klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
01-07-2015, 11:09 Subject: |
Pin removed from MSTG and connected to the OBD connector, so only one cable is present from the K-line. Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
Wiesel Profi-Schrauber
Joined: 04/06/2008 Posts: 896 Karma: +43 / -0 Location: Schleswig-Holstein
01-07-2015, 11:48 Subject: |
And yet, no communication?!
What voltage do you have on the K-line? Should (measured at the neutral point) be approximately the mains voltage. Touran 5T1 / DFGA / TGV; Fabia 6Y5 / BNV / GGV
Joined: 04/12/2002 Posts: 18139 Karma: +805 / -0 Location: St.Gallen 2018 Volkswagen T6
01-07-2015, 11:59 Subject: |
Was wurde kürzlich dem Steuergerät hinzugefügt? Caution, first heed Wiesel's advice and don't immediately try to fix it.
Profile PM WWW Garage |
01-07-2015, 13:02 Subject: |
Voltage (Ignition ON) on MSTG K-line to ground (Battery) 6.6V, also on the positive side as well.
Turn off ignition, 0V to ground, 12V to positive.
Voltage buildup at the potential divider towards ground 11.8V, to positive 0.89V ignition on.
Turn off ignition, to ground 10.8V and to positive 2.8V
K-line from MSTG is still stuck.
Unfortunately, I had opened the engine control unit 30 minutes before Rainer's response. It is dry and there are no visible damage or cold solder joints. Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
01-07-2015, 13:16 Subject: |
Quote: | | K-line to ground (battery), also on the positive line. |
There should be 12.x V!
01-07-2015, 13:59 Subject: |
At least on Plus.
I just measured a bare MSA15 and it gives the following result on
Pin 61 also only 8.2V. Touran 5T1 / DFGA / TGV; Fabia 6Y5 / BNV / GGV
01-07-2015, 14:42 Subject: |
12,xV, I only get this reading with a properly connected diagnostic cable. When I disconnect it, it drops back to 6.6V. Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
03-07-2015, 15:45 Subject: |
I tried the control unit in another bus, but it didn't work.
I've sent it off for the exam today and hopefully for a successful repair.
Greetings Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
dieselschrauber likes this. |
09-07-2015, 16:30 Subject: |
Hi there,
The control unit arrived today again.
I've quickly installed it as a temporary fix, and lo and behold, it's working again.
According to the information, the control unit had been activated and then had malfunctioned, resulting in a large number of errors, including a quantity control unit, etc.
Thank you for your help. Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
09-07-2015, 16:49 Subject: |
Interesting... and thank you for the feedback  LG, Onkel BM
