Candle image glow plugs
pax
Avatar-pax
2000 Volkswagen Passat
Post23-08-2015, 17:18    Subject: Candle image glow plugs Quote
I removed the glow plugs from my spare engine (PD TDI). Unfortunately, I can't find much information about glow plug deposits. What happened to the bottom glow plug? Is it related to coolant injection?
Bye.
peace
 File size:  162.25 KB
 Viewed:  1177 times
Translated on 13-07-2026, 17:09.
Post23-08-2015, 18:11    Subject: Candle image glow plugs Quote
Have you ever made the glow plug glow while the engine was disassembled? Perhaps that will answer your question.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 13-07-2026, 17:10.
mullemaus
Post23-08-2015, 18:33    Subject: Candle image glow plugs Quote
Have you ever made the GK glow while it's disassembled? Perhaps your question is already answered then.
I bet that 2 or 3 of them don't glow at all, or they glow really badly. And the one that supposedly has water injection is the one that works best. icon_wink.gif
Translated on 13-07-2026, 17:11.
DieselBär30x
Avatar-DieselBär30x
Post23-08-2015, 18:36    Subject: Candle image glow plugs Quote
Hello everyone!
One more note outside of the question:
From GSK No. 1, the seat was not sealed icon_exclaim.gif.
Please take a closer look at the sealing surface in the ZK (presumably referring to a component), as it appears to be damaged.
Best regards from Munich!
pax
Avatar-pax
Post23-08-2015, 19:14    Subject: Candle image glow plugs Quote
Okay, thanks. I'll try to ignite it next time.
Regarding the comment about a leaky valve seat, I have to admit I'm not knowledgeable about that - it seems the sealing is done with the cone at the bottom of the stem, between the thread and the glow plug tip, rather than with the thread itself? However, I also ran the engine several times with loose spark plugs. It's possible that some grime got lodged in there during those runs.
Bye.
peace
Translated on 13-07-2026, 17:13.
DieselBär30x
Avatar-DieselBär30x
Post23-08-2015, 19:42    Subject: Candle image glow plugs Quote
pax wrote:
...gedichtet wird wohl mit dem Konus unten am Schaft zwischen Gewinde und GlĂźhspitze und nicht mit dem Gewinde? ...
Correct. A thread alone cannot provide a seal.
And you can clearly see that the candle has already burned down, especially at the base of the GSK (presumably a piece of equipment), where it is exposed/was exposed.
Translated on 13-07-2026, 17:14.
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Spark plug firing order Technical Data
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow Plugs 1Z - Buy Online Now! Diesel Engine Technology
No new posts Ablagerungen an GlĂźhkerzen Diesel Engine Technology
No new posts BPP 2.7 TDI 6 Glow Plugs Defective? Diesel Engine Technology
No new posts Glow Plug Replacement 1.9 TDI AVF Diesel Engine Technology
