P0400 - Exhaust Gas Recirculation (EGR) Malfunction (Solution)
Post26-04-2016, 15:05    Subject: P0400 - Exhaust Gas Recirculation (EGR) Malfunction Quote
Error codes: 16784/P0400/001024 - Exhaust gas recirculation (EGR) malfunction.
Possible symptoms:
- MIL (Malfunction Indicator Lamp) light illuminated on the instrument cluster.
- Power loss.
- The noise level of the engine idling sounds slightly "rougher".
- Emission limits are not being met.
Possible causes:
- Wiring/cabling to the AGR module is faulty or damaged.
- AGR module damaged/defective.
Note: VAG uses EGR modules that, in some cases, are equipped with plastic gears that are prone to long-term tooth failure. There are replacement parts for the AGR modules available from independent parts suppliers, which are significantly cheaper than those offered by the vehicle manufacturer's parts department.
Ratings - P0400 - Exhaust Gas Recirculation (EGR) Malfunction
No new posts P1405 - Exhaust Gas Recirculation (EGR) Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Variable valve timing malfunction General Tips
No new posts Central Locking Failure: A6 Doku 4B (10/2001) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF malfunction On-Board Diagnostics (OBD)
No new posts DPF Failure: A4 2.0 TDI CNHC Engine Diesel Engine Technology
No new posts CFWA - Diesel Particulate Filter Malfunction Diesel Engine Technology
No new posts Actuator diagnosis for troubleshooting: Malfunction of le... On-Board Diagnostics (OBD)
