post14-09-2003, 16:28    Subject: G28 Where is the error? Quote
Hi!
I've already been searching... and I've also found something. But nothing for my question!
Yesterday, my Golf 3 TDI (1Z) failed to start once. Since then, it has been occasionally stalling with a strong exhaust smoke! It occurs sporadically...
Error codes according to VAG-COM:
00513 G28 Encoder Motor Speed
No signal, intermittent
According to the error database: Cable break/Short circuit
Another cable broken!? Okay, now here's my question:
Which cable? From pin 2 to the MCU? And where could the error be?
...it probably happens more often...
Should I best immediately pull a new cable from the STG to the G28, or should I first measure, which might be okay because it's only sporadic icon_question.gif?
How does the G28 work... or why is there a sensor mass and a mass, and a cable to the controller!?
Why not just one mass, if he can switch it?
Thank you for all the answers!
Best regards, Matthias
Post15-09-2003, 16:50    Subject: Re: G28 Where is the error? Quote
It probably happens more often...
Hi Matthias,
The power circuit for the sensor consists of cables 1 (sensor ground to the STG) and 2 (signal line to the STG).
Cable 3 is the shielding.
Therefore, several possibilities should be considered: a break in cable 1 or 2, corroded/damaged connector contacts, short circuit 1-2 or 1-3, or a defect directly in the sender.
TDI Butze
Post16-09-2003, 1:20    Subject: G28 Where is the error? Translating...
[Translating...]Danke ulf!
Naja wenn ich da jetzt mitn Messgerät dran geh, ist warscheinlich wieder alles ok! Heute hat er das zumindest nicht mehr gemacht! Aber bestimmt wenn ich Mittwoch zur IAA fahr icon_confused.gif icon_sad.gif
Werds erstmal so lassen und mal nach schauen wenns öfter auftritt. Vielleicht hats ja auch was mit meinem letzten Fehler zutun. Dass das Pumpenkabel daher Masse hatte!?
Werds im laufe der woche mal durchmessen und wenn der Geber nicht allzuviel kostet, werd ich den auch neu machen.
MfG Matthias
TDI Butze
Post20-09-2003, 0:30    Subject: G28 Where is the error? Translating...
[Translating...]Hi!
Nach ein paar mal ruckeln hab ich heute wieder den Fehlerspeicher ausgelesen.
Diesmal nich 513 sondern 553 G70 Luftmengenmesser, unplausiebles Signal, sporadisch.
Könnten die beiden Fehler zusammen hängen?
Post20-09-2003, 10:51    Subject: G28 Where is the error? Translating...
[Translating...]
AFAIK eher nicht.
Es sei denn, der OT-Geber setzt zeitweise aus, der Motorcomputer zählt daher weniger Umdrehungen, bekommt aber gleichzeitig gleichzeitig das Signal für den normalen Luftdurchsatz, was pro Hub dann rechnerisch die vielfache Luftmasse des Normalen ergäbe (nur als Theorie).
Aber dann müßte eigentlich auch der Dioden-Ersatz des LMM mit einem Fehlereintrag quitiert werden, was der 1Z wohl noch nicht macht . . .
Michael II
Post20-09-2003, 10:56    Subject: G28 Where is the error? Translating...
[Translating...]
wie immer bei wechselnden, sporadisch auftretenden Fehlern (und Ruckeln):
1. Relais 109 prüfen
2. Masseverbindungen prüfen
Tschüss
Michael II
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS error On-Board Diagnostics (OBD)
No new posts Fehler in der WFS Diesel Engine Technology
No new posts AGR errors On-Board Diagnostics (OBD)
No new posts 3C0-937-049-30-H Error: Troubleshooting Guide On-Board Diagnostics (OBD)
