T5 GP RPK nachgerüstet, Codierungsprobleme - Gelöst | Posts 16+
Go to page: Previous  1, 2
Mc_Givertechnik
2010 Volkswagen T5
Post30-06-2013, 12:16    Subject: Quote
Hello!
In recent weeks, I haven't had much time to delve back into the history of this topic. Now, I've compared the control units from vehicles of roughly the same production year, and even found some that had the same software versions for both the ABS/ESP control unit and the instrument cluster, some with RPK (presumably a specific feature) and some without. The control units have the same serial numbers and software versions, and the coding procedure I was recommended worked perfectly, which is what I expected. However, I'm still stuck with my T5. It won't code, and I can't figure out why.
The RPK control lamp does not illuminate on the instrument cluster, there are no error messages recorded, and the lines have been checked and measured for functionality.
What did I overlook, where might I have thought incorrectly, or taken the wrong approach to solving the problem? icon_wink.gif
Is it possible that something needs to be "coded in" somewhere to trick the ABS/ESP or AI into thinking something exists when it actually doesn't, in order to enable certain functions?
Greetings,
Peter.
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 26-07-2026, 9:50.
michiglaser
2007 Audi A4 Avant
Post01-07-2013, 12:07    Subject: Quote
Our T5.2 has the system installed.
If I can help you further with screenshots of the code, please let me know.
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 26-07-2026, 9:52.
Post01-07-2013, 12:17    Subject: Quote
"Autoscanning would be helpful because it includes part numbers and software versions in addition to the coding information."
michiglaser
2007 Audi A4 Avant
Post01-07-2013, 14:21    Subject: Quote
Okay...
VCDS version: RKS 11.11.5
Data as of: 20130111.
Monday, July 1, 2013, 2:20:43:39738 PM.
Vehicle type: 6N0
Scan: 01 03 08 09 10 15 17 18 19 22 25 2E 37 3C 47 56 57 69 6C 77
0B
Vehicle Identification Number: WV2ZZZ7HZBH11xxxx
01-Motor -- Status: OK 0000
03-Brakes -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate Control/Heating -- Status: OK 0000
09-Onboard network -- Status: OK 0000
10-Parking assist 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
17-in-1 instrument -- Status: OK 0000
18-inch heater -- Status: Error 0010.
19-CAN Gateway -- Status: OK 0000
22-All-wheel drive -- Status: OK 0000
Immobilizer system -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
3C track switch -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
69 followers -- Status: OK 0000
6C Reverse Camera -- Status: OK 0000
77-Phone -- Status: OK 0000
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Feld und lässt das Gras sanft wiegen. Es ist ein wunderschöner Tag."
The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze blows through the field, causing the grass to sway softly. It's a beautiful day.
Address 01: Engine (J623-CFCA) Label file: RKS\03L-906-022-CFC.clb
Part number SW: 03L 906 022 JB, Part number HW: 03L 907 309 H.
Component: R4 2.0L EDC H34 8752.
Revision: 22H34--- Serial Number: 00000000000000
Encoding: 0119401A233600080000
Operating number: WSC 02756 790 50316
ASAM Dataset: EV_ECM20BTD01103L906022JB 002007
ROD: EV_ECM20BTD01103L906022JB.rod
VCID: 6ED64D74B10C3F68C30
No error codes found.
Readiness: 0 0 0 0 0
Address 03: Brakes (-----)
Label file: RKS\7E0-907-37x-MK25AXT.clb
Part number SW: 7E0 907 379 G, HW: 7E0 907 379 E.
Component: ESP MK25A XT H43 0105
Revision: 00H43001
Encoding: 608764AD19A5069B26A49878796310
Operating number: WSC 02756 790 49152
VCID: 3666A51481DC47A8CB0
Address 08: Climate Control/Heating (J255)
Label file: 7E5-907-040.clb
Part number SW: 7E5 907 040 P, HW: 7E5 907 040 P.
Part number: Climatronic T5 H11 0304.
Revision: 00002001
Encoding: 0004000102
Operating number: WSC 02757 790 50316
ASAM Dataset: EV_ClimatronicT5 A01003
ROD file: EV_ClimatronicT5.rod
VCID: 3564A21894DA4CB0C2A
Subsystem 1 - Part number SW: 7E7 907 049 B, HW: 7E7 907 049 B.
Part: Rear control unit H10 0202.
Serial number: BHB-0010704110010065
Address 09: Body Control Module (J519)
Label file: RKS\7H0-937-08x-09.clb
Part number SW: 7H0 937 089 D, Part number HW: 7H0 937 089.
Part number: BCM T5GP Li4 H47 0230.
Revision: BS047001 Serial Number: 0398 073110525
Encoding: B8A0393A4F61240293284E707EAB875D8290600F60846941300000000000
Operating number: WSC 01515 666 41909
VCID: 3778A81086D6BEA0D06
Subsystem 1 - Part number: 1K0 955 559 AH
Label file: RKS\1K0-955-559-AG.CLB
Component: RLS 140311 05 54 0403
Encoding: 07302E
Subsystem 2 - Part number SW: 7E0 959 801 A, HW: 7E0 959 801 A, Label file: 7E0-959-801.CLB.
Component: J386__TSG_FT 003 3311
Encoding: 040000
Subsystem 3 - Part number SW: 7E0 959 802 A, HW: 7E0 959 802 A, Label file: 7E0-959-802.CLB.
Component: J387__TSG_BT 003 3311
Encoding: 040000
Subsystem 4 - Part number: 7E1 951 172.
Component: DWA sensor 00 001 0104.
Encoding: 000000
Subsystem 5 - Part number: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501.
Encoding: 000000
Subsystem 6 - Part number: 7E1 951 172.
Encoding: 000000
Subsystem 7 - Part number SW: 3C8 959 537 D, HW: 3C8 959 537 D, Label file: 3C8-959-537.CLB.
Component: E221__MFL-TK6 H06 0022
Encoding: E20000
Address 10: Parking Assist 2 (J446)
Label file: RKS\7E0-919-475.clb
Part number SW: 7E0 919 475 C, HW: 7E0 919 475 A.
Part: PARKING ASSIST 8K H11 0011
Revision: -------- Serial Number: 47401102300318
Encoding: 318001
ASAM Dataset: EV_VW75XParkAssis8K A01004
ROD: EV_VW75XParkAssis8K.rod
VCID: 326E990465B45B88E78
Address 15: Airbag (J234)
Label file: 5K0-959-655.clb
Part number SW: 7E0 959 655 C, HW: 7E0 959 655 C.
Part number: VW10Airbag007 H06 0013
Revision: -------- Serial Number: 003HM000XM9K
Encoding: 0000000000000000000000000000000
Operating number: WSC 02754 790 50316
ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
FILE: EV_AirbaVW10BPAVN750_VN75.rod
VCID: 3666A51489DC47A8CB0
Crash sensor for driver-side side airbag:
Serial number: 3495ZRB40630891IC8LC
Crash sensor for side airbag, passenger side.
Serial number: 3505ZRB405V0891I60GC
Address 17: Combination instrument (J285)
Label file: RKS\5K0-920-xxx-17.clb
Part number SW: 7E0 920 880 E, HW: 7E0 920 880 E.
Component: COMBINATION UNIT H04 0306
Serial number: 00000000000000
Encoding: 160F01
Operating number: WSC 24330 112 102413
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_VN75.rod
VCID: 2C52877C47900D78AD4
Address 18: Auxiliary heater
Label file: RKS\7E0-815-071.clb
Part number: 7E0 815 071 A
Component: J737, Auxiliary Heater, Part Number: 0404.
Revision: 00085000 Serial Number: 09019275D00000
Encoding: 0000031
Operating number: WSC 02757 790 00000
VCID: 23406C40E24EC2001CE
"One error found:"
01406 - No flame formation.
text
000 - -
Environmental conditions:
Error status: 01100000
Error priority: 3
Error frequency: 1.
Mileage: 27,280 km
Time: 0.
Date: 2019.06.14
Time: 07:35:35
text
Start
Temperature: 30.0°C
Voltage: 14.21 V
Temperature: 10.0°C
Address 19: CAN Gateway (J533)
Label file: RKS\6N0-909-901-6R.clb
Part number SW: 6N0 909 901, HW: 7H0 937 089.
Component: GW-K-CAN TP20 0230
Encoding: 042200
VCID: F0EAD30C2338A99851C
Address 22: All-wheel drive
Label file: RKS\0AY-907-554.lbl
Part number SW: 09N 907 554 A, Hardware: 09N 907 554 A.
Component: Haldex 4Motion, part number 6007.
Encoding: 0000007
Operating number: WSC 02756 790 00000
VCID: 3666A51441DC47A8CB0
Address 25: Immobilizer (J334)
Label file: RKS\5K0-920-xxx-25.clb
Part number SW: 5K0 953 234, HW: 5K0 953 234.
Component: IMMO H04 0306
Encoding: 000000
Operating number: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VN75.rod
VCID: EADEC1640DE453481F8
Address 2E: Media Player 3 (J650)
Label file: RKS\5N0-035-342.lbl
Part number SW: 5N0 035 342 D. Part number HW: 5N0 035 342 D.
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial Number: 7669555438
Encoding: 010000
VCID: 285A7B6C5B68215849C
Address 37: Navigation (J0506)
Label file: RKS\1T0-035-680.clb
Part number SW: 7E0 035 680, Hardware: 7E0 035 680.
Component: RNS-MID H42 2728
Revision: AB001001 Serial Number: VWZ6Z7L4062018
Encoding: 04010002010000A000
Operating number: WSC 02754 790 00000
ASAM Dataset: ------------------------- ------
VCID: E2CEA944FDD40B08D78
Address 3C: Lane change
Label file: None
Part number SW: 7E0 907 566 B, HW: 4L0 907 566 A.
Component: J0769 SWA MasterH12 0110
Revision: 00H12000 Serial Number: 6PZ 009 014-07
Encoding: 0010161
VCID: 2F689070BE867660886
Part number: 7E0 907 568 B.
Component: J0770 SWA Slave H09 0110
Address 47: Soundsystem Label file: RKS\3C0-035-456.lbl
Part number SW: 7E0 035 466, HW: 7E0 035 466.
Component: 10-channel DSP 0010
Revision: 00H06001 Serial Number: 75855000121103
VCID: E4C2AF5C27C00538254
Address 56: Radio (J0506) Label file: RKS\1T0-035-680.clb
Address 57: TV Tuner Label file: RKS\7L6-919-148.clb
Part number SW: 7L6 919 148 A, HW: 7L6 919 148.
Component: R0078 TVhybridDVB 0150
Revision: R0H21000 Serial Number: 93900500694401
Encoding: 0000801
VCID: 3A7EB12475C4A3C82F8
Address 69: Trailer (J345) Label file: RKS\1K0-907-383-MY8.lbl
Part number SW: 1K0 907 383 F. Hardware: 1K0 907 383 F.
Component: Trailer H09 0100
Revision: 3A001001 Serial Number: 00000144353690
Encoding: 410D000100000000
VCID: 306A930C63B8699891C
Address 6C: Rear view camera
Label file: RKS\5N0-907-441.clb
Part number SW: 7E0 907 441, HW: 7E0 907 441.
Component: J772__Rearview 0040
Revision: 00H09000 Serial Number: 525PA8-J110738
Encoding: 0030015
Operating number: WSC 02971 612 181466
VCID: E5C4B2582CFA7C3032A
Address 77: Phone (J412)
Label file: RKS\3C8-035-730-A.clb
Part number SW: 5N0 035 730 D, Hardware part number: 5N0 035 730 D.
Component: Telephone 009 0511
Revision: -------- Serial Number: 35909603115878
Encoding: 020101000100000000000000
ASAM Dataset: EV_UHVPremi A01005
ROD: EV_UHVPremi_VN75.rod
VCID: 295C7E6848621850562
Address 0B: Auxiliary heater
Label file: RKS\7E0-819-006.clb
Part number: 7E0 819 006 D
Part number: J604. Item: Auxiliary heater. Code: 0401.
Revision: L100300A Serial Number: 00000000000000
VCID: 285A7B6C9868215849C
End.
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 26-07-2026, 10:31.
Post01-07-2013, 15:50    Subject: Quote
Problem-solving AI:
Part number SW: 7E0 920 870 C HW: 7E0 920 870 C
Component: KOMBI H04 0204
The software version you have is different from the one that's working correctly elsewhere.
Translated on 26-07-2026, 10:32.
Mc_Givertechnik
2010 Volkswagen T5
Post08-11-2014, 11:40    Subject: Quote
Hello!
Today, I was able to confirm that retrofitting the RPK (Rear Power Kit) on a T5 is not really a problem if you have the correct coding.
In byte 12, bit 4 needs to be changed from 0 to 1, and that's all. Even the AI doesn't need to be re-encoded; it will work fine as is.
Therefore, the encoding is as follows:
alt: 108724AD09A7089924A6907A 6A 6410
new: 108724AD09A7089924A6907A 7A 6410
Greetings,
Peter.
P.S.: The software version used in the AI application is apparently irrelevant.
Translated on 26-07-2026, 10:33.
Post08-11-2014, 11:42    Subject: Quote
Thank you for the feedback!
In byte 12, bit 4 must be changed from 0 to 1.
What does this do?
Translated on 26-07-2026, 10:35.
Mc_Givertechnik
2010 Volkswagen T5
Post08-11-2014, 13:45    Subject: Quote
Activates the Rest Pressure Control (RPK) function in the ABS control unit.
Unfortunately, the label file for the ABS control unit is not visible.
Greetings,
Peter.
Mc_Givertechnik
2010 Volkswagen T5
Post27-11-2014, 8:37    Subject: Solved: [Problem/Issue] Solution Explained Quote
Hello!
Could the article possibly be marked as "Solved" so that people can see that the encoding option actually exists? I can't edit the thread title anymore.
Peter.
Translated on 26-07-2026, 10:36.
Wiesel
Post27-11-2014, 8:52    Subject: Quote
Check icon_wink.gif.
Translated on 26-07-2026, 10:37.
Mc_Givertechnik
2010 Volkswagen T5
Thank you!
No new posts Wastegate actuator for turbocharger stuck. Solved Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts GRA nachgerüstet On-Board Diagnostics (OBD)
No new posts Audi Q5 with aftermarket tow hitch Electrical Systems, Vehicle Electronics, Multimedia
This topic is locked, you cannot edit or reply. Oil in timing chain drive - MKB ABS (Solved) Gasoline Engine Technology
This topic is locked, you cannot edit or reply. Engine Diagnostics: 1.6D/TD Solutions Diesel Engine Technology
