Fuel Injector Calibration: How-To Guide
Tobe1000
Post31-05-2016, 19:07    Subject: Fuel Injector Calibration: How-To Guide Quote
Hello everyone, I'm new to this forum and still getting familiar with it. I also have a question for you.
I own a 2012 Caddy with the 1.6 CR diesel engine, identification number CAYP. The problem was that one of the fuel injectors was defective (the old one was 03L130277B, and the new one is 03L130277S). Do I need to program the new injector, or will the engine management system automatically adjust the learning values for the new injector?
I hope you can give me some advice.
Thank you in advance.
Translated on 16-09-2026, 9:07.
chli1976
Post31-05-2016, 19:49    Subject: Fuel Injector Calibration: How-To Guide Quote
Yes, you need to calibrate/adjust the injector.
VCDS
Translated on 16-09-2026, 9:08.
Tobe1000
Post31-05-2016, 19:54    Subject: Fuel Injector Calibration: How-To Guide Quote
Can someone explain to me how to do this using VCDS? That would be great, thanks.
Wiesel
Post31-05-2016, 20:20    Subject: Fuel Injector Calibration: How-To Guide Quote
If you have VCDS, use the same email address for the forum as you do for the shop, and try logging out and logging back in – there might be more information available then.
Tobe1000
Post01-06-2016, 6:38    Subject: Fuel Injector Calibration: How-To Guide Quote
I've been searching for hours and haven't found anything. Could someone please help me?
I'm still not quite getting the hang of all the forum's functions, but I'm trying my best icon_smile.gif.
Translated on 16-09-2026, 9:09.
DieselBär30x
Avatar-DieselBär30x
Post01-06-2016, 7:04    Subject: Fuel Injector Calibration: How-To Guide Quote
Were you able to understand everything that the weasel wrote above? icon_rolleyes.gif
But I'd be happy to explain it to you in more detail.
Without a valid VCDS license, there is no support available here - END icon_exclaim.gif
Best regards from Munich!
Wiesel
Post01-06-2016, 13:14    Subject: Fuel Injector Calibration: How-To Guide Quote
So - everything's good icon_cool.gif.
The VCDS file was provided by a registered user here.
Helpful suggestions on the topic are welcome icon_wink.gif.
Micha
Translated on 16-09-2026, 9:10.
Gerrit
dieselschrauber likes this.
Post01-06-2016, 17:20    Subject: Vehicle Scan: Diagnostics & Inspection Quote
Hello.
Here is the vehicle scan, provided as a file using the USN Stick format.
Gerrit
Log-D-UB 2320-WV2ZZZ2KZCX133308-46540km.txt
 File name:  Log-D-UB 2320-WV2ZZZ2KZCX133308-46540km.txt
 File size:  8.94 KB
 Downloaded:  1007 times
Translated on 16-09-2026, 9:11.
Back to top Profile PM Email
DieselBär30x
Avatar-DieselBär30x
Post01-06-2016, 20:02    Subject: Fuel Injector Calibration: How-To Guide Quote
Hello everyone!
I didn't know that Gerrit had lent you his VCDS and I suspected that you were using one of the -unfortunately- many pirated copies. icon_wink.gif
Take a look here to see if this helps you or your team.
http://wiki.ross-tech.com/wiki/index.php/3.0l_V6_TDI_%28BKS/BMK/BUN%29
Translated on 16-09-2026, 9:12.
Tobe1000
Post02-06-2016, 19:03    Subject: Fuel Injector Calibration: How-To Guide Quote
Thank you all for your efforts. I understand that you're being cautious, and I'm not upset about it in any way. That's why Gerrit got involved to get more information. But everything is fine, I managed to fix it, and it turned out to be easier than I thought.
Thank you again, everyone.
Translated on 16-09-2026, 9:13.
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Model 2014 Key Programming via VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WFS Setup: How to Configure and Use On-Board Diagnostics (OBD)
No new posts Learn PDE: A Beginner's Guide On-Board Diagnostics (OBD)
No new posts Key Fob Programming: How-To Guide On-Board Diagnostics (OBD)
No new posts Engine Control Unit (ECU) Calibration for WFS On-Board Diagnostics (OBD)
