Passat: Display Oil Temperature - 3BG V6 TDI
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
amishorty
Karma: +9 / -1   Thank you, like it!
2004 Volkswagen Passat
Post06-12-2015, 0:40    Subject: Passat: Display Oil Temperature - 3BG V6 TDI Quote
Hi everyone,
I would like to know if the oil temperature can be displayed on the screen.
With VCDS, the temperature can definitely be accessed.
Here are the details again:
VW Passat Variant 3BG, manufactured in 01/2004, 2.5 liter V6 engine, 132 kW, Vehicle Identification Number (VIN): WWW ZZZ 3BZ 4E27 4371.
All-wheel drive, 6-speed manual, 368,000 km.
Who can help?
I am grateful for any advice.
Michi.
Translated on 27-09-2026, 17:50.
Post06-12-2015, 8:33    Subject: Passat: Display Oil Temperature - 3BG V6 TDI Quote
Unfortunately, this is not possible without an additional module (e.g., FIS Control).
Translated on 27-09-2026, 17:51.
amishorty
Post06-12-2015, 14:05    Subject: Passat: Display Oil Temp - V6 TDI 132KW Quote
Hi Michael,
Can I install this optional module (FIS) and register it with the system accordingly?
and code, or isn't that available for the 3BG at all?
Michi.
Translated on 27-09-2026, 17:52.
Post06-12-2015, 14:53    Subject: Passat: Display Oil Temperature - 3BG V6 TDI Quote
No registration or coding is required; simply connect it correctly.
Actually, something just occurred to me: your Passat is a 2004 model, so it probably won't be a direct fit.
Do you have a multifunction display installed?
Translated on 27-09-2026, 17:53.
amishorty
Post06-12-2015, 15:49    Subject: Passat: Display Oil Temperature - 3BG V6 TDI Quote
Do you mean MFD as in Multifunction Display?
Is it the red light located between the speedometer and the tachometer?
If so, it's installed on my system.
Where can I get the add-on module, and what does it look like?
Do you have a picture of it?
Michi.
Post06-12-2015, 15:55    Subject: Passat: Display Oil Temperature - 3BG V6 TDI Quote
You can simply Google it; you'll find the distributor right away.
Translated on 27-09-2026, 17:54.
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A6 TDI: Adjusting Fuel Injection Timing Diesel Engine Technology
No new posts Injection Timing Display Diesel Engine Technology
No new posts DPF Regeneration: Display & Troubleshooting On-Board Diagnostics (OBD)
No new posts Display operating hours with VAG-COM? On-Board Diagnostics (OBD)
