1Z Motor Audi 80 B4 Motor sparsamer machen | Posts 16+
Go to page: Previous  1, 2
kixx_ass
Post27-10-2015, 19:27    Subject: Quote
top, thanks.
"da fehlt das "nicht" in meinem satz."
The CEO should not have that.
Wow. 0,5 l is already impressive!
Audi S2 QP
Sokda Superb 3T
Karma: +1344 / -0   Thank you, like it!
dieselschrauber likes this.
Post27-10-2015, 20:15    Subject: Quote
This only makes sense for a pump with a sophisticated spray adjustment, and is actually just a temporary fix. The spray adjustment is no longer stable. That pump needs to be replaced.
I have set the ESP on my 1Z to the latest setting, with the desired effect of a smooth idle. For EZP, I start early at high load, which provides a reserve, as shown in the FA. Interestingly, this also resulted in the lowest consumption.
Since there is ample room for thorough and lengthy debate here, my suggestion: Measure the engine's idle speed and performance under partial load at 1800 min-1 under identical conditions both before and after the recommended early adjustment. Then we know it.
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts Audi A2 to A6, Engine Area, Generosity Policy Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW AFN Motor in Audi 80 TDI Diesel Engine Technology
No new posts Oil in Coolant: Audi 1Z Engine Problems Diesel Engine Technology
No new posts Audi 80 B4: Knocking Z1 Engine - Diagnosis & Repair On-Board Diagnostics (OBD)
No new posts Audi C4 Engine Control Label File: V6 (12V) AAH On-Board Diagnostics (OBD)
