Start/Stop vom System deaktiviert | Posts 16+
Go to page: Previous  1, 2
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Post22-04-2016, 9:21    Subject: Quote
The operating number (WSC), the importer's number, and the device number are purely informative labels indicating who modified what with which device.
You can set your own workshop data in the VCDS program settings.
The data will NOT be checked for plausibility. Individuals might therefore get the idea to use existing car scans. icon_idea.gif
Translated on 25-09-2026, 17:14.
vag-driver
Post22-04-2016, 9:44    Subject: Quote
If I confirm the values provided by VCDS (12345/123/12345) with "OK," it crashes and displays an error message. The message roughly translates to: "Incorrect importer blabla number..."
Translated on 25-09-2026, 17:15.
DieselBär30x
Avatar-DieselBär30x
Post22-04-2016, 10:07    Subject: Quote
Hello everyone!
@VAG-Diver: Oh dear, don't act like that... icon_rolleyes.gif
dieselschrauber wrote:
... Individuals might therefore come up with the idea of using existing car scans. icon_idea.gif...
VCDS homepage, tabs at the top right, where you can enter WSC, etc. - this has also been explained specifically for you before.
And since the above suggestion seems too difficult:
Do you accept WSC 00020 790 00000 or WSC 00020 999 00000 or WSC 40517 000 1048576 or ...?
All WSC codes from YOUR vehicle scan!
Best regards from Munich!
Translated on 25-09-2026, 17:16.
vag-driver
Post22-04-2016, 10:27    Subject: Quote
Okay, I understand. I just wanted to know why the code suggested by VCDS isn't accepted, especially since there's supposedly no validation taking place.
Translated on 25-09-2026, 17:17.
Post22-04-2016, 10:33    Subject: Quote
vag-driver wrote:
I understand. I just wanted to know why the code suggested by VCDS is not accepted, even though no validation is actually taking place.
This is because VCDS takes the existing values if no information is provided, and if "00000" is present, it is not valid for coding. icon_idea.gif
Translated on 25-09-2026, 17:18.
vag-driver
Post22-04-2016, 10:36    Subject: Quote
I learned quite a few things again.
No new posts Error code P2177 - Lean condition system during idle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code P2178 - Engine running too lean Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Keyless Entry Installation Guide by IN.PRO Troubleshooting & Guides
No new posts Airbag malfunction -> does this disable the system? On-Board Diagnostics (OBD)
No new posts Skoda Superb 3T: Start-Stop System On-Board Diagnostics (OBD)
No new posts Disable Audi A4 8W Start Stop System On-Board Diagnostics (OBD)
No new posts Start/Stop is unavailable, what does the measurement bloc... On-Board Diagnostics (OBD)
