Are there scratches or blemishes on the new windshield?
Post24-04-2015, 8:12    Subject: Are there scratches or blemishes on the new windshield? Quote
Our new Skoda Rapid Spaceback, with approximately 20,000 km on the odometer, exhibits a veil of tiny bright spots when viewed through the freshly washed windshield towards the low-lying (bright) sun, estimated at around 5 points per square centimeter.
Visually, it's comparable to the micro-metal flakes in the spray mist of a metallic paint spray can when viewed against a bright light.
You can only see it below the sun, meaning that depending on the head position, different areas of the bright spot halo will become visible.
It spreads fairly evenly across the entire surface.
Is this "state of the art" or a valid reason for a complaint?
olli
Karma: +46 / -0   Thank you, like it!
Post24-04-2015, 8:55    Subject: Are there scratches or blemishes on the new windshield? Quote
It could be anything. (But you don't have a nano-coating, do you?) Have you tried seeing if it can be polished off with a little force? In my current "winter car," there were also streaks on the windshield when I took possession; the manufacturer then recommended a glass ceramic cleaner. It worked well.
Best regards from Berlin,
olli
A6 CANA/JME /
Ex-A6 AEL
Post24-04-2015, 15:20    Subject: Are there scratches or blemishes on the new windshield? Quote
Did the car ever used to be parked under linden trees?
Post24-04-2015, 15:41    Subject: Are there scratches or blemishes on the new windshield? Quote
Lime trees... AFAIK no, but it's my partner's car.
Just now, I looked at the disc under a magnifying glass, but those tiny things don't look like drops of flower sap to me.
Even when I gently feel the area with my fingertips, I don't notice any corresponding bumps.
Post24-04-2015, 18:01    Subject: Are there scratches or blemishes on the new windshield? Quote
Is this considered "state of the art" or a reason for a complaint?
It's definitely worth making a complaint, especially if you're feeling frustrated. At least that way, you would have reported the issue early on, rather than potentially waiting too long. You can explain that it was the first time the car was washed or cleaned.
Perhaps... if you're lucky, it's residue from a strong cleaning agent that will disappear over time.
No new posts A3 Windshield Stain: Documentary (8P1) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Windshield Crack: Documentary of a 1-Year Old Car Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Windshield crack Transmission, Chassis, Body & Interior
No new posts Distorted Windshield: Causes & Fixes Transmission, Chassis, Body & Interior
No new posts Rock chip on windshield, filling the crater Transmission, Chassis, Body & Interior
No new posts New Ibiza: 96 kW Power & Performance Diesel Engine Technology
