7D - Auxiliary heater malfunction
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
pschaefer
Post24-11-2011, 22:38    Subject: 7D - Auxiliary heater malfunction Quote
Code:
                Adresse 7D: Zuheizer       Labeldatei: RKS\1K0-963-235.lbl
   SteuergerĂ€t-Teilenummer: 1K0 963 235 E    HW: 1K0 963 235 E
  Bauteil und/oder Version: PTC-Element         0404
                 Codierung:
            Betriebsnummer: WSC 00000 000 00000
                      VCID: 2D5A8A1FCD81
1 Fehler gefunden:
00361 - Heizelement fĂŒr Zusatzheizung (Z35)
        014 - defekt
Does that mean the whole thing needs to be replaced for 305 euros, or are there other reasons?
I'm asking this question in such a silly way because the error only appeared after the battery was replaced after 5 and a half years... (of course, according to Murphy's Law, that part *must* have been fried, or something like that!?)
Pete.
*Die Fahrbahn ist ein graues Band, weisse Streifen, grĂŒner Rand*
pschaefer
Post25-11-2011, 11:21    Subject: 7D - Auxiliary heater malfunction Quote
Okay, regarding the actuator diagnosis, I can turn the PTC element on and off; it then draws power, and it also gets quite warm in the area icon_smile.gif ...
icon_question.gif Nevertheless, the error remains, and when attempting to delete it specifically in the control unit dialog, the message appears that I should contact Ross-Tech.
DieselBĂ€r30x
Avatar-DieselBĂ€r30x
Post25-11-2011, 11:49    Subject: 7D - Auxiliary heater malfunction Quote
Hi Pete!
What I'm noticing during the scan: No encoding is present, and the WSC value is set to 0000...
If you try to code it, what happens?
And one more tip: In VCDS, under "Settings," set your WSC (Write/Read Security Code) to something other than 0000. This often causes problems when coding, especially with certain types of security tokens.
Best regards from Munich!
1. S.verlÀngerung: Audi A4 Avant quattro, 1,9 TDi MKB: AFN, BJ98, Vollausstattung, +VP1L
pschaefer
Post25-11-2011, 21:36    Subject: 7D - Auxiliary heater malfunction Quote
Ugh... You can't just easily remove that part; it looks like you'd have to disassemble half the car to get to it – especially with these temperatures (in an unheated garage)! And all of this just because some poorly designed chip is acting up. There can't be that much broken if I can still communicate with it via CAN, all the data blocks are coming through, and it can still be turned on and off... icon_evil.gif icon_mad.gif
DieselBĂ€r30x
Post25-11-2011, 22:05    Subject: 7D - Auxiliary heater malfunction Quote
Hello again!
Post25-11-2011, 22:36    Subject: 7D - Auxiliary heater malfunction Quote
DieselBĂ€r30x wrote:
Hello again!
If coding is not possible on the control unit, then the WSC cannot be changed either.icon_wink.gif
DieselBĂ€r30x
Post25-11-2011, 23:07    Subject: 7D - Auxiliary heater malfunction Quote
...okay, there might be something to that...
You are right icon_cool.gif.
pschaefer
Post27-11-2011, 19:40    Subject: 7D - Auxiliary heater malfunction Quote
Unfortunately, there is no visible direct damage (such as a scorched component or similar).
Well, let's start with some chip identification and gradually get used to the idea of spending 305 euros...
 Kaum, dass man Haltegriffe, Aschenbecher, Verkleidung der Schaltkulisse, die komplette Mittelkonsole, die untere fahrerseitige Armaturenverkleidung und eine LuftfĂŒhrung entfernt hat, kann man das blöde Teil auch mal erblicken:
 File size:  3.43 MB
 Viewed:  11249 times
 Dann muss man nur noch unter WĂ€rmeeinwirkung und Dauerverformung zweier Kunststoffnasen das verklebte GehĂ€use öffnen und sieht das:
 File size:  3.26 MB
 Viewed:  27062 times
 Elektrischer Zuheizer
 File size:  3.39 MB
 Viewed:  14155 times
 File size:  3.51 MB
 Viewed:  14520 times
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post27-11-2011, 20:22    Subject: 7D - Auxiliary heater malfunction Quote
Did you only expand it because of the error? icon_rolleyes.gif Or did it not get warm inside anymore?
reflexsilber met.
pschaefer
Post27-11-2011, 20:46    Subject: 7D - Auxiliary heater malfunction Quote
RedR32 wrote:
Did you only take it apart because of the error?icon_rolleyes.gif Or did it stop getting warm inside?
The latter. I've been wondering for a while now that it sometimes gets quite warm very quickly, and other times it takes forever. I hadn't even thought about the auxiliary heater. I only noticed the error after replacing the battery, when I was trying to clear the usual error codes, and it was stuck at code 7D.
The inconsistent behavior could also be due to the already weak old battery, as the auxiliary heater is controlled in a rather "unintelligent" way.
Removing the trim pieces is a pain, but I'm used to it; this isn't the first time icon_biggrin.gif. I'm just annoyed that this process is much easier on the sister model, the Golf, but on the A3, you always have to remove everything. Actually, I should also replace some of the climate control actuators because some of them are constantly ticking (a known problem; there are updated versions available). But for that, much more needs to be... icon_wink.gif
Basically, I'm just curious... Now I'm going to take a closer look at the circuit board (checking for hairline cracks, temperature issues, etc.). The heater itself is quickly installed or removed; the car also runs without the cover parts icon_wink.gif ...
RedR32
Avatar-RedR32
Post27-11-2011, 21:17    Subject: 7D - Auxiliary heater malfunction Quote
That's also good.
Contact Ross-Tech, also Kaufmann.
reflexsilber met.
Post28-11-2011, 9:46    Subject: 7D - Auxiliary heater malfunction Quote
Here's a small tip from me on how to save money:
At least in the Passat 3C, the auxiliary heater including the control unit is only included in the first model year. The STG is known for its tendency to fail.
In later model years, the PTC heater will again be controlled using two relays. Since the three PTC elements themselves don't fail, you could switch to the relay-based system and save money that way. The outer rods provide the high heating power, while the inner rod provides the low heating power.
Refer to the wiring diagram for the newer model year for the remaining information.
I don't know if any more coding needs to be done.
Greetings.
Guste.
pschaefer
Post29-11-2011, 19:48    Subject: 7D - Auxiliary heater malfunction Quote
At least in the Passat 3C, the auxiliary heater including its control unit is only installed in the first model year. The control unit is known for failing. In later model years, the PTC is controlled again in a clumsy way using two relays.
Thanks for the tip. Yes, when I contacted the seller, he wanted to know the chassis number (even though I had only inquired about the "E" version mentioned above...). Audi probably switched to relays in the A3 at some point as well.
Under [url][/url] or [url][/url], you can see the whole range. The STG variant is the "top"-of-the-line model... icon_confused.gif
Currently, I've ordered some Power MOSFETs (they only cost 4.50 EUR). If replacing the MOSFETs doesn't solve the problem, I'm considering the relay option, although I would need to figure out a) who will drive the relays and b) how to securely attach the rather thick cables to the PTC elements without the car potentially catching fire icon_biggrin.gif.
guste100 wrote:
I don't know if anything else needs to be coded.
Okay, in the CAN gateway, "7D" needs to be disabled. That would also be my Plan C: simply deactivating the heater – I've already removed the 100A fuse in the engine compartment.http://www.beru.com/de/produkte/elektronik-und-sensorik/heizelemente-ptc{MARKER}http://www.beru.com/download/produkte/prospekt_ptc-neue-generation_de.pdf{MARKER}
pschaefer
Post09-12-2011, 21:25    Subject: Conclusion: Let it be! Quote
Brief feedback... It wasn't the MOSFETs.
Desoldering the components was a risky endeavor, as the circuit board is glued to the metallic base with thermally conductive adhesive, and even with significant heating, it is very reluctant to detach. However, desoldering is impossible without doing so, as the metal acts as an excellent heat sink. After replacing the MOSFETs, the same problem persisted, as indicated by VCDS. Furthermore, the thermal resistance is likely significantly higher than before due to the action taken (obviously: there's not enough solder under the MOSFET, and the thermal paste also needs to be replaced), so I'm not going to risk running the device.
End result: Disassembled. Opening with blind cover closed. Disconnected from the CAN gateway.
Post31-12-2015, 16:00    Subject: 7D - Auxiliary heater malfunction Quote
Tip: Check MELFs, see below.
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Heater Error 02085: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Auxiliary heater Audi, Seat, Volkswagen, unlock, error co... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Electric Heater Repair: Passat 3C TDI Electrical Systems, Vehicle Electronics, Multimedia
No new posts 7D Heater: What is it? On-Board Diagnostics (OBD)
No new posts Turn off auxiliary heater On-Board Diagnostics (OBD)
No new posts Auxiliary Heater Problems: Troubleshooting Guide On-Board Diagnostics (OBD)
