Opening CLB files
Oellappen
Karma: +0 / -2   Thank you, like it!
Post25-04-2016, 19:54    Subject: Opening CLB files Quote
How can I open CLB files in my own car?
Best regards, Peter icon_rolleyes.gif.
Translated on 12-07-2026, 13:33.
Post26-04-2016, 9:05    Subject: Opening CLB files Quote
Hi Peter,
".clb" files are control unit description files from VCDS. They are used automatically, and the user interface is expanded with the information they contain when you access the corresponding control unit.
Translated on 12-07-2026, 13:34.
Oellappen
Post26-04-2016, 17:23    Subject: Opening CLB files Quote
Hi Rainer,
Thank you for your quick response.
I finally managed to open them, but unfortunately, they are encrypted.
Can it be changed?
Post26-04-2016, 18:17    Subject: Opening CLB files Quote
Oellappen wrote:
Hi Rainer,
Can it be changed?
Sure, you can change that with the right key. However, the intention is that while the files adjust the user interface of the control units installed in your vehicle, not everyone will be able to copy all the information from all the control units.
Besides that, there's no reason for you to view the file in its raw format, because you can see the same information in VCDS anyway.
PS: Please don't ask for the source code of VCDS now...
Translated on 12-07-2026, 13:36.
Oellappen
Post26-04-2016, 18:49    Subject: Opening CLB files Quote
Hi Rainer,
Don't worry, I just wanted to get some information. I still have the manufacturer's warranty.
With my old Golf 4, it was easier to see all the values on a single page.
It's probably a bit more complicated with the Golf 7, and that's actually a good thing.
Thank you for your information.
Translated on 12-07-2026, 13:38.
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Do windows open on their own? General Tips
No new posts Doku Polo MJ 2002, windows open automatically Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Label Files: Definition & Examples Diesel Engine Technology
No new posts Analyze Log Files: Extract Insights & Data On-Board Diagnostics (OBD)
No new posts Label Files: How to Create & Use Them On-Board Diagnostics (OBD)
No new posts Log File Analysis: Insights & Optimization On-Board Diagnostics (OBD)
