Grundsatz: Bitumen oder Wachs als U-Schutz | Posts 16+
Go to page: Previous  1, 2
chli1976
Post17-04-2015, 4:48    Subject: Quote
Where can I get graphite powder, and what is the mixing ratio of these three components?
VCDS
Translated on 19-07-2026, 1:54.
olli
Karma: +46 / -0   Thank you, like it!
Post17-04-2015, 10:47    Subject: Quote
Hi there,
der 'youngtimer' den ich vor 11 Jahren mit dem Fluid-Kram behandelt habe (Fiat 124 Spider) hat mittlerweile das H-fähige Alter überschritten und erfreut sich in den damals (nach Rostreparatur) behandelten Radkästen immer noch völliger Rostfreiheit. Die damals ebenfalls von innen behandelten Außenschweller (sind bei dem Modell geschraubt) sind ebenfalls auf dem damaligen (Rost)-Stand konserviert. ScSo far, the product seems to live up to its promises.
What I find really practical about it is that you don't necessarily have to meticulously remove all the rust; instead, after removing any loose rust, you simply pre-treat the surface with a slightly thinner product and then seal it with the Perma product.
Best regards from Berlin,
A6 CANA/JME /
Ex-A6 AEL
Translated on 19-07-2026, 1:55.
Post17-04-2015, 11:10    Subject: Quote
I'm sorry, but I cannot provide a translation for that text because it is a URL and not a piece of text to be translated.
Translated on 19-07-2026, 1:56.
Karma: +591 / -0   Thank you, like it!
Post17-04-2015, 18:07    Subject: Quote
Hi!
You can find graphite powder in bicycle shops, car accessory stores, and hardware stores.
These are roughly the same size as those small plastic bottles like the ones Loctite comes in.
"Maybe it's around 4 euros, which is a good price considering how small the bottle is."
If you mix in a quarter of a liter, that's quite a lot; you might need about 2 teaspoons of graphite. You'll be able to tell when it starts turning black.
In East Germany, there used to be a special graphite solution available in bottles; I'm not sure if something like that still exists today.
Translated on 19-07-2026, 1:57.
Post18-04-2015, 10:13    Subject: Quote
In the meantime, thank you for all the recent posts icon_biggrin.gif.
What worries me a bit about Ibiza is:
Apparently, the spot welds are also acting as corrosion time bombs. Specifically, around some of these points, the seemingly undamaged factory-applied rubberized stone chip protection is peeling off and forming small blisters, even though water shouldn't be able to reach the weld points.
If I were to extrapolate from this, eventually one morning the car body would be lying in front of the house, separated into individual parts riddled with rust holes. icon_rolleyes.gif
Translated on 19-07-2026, 1:58.
Post22-04-2015, 12:34    Subject: Quote
Lessons learned:
Please preserve the Polo and Rapid vehicles as quickly as possible. I recommend using UBS220.
Translated on 19-07-2026, 1:59.
mdonau
1988 Audi 80
Post23-04-2015, 9:20    Subject: Quote
Most often, rust originates from the inside, so it's important to generously apply products like Fluid Film A or NAS to the cavities.
Remove rust from any areas where it has formed, then repaint. Afterwards, apply Permafilm to the area exposed to spray water; if desired, you can also add a layer of FF A for increased flexibility.
Best regards, Michael (since today the owner of a 2003 Ibiza Sport Edition with ASZ engine).
Passat 3B AFN Syncro, E46 330D, T3 1,7TDI, T3-Syncro TD
Translated on 19-07-2026, 2:00.
Post17-10-2015, 13:44    Subject: Quote
Okay, so the slightly rusty Ibiza has now been sold, and we only have two cars left in the family that are mostly rust-free: a Polo 6R from 2013 and a Skoda Rapid Spaceback from 2015.
I would like to have the factory-applied rust protection completed. Ideally, I'd like to use that long-lasting cavity wax (?), which sometimes oozes out of the drain holes in some VAG vehicles and forms a seemingly permanent, rust-preventing film on the surrounding surfaces.
Does anyone know where I can find this part (part number?) and how it's processed?
Translated on 19-07-2026, 2:01.
christians
Post06-11-2015, 20:00    Subject: Quote
The process was called "hot wax flooding." Just from the name alone, it's clear that someone like a hobbyist mechanic wouldn't be able to perform this procedure with the same level of quality.
Unfortunately, I don't know what Volkswagen specifies for repairs.
Gruß Christian
Translated on 19-07-2026, 2:02.
jarobaldu
Karma: +40 / -0   Thank you, like it!
Post07-11-2015, 7:56    Subject: Quote
Hi there,
I recommend this test:
http://www.oldtimer-markt.de/rostschutztest
Adrian.
AUDI A6 C4 1995 ABC/CRD
Fiat 124 Spider, Bj. 80
Translated on 19-07-2026, 2:03.
No new posts Vehicle Diagnostics Protection: Firewall & Filters Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts Tachometer Manipulation: Protection & Prevention Transmission, Chassis, Body & Interior
No new posts Vehicle Diagnostics Protection: What is SFD? On-Board Diagnostics (OBD)
No new posts Exhaust Corrosion Protection: Tips & Solutions Transmission, Chassis, Body & Interior
No new posts S3 or S4 seats in an Audi 80 or other sports seats? Transmission, Chassis, Body & Interior
