F B Guest
30-06-2015, 6:10 Subject: Professional Feather Replacement Service |
Recently, I had the pleasure of replacing the front springs on an older E-Class Mercedes.
Unfortunately, my coil springs didn't fit... grumble.
Okay, I'll start by removing the shock absorber.
I then took a long, strong threaded rod, two sturdy supports, heavy-duty nuts, and compressed the new spring.
Secure the feather with some strong ties and complete the feather leg.
Installed, added weight, and cut and removed the straps.
Okay, it's installed, working, and therefore the task is complete.
But how do professional companies actually do it?
My coil spring compressors don't fit inside the strut, and they also don't fit because of the taper of the spring.
Something like that already looks quite decent.
http://www.amazon.de/Hergestellt-f%C3%BCr-DEMA-Spezial-Federspanner/dp/B006JZXMG4/ref=sr_1_27?ie=UTF8&qid=1435640721&sr=8-27&keywords=federspanner
I can hardly imagine someone at Daimler being at a workbench, tightening things together with a ratchet.
How do professional workshops do it?
Best regards, Frank.
Translated on 04-10-2026, 19:39.
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: NĂ€he DĂŒsseldorf
30-06-2015, 8:48 Subject: Professional Feather Replacement Service |
Quote: | | Then I took a long, strong threaded rod, 2 stable supports, strong nuts, and then I compressed the new spring. |
Something similar (an inner spring compressor) is available for Mercedes-Benz vehicles from various manufacturers in the "professional" category (e.g., Klann). LG, Onkel BM
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
Translated on 04-10-2026, 19:40.
F B Guest
30-06-2015, 8:59 Subject: Professional Feather Replacement Service |
Subject: Internal spring expander.
I've already covered that topic.
I'm tightening the spring, and how do I get the shock absorber in after that?
Are there any brackets or holders that can secure the spring in place, which I can then remove later?
Hint: I'm talking about the front springs...
Translated on 04-10-2026, 19:41.
30-06-2015, 9:14 Subject: Professional Feather Replacement Service |
While we primarily focus on VAG vehicles here, including a model designation like, for example, W124, or W210, W211, etc., for the "older E-Class" would be helpful. LG, Onkel BM
Translated on 04-10-2026, 19:42.
F B Guest
30-06-2015, 10:11 Subject: Professional Feather Replacement Service |
Okay, but I'm generally asking how this is handled in a workshop setting.
The issue with the acute care vehicle was resolved through a custom-built solution.
30-06-2015, 12:12 Subject: Professional Feather Replacement Service |
With the right spring compressor, of course.
Professional-grade wrenches are usually impact-wrench resistant. LG, Onkel BM
Translated on 04-10-2026, 19:43.
F B Guest
04-07-2015, 7:14 Subject: Professional Feather Replacement Service |
Sorry, but I would have bet my bottom dollar that a specialized workshop would...
The device may use hydraulics to compress the new spring.
and then secured with brackets or something similar.
So, they only cook with water.
If there's no better or alternative idea, I guess I'll have to dig deep into my pockets...
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
06-07-2015, 22:41 Subject: Professional Feather Replacement Service |
We're doing it with the inner spring compressor; it works great, because there's a hole specifically designed for that purpose, located in the middle of the spring on the lower control arm  . NA,Gehörlose wie ich können auch Schrauben! Ihr HĂRT ich FĂHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 04-10-2026, 19:44.
Profile PM Email Garage |
F B Guest
07-07-2015, 0:17 Subject: Professional Feather Replacement Service |
I think you're talking behind my back.
I'm starting from the beginning.
I have this nagging feeling that there must be something more to it than just pressing a spring together with a threaded rod.
Hydraulically, it should be faster and quieter.
Translated on 04-10-2026, 19:45.
08-07-2015, 21:41 Subject: Professional Feather Replacement Service |
Autoservice wrote: | | While we are primarily dealing with VAG here, a model designation such as, for example, W124, or W210, W211, etc., to refer to the "older E-Class" would not be bad. |
Exactly! I don't know which Star model it is, as he doesn't disclose that information, no matter  . NA,Gehörlose wie ich können auch Schrauben! Ihr HĂRT ich FĂHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 04-10-2026, 19:46.
09-07-2015, 11:54 Subject: Professional Feather Replacement Service |
.... and that's exactly why I'm going to close this down now  . LG, Onkel BM
