P0672 / P0673 elektrischer Fehler im Stromkreis, GlĂŒhkerzen? | Posts 32+
Go to page: Previous  1, 2, 3
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
Post03-06-2015, 19:18    Subject: Quote
I hope for a little more understanding from the insurance company.
...you might have to wait a long time for that. Purely speculatively, they won't agree to anything... there's no reason for them to.
The icon_biggrin.gif must determine the extent of the damage in order for any basis for negotiation to exist.
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
Translated on 25-08-2026, 21:44.
yaya
Post08-06-2015, 21:27    Subject: Quote
Okay, let's move on towards a diagnosis.
Attached is the MWB 13-18-23 report. In addition, there is the error memory of the engine control unit.
MWB_13_18_23.csv
 Logfile. Markierungen sind jeweils VOR dem Anfahren gesetzt worden
 File name:  MWB_13_18_23.csv
 File size:  41.65 KB
 Downloaded:  433 times
MWB_13_18_23.pdf
 Fehlerspeicher
Fehlerspeicher
 File name:  MWB_13_18_23.pdf
 File size:  31.6 KB
 Downloaded:  688 times
Translated on 25-08-2026, 21:45.
Post08-06-2015, 22:04    Subject: Quote
I would remove the PD element from cylinder 4, visually inspect the seats and seals, and then swap it with a different cylinder (using new gasket sets).
After that, check if the problem is related to the misfire or the high idle speed. If it is, obtain a different pressure sensor, install it with a new gasket, and observe.
yaya
Post08-06-2015, 22:25    Subject: Quote
dieselschrauber wrote:
I would remove the PD element from cylinder 4, visually inspect the seats and seals, and then exchange it with a different cylinder (using new gasket sets).
Best regards, Rainer
You wrote down my plan icon_wink.gif.
It's tentatively scheduled for Friday, pending the arrival of the ultrasonic cleaner.
Translated on 25-08-2026, 21:46.
Post09-06-2015, 7:37    Subject: Quote
I wouldn't expect too much from the ultrasonic cleaner. You'll need the right cleaning solution and a lot of time...
Translated on 25-08-2026, 21:47.
yaya
Post09-06-2015, 15:13    Subject: Quote
I have the time, and I can get the right cleaner at the icon_smile.gif (please correct me if that's not correct...).
I will definitely clean the injectors, as they have been in use for over 120,000 kilometers since the last cleaning.
There is still an update regarding the insurance. They will pay according to the cost estimate icon_wink.gif.
Translated on 25-08-2026, 21:48.
Post09-06-2015, 22:48    Subject: Quote
Then make sure that the icon_smile.gif also complies with the KV.
My skeptical, experience-honed eyes read the subordinate clause "additional costs may arise" in that sentence.
With fictitious billing, there is no VAT (at least this is the case with comprehensive insurance claims) - this is another point that should not be overlooked.
Translated on 25-08-2026, 21:49.
yaya
Post10-06-2015, 9:20    Subject: Quote
That shouldn't be a problem, I will have the amount paid out icon_smile.gif.
But thank you for the information, it might help warn others.
Translated on 25-08-2026, 21:50.
Post10-06-2015, 9:48    Subject: Quote
Could you please let us know whether the price is net or gross?
Thank you.
yaya
Post10-06-2015, 9:55    Subject: Quote
Thank you.
It always results in a net amount, as it is legally regulated.
I was also informed that this doesn't change, even if you, like me, have your residence abroad.
Translated on 25-08-2026, 21:51.
yaya
Post23-07-2015, 11:26    Subject: Quote
There is news icon_wink.gif.
- Insurance has been paid.
- Ultrasonic cleaner acquired.
- Cleaning solution obtained.
- 4 sets of seals obtained.
Result: It's working again!
I would like to thank everyone who took the time and effort to share their ideas with me.
 EinspritzdĂŒsen Vorher - Nachher
 File size:  2.53 MB
 Viewed:  826 times
 Steckplatz dreckig
 File size:  1.94 MB
 Viewed:  963 times
 Steckplatz sauber
 File size:  2 MB
 Viewed:  833 times
 MWB 13, 18 & 23 nach der Reparatur
 File size:  39 KB
 Viewed:  1077 times
LOG-MWB-013-018-023_repariert.csv
 Logfile ĂŒber die Masswertblöcke bei einer kurzen Testfahrt
 File name:  LOG-MWB-013-018-023_repariert.csv
 File size:  37.64 KB
 Downloaded:  368 times
Translated on 25-08-2026, 21:52.
Post23-07-2015, 13:48    Subject: Quote
The idle noise regulation looks good (the values are only meaningful when idling), hopefully the ultrasonic cleaning has made a difference. I'm a bit skeptical based on my experience. icon_wink.gif
Unfortunately, your engine control unit doesn't have a data block that includes the lambda value (and doesn't even have an oxygen sensor). This value would have been interesting at full throttle and between 1200-4500 rpm: If the fuel injectors were clogged, the lambda value would likely be relatively high.
However, in most cases, the BKD injectors are unlikely to clog.
Translated on 25-08-2026, 21:53.
yaya
Post23-07-2015, 13:51    Subject: Quote
Hello Rainer,
"Thank you - yes, the idle speed control was measured at idle -> the values are correct."
Is the lambda sensor part number MWB 040, or what?
I can check that out and post it here sometime soon.
Translated on 25-08-2026, 21:54.
Post23-07-2015, 16:04    Subject: Quote
As previously mentioned, the BKD does not have a lambda sensor.
If such a value appears in a vehicle's diagnostic data, it is calculated based on air mass and fuel injection volume and provides no information whatsoever about whether any injectors are faulty or not.
yaya
Post23-07-2015, 16:37    Subject: Quote
Okay, that's good input.
While the BKD engine is not particularly prone to coking, in this case, we also have a combination of incorrect fueling and 30-40,000 icon_wink.gif.
Translated on 25-08-2026, 21:55.
No new posts P0674: Glow Plug Circuit Fault, Cylinder 4 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Motor: Circuit Fault (P2100) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Intake Air Temp Sensor P0110: Causes & Fixes General Tips
No new posts Polo Glow Plug Error: Get Help Now! Diesel Engine Technology
No new posts Lambda sensor control (electrical) (Fault in the electric... On-Board Diagnostics (OBD)
No new posts PD Unit Power Issues: Troubleshooting Stuttering On-Board Diagnostics (OBD)
No new posts Passat 3 BG 1.6 electric radiator fan Electrical Systems, Vehicle Electronics, Multimedia
