BLS Motor, Ladedruck Überschwinger | Posts 16+
Go to page: Previous  1, 2
Post01-07-2015, 1:32    Subject: Quote
98er_alh wrote:
It remains just below the threshold of the motor drive
Please translate it for me icon_confused.gif.
Especially since the circled area is between 2500 and 3000 RPM?
Generally speaking, the engine is operated at the point where the minimum of the three limits – driver demand, torque, and fuel consumption – is reached.
Since the "notch" I discovered always has a lower torque limit, the notch is not actually "used."
98er_alh wrote:
ich sehe nun auch das die Überschneidung im 2. und 3., aber nicht im 4. Gang appearance.
I don't quite understand what you mean right now.
98er_alh wrote:
And how did you reduce the speed curve?
Is this related to the datascope software - the latest version?
Excel - Speed on the secondary axis (was faster than the three Nm curves on the secondary axis icon_smile.gif.
Translated on 29-08-2026, 7:33.
98er_alh
Post01-07-2015, 2:11    Subject: Quote
Excel - Speed on secondary axis
Okay, I just thought I might have missed something.
98er_alh wrote the following:
meine 3 Beschleunigungskurven im Log habe ich im 2. 3. und 4. Recording started.
And in the 4th gear, there's no "notch" at the top, and it doesn't jerk.
Generally speaking, the engine is operated with the minimum of the three limits: driver demand, torque, and fuel consumption.
I've got that figured out so far.
"But isn't the 'peak' at the maximum, and doesn't the torque limit define the minimum of the three?"
I'm unfortunately not quite getting it icon_confused.gif, and also, my RPM is around 1800.
best regards
Andreas.
Translated on 29-08-2026, 7:35.
Post01-07-2015, 8:40    Subject: Quote
The torque limit is the lowest value in your curves, so it's okay.
What is the specific need for action here? It seems reasonably okay. While the boost pressure regulation isn't perfect, it's not necessarily a reason to remove the turbocharger.
Translated on 29-08-2026, 7:37.
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Boost Overpressure Up to 1.7 Bar (LDA) On-Board Diagnostics (OBD)
No new posts Boost Overboost G4 ALH: How High? Diesel Engine Technology
No new posts Überschwinger Ladedruck Polo BLT TDI bis 2 bar (3 absolut) On-Board Diagnostics (OBD)
No new posts Boost Pressure Surge: Fix with N75 Adjustment Diesel Engine Technology
