P3138 - Airflow Control Valve: Control Difference (Solution)
Post01-02-2016, 17:53    Subject: P3138 - Airflow Control Valve: Control Difference Quote
Possible causes for air flow control, throttle body valve, control difference (P3138):
- Throttle body base setting not performed (see throttle body base setting).
- Wiring/electrical connections to the throttle body valve (throttle body) are faulty.
- Throttle body valve (throttle body) is mechanically faulty.
Possible solutions:
- Vacuum valve basic setting
- Check vacuum valve wiring/electrical connections (throttle valve)
- Replace throttle valve module/vacuum valve module.
Notes for 2.0 TFSI engines: Check and update engine control unit software if necessary, replace vacuum valve module/throttle valve module (V157) with an improved version.
Attention: In TFSI engines, fault code P3138 can be a consequence of incorrect air leaks in the intake system. When low lambda values or "system too lean" are detected in this direction, investigate further.
Ratings - P3138 - Airflow Control Valve: Control Difference
No new posts P3135 - Airflow Control Valve: Exceeds Limit. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A6 4B, Fresh Air Blower Control Difference Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
No new posts Error - Airflow control valve for 1.9 TDI BLS Diesel Engine Technology
No new posts Golf V Intake Manifold Flap - Airflow Control & P138 ... Diesel Engine Technology
No new posts BLS intake flap Upload
No new posts Throttle valve 2 for 3.0 V6 TDI Diesel Engine Technology
