Touareg 7P 2013 DWA System
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
VCDS-S
2013 Volkswagen Touareg
Post23-12-2015, 10:46    Subject: Touareg 7P 2013 DWA System Quote
Is there a way to permanently disable the Driver's Window Auto (DWA)? Perhaps even remove it from the configuration list? In my Audi A4 B7, I was able to permanently disable the RDK (Remote Diagnostic Key) through the configuration list because my summer tires didn't have sensors. I'd like to do something similar in my Touareg, as I often travel with my dog and I don't want to have to press the old switch in the door every time, or press the FFB (Front Bottom Button) twice... It's not about leaving the animal alone in the car for hours!
Translated on 03-10-2026, 9:16.
Post29-12-2015, 23:50    Subject: Touareg 7P 2013 DWA System Quote
I'm not sure how it works with the Touareg, but with other vehicles from the group, the alarm system was often offered in two versions: a basic version (without a tilt sensor and interior sensor) and a "DWA Plus" version (including both of the above).
Therefore, I assume that the interior sensor can be individually disabled via VCDS (it may be necessary to disconnect the connector of the IRUE to avoid an error message in the system).
Greetings.
Guste.
Translated on 03-10-2026, 9:18.
No new posts VW Caddy Tailgate 2004-2013 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Crafter, Year 2012/2013, High Standby Current Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Motion, Year 2013, Problems with ASR/ESP/ABS/Autohold Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Auxiliary heater fault memory Touareg 7P MJ 2013 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Battery problems, 6J Cupra, 2013 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Touareg GRA.... On-Board Diagnostics (OBD)
No new posts Touareg R50 V10 Diesel Engine Technology
