kiesgrubenwilli
11-12-2015, 19:39 Subject: Audi Q7 Battery Drain: Causes & Fixes |
Hello chili1976,
Today, I used the search function to read your posts from December 2014 about a dead battery in an Audi A6 4F.
I seem to be experiencing the same problems with my Q7 and have almost identical measurement results as those you mentioned in your posts.
Unfortunately, this issue was not resolved.
I would like to know what results your research has yielded and what measures were taken to eliminate the problem.
Thank you in advance for your efforts.
Best regards, Willi.
Translated on 26-07-2026, 4:08.
chli1976 Profi-Schrauber
dieselschrauber likes this. |
12-12-2015, 9:37 Subject: Audi Q7 Battery Drain: Causes & Fixes |
I updated the MMI software. Since then, I haven't seen the "low battery" warning.
VCDS
Translated on 26-07-2026, 4:09.
kiesgrubenwilli
12-12-2015, 12:00 Subject: Audi Q7 Battery Drain: Causes & Fixes |
Hello chli1976,
Thank you for the quick response.
Did the complaint about the vehicle only relate to the display in the infotainment system (MMI), or did it also include the battery discharging?
Or has the update to the MMI also resolved the issue with the battery draining?
Translated on 26-07-2026, 4:10.
kiesgrubenwilli likes this. |
12-12-2015, 20:57 Subject: Audi Q7 Battery Drain: Causes & Fixes |
The complaint was that the car would not start every 3-4 days if it wasn't driven regularly. After the update, it works normally again. At least, there have been no further reports of the issue.
VCDS
Translated on 26-07-2026, 4:11.
