2.0 TDI stirbt ab - BMP | Posts 16+
Go to page: Previous  1, 2
Post30-09-2014, 12:18    Subject: Quote
Therefore, I strongly suspect the EGR valve!
It's not ruled out, but as Rainer writes, the amount of ash and the loading status are extremely concerning. I don't know if active regeneration can even occur with a loading level of >50%.
If that's the case, the DPF will gradually become clogged up more and more.
It should also be noted that the increased exhaust pressure may cause more exhaust gases to flow through the EGR system (which may not be functioning correctly).
Here is the translation:
Here are also some guidelines: https://community.dieselschrauber.org/en/viewtopic.php?t=24222
Translated on 12-10-2026, 3:25.
Post30-09-2014, 13:29    Subject: Quote
dieselschrauber wrote:
However, that alone won't help you at all.
Because of the ash mass in the DPF:
If the maximum value of 60 g is reached or exceeded, regeneration is no longer permitted, and the particulate filter must be replaced.
Hello Rainer,
Contrary to the above statement, in my experience, the BMP (Diesel Particulate Filter) continued to regenerate automatically until it reached approximately 65 grams of ash. Also, the DPF warning light did not illuminate. (I cleaned it when it reached 65 grams).
However, the soot load was never actually at 50%, which is obviously a clear indication that regeneration was not taking place...
Code:
Adresse 01: Motorelektronik        Labeldatei: RKS\03G-906-021-BMM.clb
   Teilenummer SW: 03G 906 021 NK    HW: 03G 906 021 AB
   Bauteil: R4 2,0L EDC G000AG  9971
   Revision: --H07---    Seriennummer: VWZCZ000000000
   Codierung: 0000078
   Betriebsnr.: WSC 48992 143 80611
   VCID: 75EA34D41C031FB6B75-8020
Greetings.
Guste.
Translated on 12-10-2026, 3:27.
Post30-09-2014, 14:13    Subject: Quote
Hello Guste,
The sentence I posted was in connection with the forced regeneration; anyway, nothing more will happen automatically for the person who asked the question. icon_wink.gif
Translated on 12-10-2026, 3:28.
blackblizzard
Post30-09-2014, 14:59    Subject: Quote
It should also be noted that the increased exhaust pressure can cause more exhaust gases to flow through the EGR system (which may not be functioning correctly)...
I think so too. A new EGR valve has been ordered, and I will report back on the results.
Once the engine is running again, I'll start logging data and then see what's happening with the DPF.
Translated on 12-10-2026, 3:29.
blackblizzard
Post01-10-2014, 11:39    Subject: Quote
Okay, I installed a new EGR valve; the old one was defective (I'll post a comparison video later).
Now I'm just having a problem with the DPF, which is probably why the car is in limp mode.
Differential pressure at idle is 12, and at full throttle at idle it is approximately 300.
The ash content remains at 69, while the loading coefficient has decreased to 35.
Can I force a regeneration?
Translated on 12-10-2026, 3:30.
blackblizzard
Post01-10-2014, 13:14    Subject: Quote
Here's the video and the log (full throttle).
Set the ash mass to 49 --> no error in memory and no emergency mode.
What should I do next?
2.0 TDI stirbt ab - BMP | Posts 16+ - AGR.mp4
 AGR: defekt und neu
 File size:  5.25 MB
 Viewed:  3118 times
log.csv
 Vollgaslog MWB 11, 67, 68
 File name:  log.csv
 File size:  1.77 KB
 Downloaded:  274 times
Translated on 12-10-2026, 3:31.
Post01-10-2014, 13:28    Subject: Quote
Thank you! The excessive DPF soot buildup is likely caused by a malfunctioning EGR valve that is not closing properly.
Despite this, considering the mileage and the amount of ash stored in the engine control unit, it should be checked to see if the system is simply full.
My suggestion would be to first check if the loading status actually returns to 0%, and if it does, create a log of the differential pressure and compare the values with those in the topic I linked: 323.85 mbar seems to be the upper limit of the differential pressure sensor's measurement range.
P.S. The conversion of the .csv file that you performed was not only unnecessary, but it also corrupted the file. Just open the logs with KDataScope and you're done!
Translated on 12-10-2026, 3:32.
blackblizzard
Post01-10-2014, 23:33    Subject: Quote
So, does that mean I should force a regeneration of the DPF due to the soot load?
And: Am I correct in my reasoning? The soot level is determined by the differential pressure. However, since ash is produced when the soot is burned, this ash is calculated (and the differential pressure increases further).
Translated on 12-10-2026, 3:33.
Post02-10-2014, 0:09    Subject: Quote
Something like this: In new filters, or those with little accumulated ash, this is not a major issue. However, when the filter is nearing its maximum ash capacity, only a relatively small amount of filter surface area remains permeable... the fill level, or differential pressure, increases more rapidly, active regeneration cycles are shortened, fuel consumption increases, and in some cases, the engine oil level may rise.
So, either have the DPF cleaned or regenerated, or replace it.
Personally, I would (if it were my car) immediately replace the differential pressure sensor and possibly have a software update (if available) performed at the icon_lol.gif.
Translated on 12-10-2026, 3:34.
Post02-10-2014, 9:29    Subject: Quote
The engine control unit calculates the amount of soot based on the differential pressure in the respective operating condition. However, the amount of ash increases with each regeneration cycle, which causes the overall differential pressure values to increase over time. Based on this, along with the mileage and the amount of fuel consumed, it is possible to estimate the amount of ash in the filter.
"In my experience, the ash mass value tends to be more of an estimate than a precise measurement. I had my DPF removed after about 80,000 km, and although the ash mass calculated by the engine control unit was within the expected range, the filter itself was practically empty. Ultimately, it's difficult to predict the actual amount of ash present, as it depends on factors such as the type of engine oil used (additives or oils that produce less ash), the condition of the engine (high or low oil consumption), the driving profile, and the type of fuel used."
If your DPF is still the original one and has never been cleaned, it's very likely to be full given the mileage.
Translated on 12-10-2026, 3:36.
blackblizzard
Post03-10-2014, 8:55    Subject: Quote
Thank you for all the information!
Now I understand what needs to be done with the DPF.
Before that, I'm going to measure the differential pressure myself (just out of curiosity), as I happen to have a differential pressure sensor lying around in my workshop.
Currently, it's in a limp mode, the DPF light is on, and the load is at 61%. Is a forced regeneration too risky?
Translated on 12-10-2026, 3:38.
Post03-10-2014, 11:21    Subject: Quote
Is emergency regeneration too dangerous?
It's highly unlikely that it will be possible again.
The DPF should be removed as soon as possible. While you're at it, please also check if there's another reason for the rapid increase in DPF clogging, such as high oil consumption (often from the turbocharger) or excessive soot buildup in the engine due to a leak in the charge air system (where air intended for combustion escapes into the atmosphere).
The latter are also not uncommon during operation and can be identified by oil traces on the charge air ducts or intercooler, as well as by the corresponding noises.
Translated on 12-10-2026, 3:39.
blackblizzard
Post03-10-2014, 13:17    Subject: Quote
Okay. I couldn't detect any oil consumption, but rather an increase in oil level (possibly due to DPF regeneration?).
Can I remove the filter without using a lift?
Translated on 12-10-2026, 3:40.
blackblizzard
Post30-10-2014, 9:30    Subject: Quote
Okay, I installed a new DPF and changed the oil (it was as thin as water).
I set the ash mass to 0g, then restarted the system several times and cleared the error memory. Now it seems to be working fine for the moment. Is there anything else I need to do? I heard something about a "regeneration cycle"...
Regarding the DPF removal: I also detached the driveshaft on the transmission side, which made the process much easier! (I only removed the sensors and wiring after the DPF was already out).
Translated on 12-10-2026, 3:41.
No new posts Golf 5 / Audi A3 BKC Engine Failure: Won't Start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf 3 TDI: Engine Failure? Causes & Fixes Diesel Engine Technology
No new posts Engine Failure: Causes and Solutions Diesel Engine Technology
No new posts A6 2.4 runs for 10 seconds and then dies. Gasoline Engine Technology
No new posts Engine diesels, and it's jerking while running! Diesel Engine Technology
