Warmstart 5Zyl TDi (AEL) problematisch | Posts 16+
Go to page: Previous  1, 2
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
RĂŒdi
Post02-09-2015, 10:24    Subject: Quote
I haven't noticed any difference; the AFN runs perfectly with both encodings.
DieselBĂ€r30x
Avatar-DieselBĂ€r30x
Post02-09-2015, 11:43    Subject: Quote
Hello everyone!
RĂŒdi wrote:
I haven't noticed any difference; AFN runs perfectly with both encodings.
...I can also NOT confirm this, but rather:
roorback wrote:
The automatic transmission was significantly slower and also seemed to create some "slippage" during gear changes - making it really difficult to drive. ...
Has, however, now dealt with the topic m. E. not much left to do, however, the changed driving behavior in the coding for automatic transmission is also logically sound icon_wink.gif
This starts with the non-evaluated clutch switch (which then explains the strange "intermittent gas" and, in fact, the delayed clutch engagement), and stops when a strongly non-linear gas pedal evaluation is performed.
@RudiViewing profile: Rudi, I have no idea what dataset you're working with and what you've actually coded icon_wink.gif. All-wheel drive would also be codable, perhaps you've already figured that out?
Best regards from Munich!
1. S.verlÀngerung: Audi A4 Avant quattro, 1,9 TDi MKB: AFN, BJ98, Vollausstattung, +VP1L
RĂŒdi
Post03-09-2015, 13:02    Subject: Quote
On the Ford Galaxy TDI with AFN engine, there is no coding for all-wheel drive.
That was the code I created 2 years ago:
Engine Control Unit Coding (Engine Code AFN)
STG 01 (Engine Electronics) Selection
STG Encoding -> Function 07
00001 - Automatic Transmissions
00002 - Manual Transmission
From 00002 to 00001 and, as I said, the driving behavior has not changed at all.
DieselBĂ€r30x
Post03-09-2015, 14:24    Subject: Quote
Tip: Why not try it again with your two vehicles from your signature, if they are AFN vehicles.
That actually seems to depend on the specific MStGe-T.-number that has been installed, and whether and what can be encoded here. B.:
00001 Automatic (AG)
00002 Gearbox (SG)
00003 SG All-Wheel Drive (SG)
Post03-09-2015, 14:42    Subject: Quote
However, it seems that this actually depends on the specific MStGe-T.-number, whether and what can be encoded here
Possible encodings see Tooltip (information bubble) when you hover your mouse over the corresponding input field.
In my A3 8L with AHF engine, I once coded the control unit for automatic mode as a test, but I didn't notice any difference compared to the manual transmission version.
Therefore, it also depends on the specific control unit here whether other variants behave noticeably differently.
Best regards, Rainer
roorback
Karma: +1 / -2   Thank you, like it!
Post24-09-2015, 7:16    Subject: Quote
vwSchrauber wrote:
Take a look at the locking screw on the high-pressure part. Depending on the extent of the damage, you may only experience issues with warm starts, or also cold starts (valve adjustment).
I've already had several pumps with this problem.
See the image in the attachment!
Screw and O-ring number available upon request... costs around 15€;
Hello VWSchrauber
Since I had to seal my pump yesterday, I also took a look at {THAT}. It's a mystery to me how I managed to remove the screws on the pumps that I have already repaired (on my workbench) - while it was installed, I had no idea (since I didn't have the 3-sided nut). However, I can already organize the tool – but first, I would like to obtain the aforementioned spare parts, therefore my request – to obtain the spare part numbers that I need beforehand, and then open
THANKS
Best regards, Uwe
vwSchrauber
Post30-09-2015, 16:53    Subject: Quote
here are the part numbers (Bosch ET- numbers)
Closure screw: F 002 D12 533
O-ring: 1 460 210 349
EDIT: You can get Dreikantnuss and other products either from dieselkontor.de (only for commercial use). (Customers) or at various e-bay sellers.
roorback
Post01-10-2015, 10:26    Subject: Quote
Thank you very much for the information.
I have already organized the tools - I will order the materials in the coming days.
I will share my experience later.
Greetings
roorback
dieselschrauber likes this.
Post10-11-2015, 10:21    Subject: Quote
Hello
would like to post a completion report.
So, I've ordered the part along with the seal - and I've also replaced it. However, I couldn't really see a significant visual difference in the older part.
Exactly the same applies regarding starting behavior - when it's warm, it simply needs 2-3 more turns. Strange - but essentially a "luxury problem" - it actually starts up perfectly fine every time!
Thank you.
Best regards, Uwe
No new posts Engine Revs High After Warm Start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR in USA auch problematisch? Diesel Engine Technology
No new posts Glass Roof Installation: Problems & Solutions Transmission, Chassis, Body & Interior
No new posts Mercedes 124 Glow Plugs Replacement (1990) Diesel Engine Technology
No new posts Chiptuning 2.5l 5Zyl.103KW - wer hat Erfahrung? Diesel Engine Technology
