T5, Multivan: Turbocharger pressure control, regulation limit exceeded
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
stolley
Karma: +38 / -1   Thank you, like it!
Post07-07-2015, 21:39    Subject: T5, Multivan: Turbocharger pressure control, regulation limit exceeded Quote
Hello everyone!
On Sunday, we were driving on the highway in our T5. It was very warm, and I was just about to press the accelerator a bit harder at the beginning of an incline when the preheating light suddenly started to blink.
After restarting the engine, the error message disappeared.
At home, I connected VCDS and read the memory.
Here's the translation:
"This is what came out."
Monday, July 6, 2015, 01:43:21:25065
VCDS -- A Windows-based VAG/VAS emulator.
VCDS Version: RKS 14.10.2.0
Data as of: 20150412.
Vehicle Identification Number: WV2ZZZ7HZ8H10xxxx License plate:
Mileage: 151,800 km. Repair order: Faulty turbocharger pressure regulation.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 7H (7HM - T5 Multivan)
Scan: 01 02 03 08 09 15 17 18 19 37 45 46 56 77
Vehicle Identification Number: WV2ZZZ7HZ8H10xxxx Mileage: 151,800 km
"Der schnelle braune Fuchs springt ĂŒber den faulen Hund."
Address 01: Engine Control Module
Label file: DRV\070-906-016-BPC.clb
Part number SW: 070 906 016 DR Hardware number: 070 906 016 DR
Part: R5 2.5L EDC G000AG 1584
Revision: --H06--- Serial Number: VWZ7Z0G6131852
Encoding: 0001075
Operating number: WSC 30696 264 83473
VCID: 63C39824A134513913D-515A
"1 error found:"
000665 - Charge pressure control.
P0299 - 000 - Control limit exceeded - Intermittent.
Environmental conditions:
Error status: 00110000
Error priority: 1.
Error frequency: 1
Lost Counter: 255
Mileage: 151,565 km
Time: 0
Speed: 2352 RPM
Speed: 96.0 km/h
Last: 71.4%
Voltage: 13.91 V
Binary value: 00101000
Pressure: 2376.6 mbar
Pressure: 1907.4 mbar.
Readiness: 0 0 0 0 0
Could someone explain what this error message means?
Can I safely ignore this? Or should I expect the turbocharger to fail gradually? Should I go for a gymnastics class again?
Sure, no problem!
Volker.
Post08-07-2015, 8:55    Subject: T5, Multivan: Turbocharger pressure control, regulation limit exceeded Quote
Or should I do some gymnastics again?
The environmental conditions are "Pressure: 2376.6 mbar" (setpoint) and "Pressure: 1907.4 mbar" (actual value) for the boost pressure.
Check the charge air cooler system for leaks, and also verify that the control of the variable turbine geometry (VTG) on the turbocharger functions correctly throughout its entire range of motion (actuator test).
Post08-07-2015, 11:36    Subject: T5, Multivan: Turbocharger pressure control, regulation limit exceeded Quote
Um... based on my interpretation, the boost pressure was too low. If that is the case, the vacuum system should also be checked for leaks.
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
Post08-07-2015, 12:06    Subject: T5, Multivan: Turbocharger pressure control, regulation limit exceeded Quote
Autoservice wrote:
Um... according to my interpretation, the boost pressure was too low. If that is the case, one should also check the vacuum system for leaks.
stolley
Post08-07-2015, 21:34    Subject: T5, Multivan: Turbocharger pressure control, regulation limit exceeded Quote
Hello you two!
Thank you for the tips.
I'm going to try doing things this way soon.
Volker.
Post08-07-2015, 21:38    Subject: T5, Multivan: Turbocharger pressure control, regulation limit exceeded Quote
Please also check the measurement block 11 from the engine control unit to see what the boost pressure setpoint and actual value do at full throttle. icon_idea.gif
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post08-07-2015, 22:04    Subject: T5, Multivan: Turbocharger pressure control, regulation limit exceeded Quote
The T5 also has these quick-release fasteners on the intercooler pipes; check the clearance there.
It's not that they detach from the mating parts under heavy load.
stolley
Post10-08-2015, 17:14    Subject: T5, Multivan: Turbocharger pressure control, regulation limit exceeded Quote
Regards
Thank you for the tip!
I'll check that out!
stolley
Post18-08-2015, 16:45    Subject: T5, Multivan: Turbocharger pressure control, regulation limit exceeded Quote
Here's the video again!
Could the wobble/play be responsible for the pressure loss?
Or is this connection always so unstable?
T5, Multivan: Turbocharger pressure control, regulation limit exceeded - video.mp4
 T5 TDI Verbindungen LadedruckschlĂ€che - zu lose?
 File size:  710.83 KB
 Viewed:  4717 times
Post24-08-2015, 13:20    Subject: T5, Multivan: Turbocharger pressure control, regulation limit exceeded Quote
It looks unstable, and over time, this instability will wear down the sealing ring of the connection.
-> Disassemble, check the sealing ring. An O-ring used as additional mechanical support on the mating surface can prevent "loosening" or "shifting" damage.
The best way to check if everything is airtight is to pressurize the charge air system: Seal the ends with appropriate caps and apply approximately 1 bar of pressure.
Caution: Be careful to prevent the plugs from being ejected (risk of injury).
See also:
Problemi
2013 Volkswagen Passat
Post04-09-2015, 17:50    Subject: T5, Multivan: Turbocharger pressure control, regulation limit exceeded Quote
This error occurs very frequently with broken or defective DPFs!
Please also check this. Remove the exhaust pipe after the DPF and check the filter at the outlet.
No new posts Boost pressure control exceeded 3.0 bar, P0299 code / rou... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0299 Error: Boost Control System Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Boost Pressure Limit Reached (BLS) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0299: Load Pressure Control - Control Limit Undershot Diesel Engine Technology
No new posts Boost pressure control, regulation limit exceeded (low) Gasoline Engine Technology
No new posts AUY: Limit Breached, Below Threshold Diesel Engine Technology
No new posts A3 BKD, boost pressure regulation limit exceeded Diesel Engine Technology
