DSG transmission enters limp mode at oil temperatures above 70°C
binford
Avatar-binford
Post07-11-2015, 14:13    Subject: DSG transmission enters limp mode at oil temperatures above 70°C Quote
Hello everyone.
"I'm getting the following error message as soon as the transmission exceeds a temperature of approximately 65..70°C. To provide some background, the car was involved in a minor accident, and the transmission cover was dented by about 3...4 mm. The circuit board/contact plate of the mechatronic valves was slightly bent, but the rest "appears" to be fine. When the transmission is cold, it runs perfectly." The other errors can be ignored
Code:
Samstag,07,November,2015,14:02:23:49048
VCDS Version RKS 15.7.1 Läuft mit Windows 7 x64(VMWare)
                Adresse 02: Getriebe       Labeldatei: DRV\0D9-927-770.clb
   Steuergerät-Teilenummer: 0D9 300 012 J    HW: 02E 927 770 AQ
  Bauteil und/oder Version: DQ250-6A MQB  H53 4517
                 Codierung: 0014
            Betriebsnummer: WSC 04742 780 00200
              ASAM Datensatz: EV_TCMDQ250021 001001 (AU37)
                       ROD: EV_TCMDQ250021_AU37.rod
                      VCID: 1D1E837C0C0E56D656-8049
2 Fehlercodes gefunden:
10739 - Ventil 3 im Teilgetriebe 1
          P174A 00 [200] - elektrischer Fehler
          Warnleuchte EIN - Sporadisch - bestätigt - geprüft seit letzter Löschung
             Umgebungsbedingungen:
                    Fehlerstatus: 00000001
                    Fehlerpriorität: 0
                    Fehlerhäufigkeit: 3
                    Kilometerstand: 5555 km
                    Datum: 2015.11.07
                    Zeit: 04:35:59
10763 - Anlasserfreigabe von der Wählhebelsensorik
          P1734 00 [002] - -
          Sporadisch - unbestätigt - geprüft seit letzter Löschung
Mileage: only 5,500 km. 6-speed DSG transmission from an A3.
Thank you for your responses.
Log-WAUZZZ8V0FA044856-5555km.txt
 File name:  Log-WAUZZZ8V0FA044856-5555km.txt
 File size:  13 KB
 Downloaded:  1799 times
Post08-11-2015, 11:45    Subject: DSG transmission enters limp mode at oil temperatures above 70°C Quote
Unfortunately, hairline cracks in electronic components often become noticeable due to temperature changes. Varying temperatures cause components made of different materials to expand at different rates, which results in tiny shifts in their position. If a contact or a conductive trace is not 100% functional, it can cause interruptions or short circuits, depending on the nature of the damage.
It might be possible to remove the transmission cover with the transmission still installed. Should replacement parts be sourced from a similar, used gearbox?
No new posts Doku Touareg, Transmission in Emergency Mode Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
No new posts Oil Temperature: How to Check & Optimize Diesel Engine Technology
No new posts Oil Temperature Gauge: Add-on Instrument Diesel Engine Technology
No new posts Oil Temperature: Where to Measure It? Diesel Engine Technology
No new posts Oil temperature sensor Diesel Engine Technology
