Golf 7 R DSG: Dyno Test & Performance
Oellappen
Karma: +0 / -2   Thank you, like it!
Post10-04-2016, 19:14    Subject: Golf 7 R DSG: Dyno Test & Performance Quote
What values do I need to perform a power measurement using VCDS?
I have VCDS DRV version 15.7.
Peter
Translated on 14-09-2026, 19:57.
Post10-04-2016, 22:38    Subject: Golf 7 R DSG: Dyno Test & Performance Translating...
[Translating...]
https://shop.dieselschrauber.de/download/KPower-Handbuch-ger.pdf
Oellappen
Post11-04-2016, 17:42    Subject: Golf 7 R DSG: Dyno Test & Performance Quote
Hello Rainer,
Thank you for your quick response. Of course, I read it.
Unfortunately, there are no standard MWB (Material Safety Data Sheets) available. There are over 900 possibilities.
to click.
I was hoping to get some help from you, as you have a lot of experience.
Peter
Translated on 14-09-2026, 19:58.
dieselschrauber likes this.
Post11-04-2016, 18:23    Subject: Golf 7 R DSG: Dyno Test & Performance Quote
Then, within those 900 possible values, search for the speed and RPM. It's in the link. Adjust the window displaying your 900 individual measurements so that you can see the descriptive text. And then, as described, log the data.
Translated on 14-09-2026, 19:59.
Oellappen
Post11-04-2016, 19:27    Subject: Golf 7 R DSG: Dyno Test & Performance Quote
Thank you. That's what I wanted to know.
Peter
Post13-04-2016, 16:51    Subject: Golf 7 R DSG: Dyno Test & Performance Quote
Translated on 14-09-2026, 20:00.
Post13-04-2016, 18:38    Subject: Golf 7 R DSG: Dyno Test & Performance Quote
I'm worried that this will only make things more complicated.
Oellappen
Post13-04-2016, 18:48    Subject: Golf 7 R DSG: Dyno Test & Performance Quote
Hello Rainer,
Thank you for your tip; it makes the search much easier.
Peter
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf, Bora (from 05.00) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Leistungsmessung On-Board Diagnostics (OBD)
No new posts K-Power Performance Measurement On-Board Diagnostics (OBD)
No new posts TDI Performance Measurement: Calculating the Nominal Perf... Diesel Engine Technology
No new posts Performance Logs: How to Create and Use Them On-Board Diagnostics (OBD)
