Fabia 1,2 BMD Gemisch zu fett | Posts 16+
Go to page: Previous  1, 2
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Gasoline Engine Technology
turrican944
Post06-10-2015, 12:59    Subject: Quote
Yes, there is such a repair kit, but it now costs a mere 1800€, and that is not really worth it for the car. That should last around 140,000 km, and if it lasts another 100,000 km after the repair, we'll be very satisfied.
The repair cost includes the cat, a new cylinder head, and the cylinder head, and for what you're getting, 1800€ doesn't seem that bad at all. But it will soon exceed the value of the car itself.
Octavia 1Z2.0 TDI 4x4 2008
Porsche 944S3 1986
Back to top Profile PM Email
turrican944
Post11-10-2015, 10:44    Subject: Quote
Yesterday I reassembled the box again, and now it's working perfectly again.
Although the MKL was still running when starting and shutting down yesterday, I didn't have my VCDS device with me to clear the memory once. I didn't feel like taking a test drive yesterday evening.
We also replaced the timing chain, which was probably overdue. The old chain could be removed from the sprocket after one of the guide rails was removed, but the new chain also wouldn't go on the wheel without both rails, so the wheel had to be removed and the chain reattached to the crankshaft. She must have been a bit tired after all.
Anyway, the engine is now running much smoother at idle than before, and I hope that the check engine light will also turn off after the error memory is cleared.
Porsche 944S3 1986
No new posts P0171 Fuel System Bank 1 Lean Mixture Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code P2178 - Engine running too lean Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N / Ibiza 6L / Fabia 2: Generator does not charge Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diesel-Gasoline Mixture in PD? Diesel Engine Technology
No new posts Signal too slow, signal too fat 3.0 TDI CTBA Diesel Engine Technology
No new posts EDS im Fabia RS On-Board Diagnostics (OBD)
No new posts Fabia RS ASZ: Parts for 2001-2011 Models Upload
