Register the tow hitch on the vehicle's system, Audi A6 4G | Posts 16+
Go to page: Previous  1, 2
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
amishorty
Karma: +9 / -1   Thank you, like it!
2004 Volkswagen Passat
dieselschrauber and Steffen W likes this.
Post24-11-2015, 21:55    Subject: Register the tow hitch on the vehicle's system, Audi A6 4G Quote
Hello Rainer,
Everything worked out.
I figured out how the encoding works at address 19 using the assistant.
Okay, everything was encoded, confirmed, and the AHK symbol in the circuit breaker panel was switched off.
Then, register the trailer hitch control module (STG) under address 69. Ready.
However, I had to specifically program one thing: the air suspension for the rear axle, because it needs to react when there is a load on the trailer hitch.
Under address 34, I changed the coding using the assistant, so that the suspension can now react to clutch load.
Now, you can also turn the AHK (Automated Hotkey) "ON" and "OFF" using the media screen.
It was quite a challenging experience without much prior knowledge. However, if you are careful and test it thoroughly, it can work.
I'm glad that it's working properly now.
Thank you again for your assistance.
Michi.
Post24-11-2015, 22:08    Subject: Register the tow hitch on the vehicle's system, Audi A6 4G Quote
Hallelujah icon_cool.gif When it comes to 4G, there are definitely potential pitfalls depending on the specific AHK (trailer hitch) set/control unit and the overall vehicle configuration.
The good thing is: you can do it now. The procedure is very similar across all VAG models, so it will be much faster next time with the next car!
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Towing Hitch Unlock: VW Golf 5 and Newer Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Trailer Hitch Registration with VAG-COM (Div. Steuergeräte) On-Board Diagnostics (OBD)
No new posts Audi A3 8V: Install Tow Hitch (Original) Electrical Systems, Vehicle Electronics, Multimedia
No new posts KDataScope Login Issues: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Tow Hitch for VW Golf IV Diesel Engine Technology
