"Missing" Control Unit 76? Parking Assist?
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
stolley
Karma: +38 / -1   Thank you, like it!
Post21-05-2015, 20:38    Subject: "Missing" Control Unit 76? Parking Assist? Quote
Hello everyone!
My T5's parking sensors are malfunctioning: as soon as I put it in reverse, it beeps constantly.
After a VCDS scan, I noticed that control unit number 76 is not appearing.
Could it be that the PDC (Parking Distance Control) in my vehicle is controlled by a different control unit?
Here's the car scan:
Thursday, May 21, 2015, 10:48:47 PM: 25065
VCDS -- A Windows-based VAG/VAS emulator.
VCDS Version: RKS 14.10.2.0
Data as of: 20150412.
Vehicle Identification Number: WV2ZZZ7HZ8H1xxxxx License plate:
Mileage: 148,810 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
57 6E 76 77 78 7D
Vehicle Identification Number: WV2ZZZ7HZ8H1xxxxx Mileage: 148,810 km
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module
Label file: DRV\070-906-016-BPC.clb
Part number SW: 070 906 016 DR Hardware number: 070 906 016 DR
Part: R5 2.5L EDC G000AG 1584
Revision: --H06--- Serial Number: VWZ7Z0G6131852
Encoding: 0001075
Operating number: WSC 30696 264 83473
VCID: 63C39824A134513913D-515A
No error codes found.
Readiness: 0 0 0 0 0
Address 02: Transmission Label file: DRV\09G-927-750.clb
Part number SW: 09K 927 750 L, Hardware number: 09K 927 750 L.
Part: AQ 250 6F 1045
Revision: 00H67000 Serial number:
Encoding: 0000072
Operating number: WSC 02756 790 00000
VCID: 3E7509506A165CD15C3-515A
Address 03: Brake Electronics Label file: DRV\7H0-907-37x-ESP.lbl
Part number SW: 7H0 907 379 R, HW: 7H0 907 379 R.
Component: ESP MK25E1 0104
Revision: 00H31001
Encoding: 0000555
VCID: 44817BB804FA36010A7-513C
Address 08: Climate Control/Heating Module. Label file: DRV\7Hx-907-040.lbl
Part number: 7H5 907 040 D.
Component: CLIMAtronic T5 4221
Encoding: 0011040
Operating number: WSC 02757 790 00000
VCID: 2C5133188C6ADE41E27-513C
Subsystem 1 - Part number: 7H5 907 049 D
Part: Display_2_ClimaT5 X 0307
"1 error found:"
01592 - Sensor for air duct (G238)).
010 - Short circuit/overload after positive terminal.
Address 09: Central Electronics
Label file: DRV\7H0-937-049.lbl
Part number: 7H0 937 049 AE.
Component: BORDNETZ SGVER 1.0 2101
Encoding: 0000359
VCID: 75E7D67C1FA0DF894D9-513C
"1 error found:"
00991 - Interior lighting.
012 - Electrical fault in the circuit.
Address 15: Airbag
Label file: DRV\6Q0-909-605-VW5.lbl
Part number: 1C0 909 605 F
Part number: 11 AIRBAG VW61 0R 0004.
Encoding: 12593
VCID: 275BCC34C58CFD190F5-515A
Address 17: Terminal block module Label file: DRV\7Hx-920-xxx-17.lbl
Part number: 7H5 920 872 L.
Component: COMBINATION INSTRUMENT + SPEEDOMETER VDO V02
Encoding: 05113
Operating number: WSC 71692
VCID: 3C7103582C0A4EC1727-513C
WV2ZZZ7HZ8H109783 VWZ7Z0G6131852
Address 18: Auxiliary heater
Label file: DRV\7H0-819-008.lbl
Part number: 7H0 815 071 F.
Component: Auxiliary heater 0209.
Operating Number: WSC 00000 000 00000
VCID: 2B5330048964D979EBD-513C
"1 error found:"
00664 - Fuel level indicator.
002 - Lower limit exceeded - Intermittent.
Address 19: Diagnostic interface
Label file: DRV\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway K<->CAN 0001
Encoding: 00006
VCID: 70E9E76830C2FAA19EF-513C
Address 37: Navigation
Label file: DRV\7L6-919-887-DVD.lbl
Part number: 7H0 919 887 B
Component: Navigation 0030
Encoding: 0000101
VCID: 3B730044790449F97BD-515A
Address 45: Interior monitoring. Label file: DRV\7Hx-951-171.lbl
Part number: 7H5 951 171 C.
Component: Interior monitoring system. 2917.
Encoding: 0000012
VCID: 2F6B2414BD7CA559C75-51B2
Subsystem 1 - Part number: 7H5 951 178.
Component: Interior monitoring system 1607.
Address 46: Comfort System. Label file: DRV\7H0-959-433.lbl.
Part number: 7H0 959 433 B
Component: C11 Comfort Device 0004
Encoding: 00031
VCID: 326D2D60FE4E88B1A8B-4B18
Address 56: Radio Label file: DRV\7L6-035-186-DVD.lbl
Part number: 7L6 035 186 D.
Component: Radio 0030
Encoding: 0016410
VCID: 34612B78545A8681BA7-513C
Address 77: Telephone (J73
) Label file: DRV\1K8-035-730.clb
Part number SW: 7H0 035 730 HW: 7H0 035 730
Component: Telephone 005 1411
Revision: 00005000 Serial number: 20330620005755
Encoding: 000211
VCID: 61CF922C7B284329011-515A
"1 error found:"
01299 - Diagnostic interface for data bus (J533)
004 - No signal/communication - Sporadically.
Environmental conditions:
Error status: 00100100
Error priority: 3
Error frequency: 1
Lost Count: 39
Time: 0
End----------------------------(Duration: 06:02)-----------------------------
bloesch
Post22-05-2015, 7:50    Subject: "Missing" Control Unit 76? Parking Assist? Quote
Parking assist system, possibly retrofitted?
P.S.: You should probably replace the air quality sensor; then your fans won't be running constantly anymore...
Post22-05-2015, 20:51    Subject: "Missing" Control Unit 76? Parking Assist? Quote
Which fan are you talking about? Please clarify the connection for us. In any case, I know of many defective air quality sensors, but the fresh air blower and the radiator fan are still working normally. The fresh/recirculated air flap is activated only when the sensor is functioning correctly, and also when the car is in reverse gear.
Post22-05-2015, 23:17    Subject: "Missing" Control Unit 76? Parking Assist? Quote
Okay, I have a scan here of a Multivan, model year 2007. The STG 76 is definitely present there.
stolley
Post06-06-2015, 16:59    Subject: "Missing" Control Unit 76? Parking Assist? Quote
bloesch wrote:
Parking assist perhaps retrofitted?
Damn!
Actually, it was delivered without parking assistance!
So far, I thought only the front sensors had been retrofitted.
Then I probably don't have a chance with VCDS, do I?
Apparently, the only option left for me is to turn off the PDC. But how?
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Turbocharger Control Unit: Faulty, 18360, 18361 Diesel Engine Technology
No new posts Error message: "Control unit incorrectly coded" Diesel Engine Technology
This topic is locked, you cannot edit or reply. Audi A6 TDI Engine Control Unit "02" (C4 AAT) Diesel Engine Technology
No new posts 1Z/AHU "simplified", control unit from AHU to AFN Diesel Engine Technology
