Adjusting 2-Needle Loppers: Where to Find Service?
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post13-01-2016, 13:52    Subject: Adjusting 2-Needle Loppers: Where to Find Service? Quote
I hope I am in the right place with my question icon_wink.gif.
I would like to have the fuel injectors on my Allroad properly adjusted, in both stages, after 420,000 km. However, no matter which diesel service I contact, they all tell me that they no longer offer this service.
Among them were true professionals who professionally overhaul and adjust VP44 injection pumps, but they don't handle injector holders?
Or should I just replace the nozzles and that will be enough?
Please report if anyone knows anything icon_smile.gif.
Translated on 20-08-2026, 11:30.
Post13-01-2016, 19:32    Subject: Adjusting 2-Needle Loppers: Where to Find Service? Quote
The nozzle holder combinations for engines with VP44 injectors are adjusted differently than those with VP37 injectors, and usually cannot be adjusted at all in the first stage.
Even with tricks, it's possible, but the effort involved doesn't justify the benefit.
New injector nozzles and they seem good. It's still important to check if they work properly.
Translated on 20-08-2026, 11:31.
Tagessuppe
Post14-01-2016, 12:34    Subject: Adjusting 2-Needle Loppers: Where to Find Service? Quote
Thank you for the response!
Now I understand why nobody wants to do this icon_wink.gif.
I also think it's more important to install new nozzle inserts than to ensure that the DÖD (presumably a specific component) is 100% equivalent to its new value.
Ultimately, even with worn-out valve heads and reduced opening pressure, they still performed reasonably well.
Translated on 20-08-2026, 11:32.
Post14-01-2016, 14:20    Subject: Adjusting 2-Needle Loppers: Where to Find Service? Quote
I also think that it is more important to install new nozzle inserts than for the DÖD (Diesel Oxidation Diesel) to be 100% equivalent to its new value.
Yes. However, it should generally work; I've also encountered broken or worn-out springs before. Also, things can go wrong during the conversion process if you don't do it frequently.
Therefore, a final exam is very useful.
The structure of your DHK (presumably a specific system or organization) is similar but not identical.
Okay, I'm ready. Please provide the German text you want me to translate into English. I will only give you the translation.
Translated on 20-08-2026, 11:34.
vwSchrauber
Post15-01-2016, 9:30    Subject: Adjusting 2-Needle Loppers: Where to Find Service? Quote
New nozzle inserts and good. It is still important to check if they work properly, of course.
Check the quantity deviations in the measurement data blocks. If it doesn't fit with a calibrated instrument (DHK), it will be evident at a value of +/- >1.5mg.
Translated on 20-08-2026, 11:35.
No new posts Lupo Door Problems: 6X1 MJ 2002 Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts 0,216 er Düsen mit welchen Einspritzdrück einstellen la... Diesel Engine Technology
No new posts High Boost Issues: What Else Could It Be? Diesel Engine Technology
No new posts Adjust headlights: How to do it right. Transmission, Chassis, Body & Interior
No new posts LL Service: What event can trigger it? Diesel Engine Technology
