Alle vier Reifen innen bis auf Gewebe abgefahren....Fehler? | Posts 16+
Go to page: Previous  1, 2
scrdel
Karma: +4 / -2   Thank you, like it!
2002 Volkswagen Passat
Post11-11-2014, 22:45    Subject: Quote
Hey, while I was changing the shock absorbers, I noticed the control arms. The rubber bushings were already starting to deteriorate, so I decided to replace them completely – both upper and lower ones, along with the tie rods and ball joints.
The control arms weren't completely finished yet, even though they were the first ones from 2002... but they weren't bad at all.
The work was incredibly difficult under the carport, with jacks and two car lifts... new_all_coholic.gif
I had the wheel alignment done today. There were slight deviations due to the new steering knuckles, but nothing major... now everything is back to normal.
The Bilstein B4 shock absorbers actually work perfectly well with the original suspension system!
It's wonderful to be able to enjoy driving comfort again, and now it drives like a new car, for the next 12 years... icon_wink.gif
Sven.
Translated on 16-08-2026, 11:31.
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tire Wear Audi A3: Front Tires Worn Inside Transmission, Chassis, Body & Interior
No new posts Worn Inner Tire: Causes & Solutions Transmission, Chassis, Body & Interior
No new posts Tire Wear Uneven, Alignment OK Transmission, Chassis, Body & Interior
No new posts Uneven Tire Wear: Causes & Solutions Transmission, Chassis, Body & Interior
