Golf 4, 2000, APF,Sekundärluftpumpe Schaltsignal fehlerhaft | Posts 16+
Go to page: Previous  1, 2
Cr4sh
Registered VCDS User
Post14-12-2014, 0:55    Subject: Quote
Unfortunately, the update was unsuccessful. The secondary air valve is working correctly. Also, the vacuum source it connects to, and the switching valve located upstream of it.
Surprisingly, nothing is being stored in the error memory anymore.
However, the jerks and extreme misfires are still present. I read somewhere else that it was the engine control unit (ECU) in the end, and I'm just at a loss for what to do now.
Is it possible to read the fuel pressure on a Golf 4 1.6 SR? I couldn't find a matching MWB (Material Safety Data Sheet) for that.
Post14-12-2014, 11:09    Subject: Quote
Have I missed something, or has anyone posted an engine control unit part number (VAG part number) or at least a scan of it anywhere yet?
Cr4sh
Post17-12-2014, 21:01    Subject: Quote
Here's a current car scan:
Wednesday, December 17, 2014, 20:50:31:58539
VCDS -- A Windows-based VAG/VAS emulator.
VCDS Version: DRV 12.12.3.0
Data as of: 20140910.
Mileage: 137,330 km. Repair order:
Vehicle type: 1J - VW Golf/Bora IV (1998 > 2006)
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 137,330 km
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module
Label file: DRV\06A-906-033-APF.lbl
Part number: 06A 906 033.
Part: SIMOS33 1.6L 2V 00HS3087
Encoding: 00231
Operating number: WSC 45241
VCID: DCBB97734F2B07E3BFB-515A
No error codes found.
Readiness: 0000 1000
Address 03: Brake Electronics Label file: DRV\1J0-907-37x-ESP-F.lbl
Part number: 1C0 907 379.
Component: ESP 20 CAN V005
Encoding: 10241
Operating number: WSC 52410
VCID: E7D1B89F866D543B229-4B18
Address 08: Climate Control/Heating Module. Label file: DRV\3Bx-907-044.lbl
Part number: 3B1 907 044 C.
Component: CLIMATRONIC C 0.7.0
Encoding: 01010
Operating number: WSC 01317
VCID: 21456687A8C9EA0B2CD-5284
"1 error found:"
00603 - Actuator motor for footwell/defrost flap (V85)
37-10 - defective - intermittent.
Address 15: Airbag
Label file: DRV\6Q0-909-605-VW5.lbl
Part number: 6Q0 909 605 A
Part number: 02 AIRBAG VW5 0003
Encoding: 12338
VCID: 356DA2D70C4176ABE05-4B18
Address 17: Control panel module Label file: DRV\1J0-920-xx0-17.lbl
Part number: 1J0 920 802 B
Component: COMBINATION INSTRUMENT + TRIP COMPUTER. BOO V23.
Encoding: 01143
Operating Number: WSC 00000
VCID: 2247698BADCFF113357-5178
Subsystem 1 - Part number: Ident
Part number: WEGFAHRS.:VWZ6Z0X1003207
Identification Number: WEGFAHRS.VWZ6Z0X1003207
Address 19: Diagnostic interface
Label file: DRV\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway K<->CAN 0001
Encoding: 00006
VCID: F0E3D3C3B3A39383733-5178
Address 46: Comfort System Label file: DRV\1J0-959-799.lbl
Part number: 1J0 959 799 Q
Component: 4C Central Control Unit, Comfort Version, 0001.
Encoding: 04097
VCID: 4C9BE7337FCB1763AFB-4B32
Subsystem 1 - Part number: 1J1959801C
Component: 4C Throttle Control Unit. FS0002F
Subsystem 2 - Part number: 1J1959802D
Component: 4C Throttle Control Unit. BF0002r
Subsystem 3 - Part number: 1J4959811C.
Component: 4C Throttle Control Unit. HL0002r
Subsystem 4 - Part number: 1J4959812C
Component: 4C Throttle Control Unit. HR0002H
End.
Post18-12-2014, 13:25    Subject: Quote
There is no measurement block for fuel pressure.
If you click on the blue-highlighted name of the label file within the measurement blocks, the file will open, and you can see what's inside.
Short-term and long-term adaptation of the lambda control system, and the coolant temperature.
Cr4sh
Post22-12-2014, 9:53    Subject: Quote
We were probably able to identify the problem, even though it's not 100% clear which one it was.
After reviewing the data again, I repeatedly noticed a high temperature reading. Another point was that cylinder 2 was now experiencing misfires.
However, it's normal for the APF (automatic transmission) to have a temperature that's more than 100 degrees Celsius above the coolant temperature, because the thermostat in the APF only opens at 106 degrees Celsius!
However, it was surprising that this value did not decrease and remained relatively constant at 106-108 degrees Celsius.
I replaced the dual coolant temperature sensor as a corrective measure. As a result, the coolant temperature now fluctuates continuously between 96 and 106 degrees.
For cylinder 2, I swapped the cables with those from cylinder 1 for testing purposes, as they have the same length. It's possible that the new cable itself was also faulty, and the problem would have shifted to the other cylinder, but that didn't happen.
The misfires were gone after the two measures were implemented. Another possibility is that the thermostat was stuck inside its housing and that my shaking of the sensor may have dislodged it.
The problem has been resolved for the past few days, at least.
No new posts Golf 1J Doku: Gala Function Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Combination instrument, Golf, Bora, 05.99 to 04.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J AC Repair: No Cooling - 2000 Model Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 PD Engine (ATD) - No KI, 2000 On-Board Diagnostics (OBD)
No new posts Golf 4 TDI: Jerking/Hesitation at 2000-3000 RPM and under... On-Board Diagnostics (OBD)
No new posts EDS System Error: Troubleshooting & Fixes Diesel Engine Technology
No new posts Outdoor Temperature Display Malfunction! Diesel Engine Technology
