KombiBlue Blaumann
Joined: 04/18/2003 Posts: 76 Karma: +7 / -0 Location: D-48165 Münster
12-01-2016, 18:07 Subject: High-Pressure Pump Timing: Why It Matters |
Hello, I'm wondering why the high-pressure pump in a VW CR engine is also connected to the crankshaft and camshaft.
Shouldn't it actually not matter in which position the pump is? It only increases the pressure of the diesel fuel, which is then stored in the rail. The water pump isn't disconnected either.
So, can someone please enlighten me?
What have I misunderstood or misinterpreted here?
Thank you.
Ralf. Gruss Ralf
Passat Var. 2.0 TDI 3/2009, 125kW, CBBB
Translated on 07-10-2026, 20:09.
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
12-01-2016, 18:19 Subject: High-Pressure Pump Timing: Why It Matters |
Hello Ralf,
The pressure in the high-pressure accumulator is not constant. I suspect that disconnecting the high-pressure pump is intended to better manage resonances in the fuel pressure.
The engine control unit can predict, based on a defined pump position, how the fuel pressure will change in advance.
Translated on 07-10-2026, 20:10.
Profile PM WWW Garage |
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
12-01-2016, 22:31 Subject: High-Pressure Pump Timing: Why It Matters |
dieselschrauber wrote: | Hello Ralf,
Best regards, Rainer |
Absolutely correct!  NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 07-10-2026, 20:11.
Profile PM Email Garage |
KombiBlue Blaumann
13-01-2016, 17:16 Subject: High-Pressure Pump Timing: Why It Matters |
Yes, that makes sense.
Thank you, I now understand.
The HD isn't a centrifugal pump. I hadn't thought of that.
Great.
Ralf. Gruss Ralf
Translated on 07-10-2026, 20:12.
vwSchrauber Profi-Schrauber
15-01-2016, 9:34 Subject: High-Pressure Pump Timing: Why It Matters |
Bosch describes the "injection synchronization" feature in the CP4 documents, which in the passenger car sector is typically a single-piston pump that does not provide continuous fuel delivery.
For comparison: CP1, CP1H, CP2, and CP3, as well as various high-pressure pump systems based on common rail technology (Deutz), provide continuous fuel delivery. selber schrauben - statt Werkstattpfusch
KombiBlue Blaumann
15-01-2016, 15:05 Subject: Pump Installation: Does Position Matter? |
So, does it not matter how the pump relates to the rest of the system?
And what type of fuel pump is in my Passat 2.0 TDI (CBBB)?
Thank you.
Ralf. Gruss Ralf
Translated on 07-10-2026, 20:13.
18-01-2016, 11:02 Subject: High-Pressure Pump Timing: Why It Matters |
Quote: | | So, does it not matter how the pump relates to the rest? |
Everything except the CP4 is actually irrelevant. Although, for example, with PSA, the high-pressure pump (CP3) is also disconnected, the synchronous operation is rendered unnecessary due to the 2/3 ratio.
Quote: | And what kind of fuel pump is in my Passat 2.0 TDI (CBBB)?
If it's a Bosch system, the EU5 standard typically uses a CP4 injector. This applies to most other manufacturers as well.
I suspect that one of the reasons the five-cylinder engine disappeared from the Crafter is that it would have been too complicated to adapt it. Instead, they could simply use a similarly powerful four-cylinder engine from the "passenger car/van" lineup. selber schrauben - statt Werkstattpfusch
Translated on 07-10-2026, 20:15.
KombiBlue Blaumann
21-01-2016, 7:19 Subject: High-Pressure Pump Timing: Why It Matters |
Okay, thank you, so CP4.
Do other people also experience so many problems with chip-generating HD pumps?
"Mine got it recently too. It's quite an expensive thing."
Thank you, Ralf.
Subject: Off-Topic: Why don't I receive emails when something is posted here? Gruss Ralf
Translated on 07-10-2026, 20:16.
21-01-2016, 11:12 Subject: High-Pressure Pump Timing: Why It Matters |
KombiBlue wrote: | Do all other people also have so many problems with HD pumps that produce shavings?
Mine also experienced it recently as well. | It's quite an expensive ordeal.
What kind of engine do you have? What's the engine code?
Quote: | | OT: Why don't I receive an email when something is posted here? |
It should work, have you checked the spam folder?
Translated on 07-10-2026, 20:17.
matthiasTDI96 Profi-Schrauber
21-01-2016, 11:14 Subject: High-Pressure Pump Timing: Why It Matters |
According to the signature, a CBBB.
Translated on 07-10-2026, 20:18.
21-01-2016, 11:17 Subject: High-Pressure Pump Timing: Why It Matters |
Damn, I just thought that only the 3.0 TDIs of certain model years were affected.
@ KombiBlue : What's the mileage and year of manufacture?
21-01-2016, 14:22 Subject: High-Pressure Pump Timing: Why It Matters |
If it's the one from the signature... from 2009.
21-01-2016, 15:08 Subject: High-Pressure Pump Timing: Why It Matters |
The mileage is still missing.
