Auxiliary heater fault memory Touareg 7P MJ 2013
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
VCDS-S
2013 Volkswagen Touareg
Post24-01-2016, 19:02    Subject: Auxiliary heater fault memory Touareg 7P MJ 2013 Quote
"I have the following error code stored in the STG18 module of the auxiliary heater, but there are no issues, the heater is working correctly, and there are no error codes stored in the engine control unit." What do the errors mean?
Address 18: Auxiliary heater (J364)
Label file: DRV\8R0-265-105.clb
Part number SW: 7P0 963 272 D, Hardware: 7P0 963 272 D.
Component: Auxiliary heater, part number H23 0243.
Revision: 56005006 Serial number: 20120427201602
Encoding: 114200
Operating number: WSC 31414 790 00001
VCID: 387B5A868BF50DFEA5-806C
"1 error found:"
01314 - Engine Control Unit.
013 - Please read the error memory.
Environmental conditions:
Error status: 01101101
Error priority: 5
Error frequency: 2
Lost Count: 107
Mileage: 80779 km
Time: 0
Date: 2016.01.15
Time: 22:00:03
Temperature: 1.0°C
Temperature: 9.0°C
Voltage: 12.30 V
Start.
Error code: 2.
Temperature: 1.0°C
Speed: 0 RPM.
No.
Post24-01-2016, 21:10    Subject: Auxiliary heater fault memory Touareg 7P MJ 2013 Quote
It's possible that there was an error stored in the engine control unit (ECU) that has since been resolved and/or cleared.
What is the result of the Autoscan? Are there any other errors, especially communication problems?
VCDS-S
Post24-01-2016, 22:20    Subject: Auxiliary heater fault memory Touareg 7P MJ 2013 Quote
Hello Rainer,
I had the same error message on December 29, 2015, and I cleared the error at that time. After doing so, the vehicle's data was clean, so it worked correctly after another run.
Encoding: 114200
"1 error found:"
Error priority: 5
Error frequency: 4
Lost Count: 78
Mileage: 79,908 km
Time: 0
Date: 2015.12.29
Time: 18:44:22
Temperature: 48.0°C
Temperature: 65.0°C
Voltage: 12.20 V
Start.
Error code: 2.
Temperature: 6.0°C
Speed: 0 RPM.
No.
Everything else without errors:
01-Motor electronics -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
08-Climate/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: OK 0000
10-Parking Assist 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-Heater -- Status: Error 0010
19-Diagnosis interface -- Status: OK 0000.
28-Heating/Climate: Current status: OK 0000.
42-door electric. Driver -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric. Front passenger seat. -- Status: OK 0000.
53-Parking brake -- Status: OK 0000
55-Beam angle adjustment. -- Status: OK 0000.
56-Radio -- Status: OK 0000
5F-Information Selection. I -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000.
69 followers -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
No new posts VW Caddy Tailgate 2004-2013 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Motion, Year 2013, Problems with ASR/ESP/ABS/Autohold Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Crafter, Year 2012/2013, High Standby Current Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touareg 7P 2013 DWA System Electrical Systems, Vehicle Electronics, Multimedia
No new posts Battery problems, 6J Cupra, 2013 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Error memory 1Z-TDI Diesel Engine Technology
No new posts Peugeot 206 and the error memory. On-Board Diagnostics (OBD)
