unruhiger Polo 6R in schnellen BAB-Kurven | Posts 16+
Go to page: Previous  1, 2
Post27-07-2015, 17:37    Subject: Quote
Then you've unfortunately ended up with a very unfortunate combination of tire and axle.
This proves that the soft tire counteracts the hard axle. Therefore, you should also use a normal hard axle with your "standard" tires icon_wink.gif.
It's clear that running at high pressure generally isn't as stable, simply because the contact area is somewhat smaller.
In my case, it was only about absorbing the lateral forces that occur during an autocross event.
Translated on 30-07-2026, 18:53.
No new posts AHF MKB: Troubleshooting Idle Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Noise: Causes and Solutions Diesel Engine Technology
No new posts VA Noise When Braking in Curves Transmission, Chassis, Body & Interior
No new posts Audi A6 Avant: Humming Noise When Turning Diesel Engine Technology
No new posts AHU: Idle Speed Issues Diesel Engine Technology
