Variable valve timing malfunction (Solution)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » General Tips
MisterD
Post12-12-2015, 14:00    Subject: Variable valve timing malfunction Quote
Hello everyone,
Recently, the check engine light illuminated on the instrument panel. When the error memory was read, it indicated the fault code P0010: camshaft position timing - malfunction.
I deleted the error message, but it reappeared after the next restart.
The car isn't going into limp mode, but it feels weaker around the 2000 rpm range.
Engine code: CDAA, chip tuning for the last 30,000 km, total mileage approximately 120,000 km.
Should I take it to the workshop immediately, or are there any DIY solutions I can try?
Dennis.
You are not permitted to view these file(s), please log in or register for extended rights or status updates.
Translated on 18-07-2026, 6:47.
Post12-12-2015, 18:20    Subject: Variable valve timing malfunction Quote
According to my research, there was or is a free service campaign offered by Volkswagen regarding this issue.
I would first inquire with the icon_biggrin.gif to see if the vehicle is affected or was ever affected.
Translated on 18-07-2026, 6:49.
MisterD
Post12-12-2015, 20:47    Subject: Variable valve timing malfunction Quote
I did some research and came across the Audi campaign 15D6. It specifically affects my engine type and production year (05/09).
I did some troubleshooting on my own. I noticed that the N205 valve was not being activated during the actuator diagnosis. I looked into it more closely and immediately found the solution.
I'm not very confident that I will be able to get this replaced under warranty (see picture) icon_smile.gif.
Can I still drive with this? I have a long trip planned for next week, from Aachen and back. However, I'm not sure if I'll receive the part by then.
Greetings,
Dennis.
Translated on 18-07-2026, 6:50.
bloesch
Post14-12-2015, 6:45    Subject: Variable valve timing malfunction Quote
If your vehicle is affected by this issue, please take it to a service center and you will receive a new camshaft adjuster.
Why does it usually not matter to the workshop? / Because Audi pays - that's all that matters.
Translated on 18-07-2026, 6:51.
MisterD
dieselschrauber likes this.
Post14-12-2015, 14:01    Subject: Variable valve timing malfunction Quote
I called the Seat dealer earlier. According to the VIN, my vehicle is not affected.
The new solenoid valve has been installed, the vehicle is running normally again, and the error memory is clear. icon_smile.gif
Lucky me, only 20 euros for the replacement part.
Dennis.
Translated on 18-07-2026, 6:52.
Post14-12-2015, 15:30    Subject: Variable valve timing malfunction Quote
Lucky me, only 20€ for the spare part.
Humans need happiness... and thank you for the feedback icon_wink.gif.
Translated on 18-07-2026, 6:53.
Ratings - Variable valve timing malfunction
No new posts Central Locking Failure: A6 Doku 4B (10/2001) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P1405 - Exhaust Gas Recirculation (EGR) Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P2101 - Throttle Control Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF malfunction On-Board Diagnostics (OBD)
No new posts DPF Failure: A4 2.0 TDI CNHC Engine Diesel Engine Technology
No new posts CFWA - Diesel Particulate Filter Malfunction Diesel Engine Technology
New posts DPF Failure P2002: Volkswagen Touareg 7L 2.5 TDI Diesel Engine Technology
