P2006 - Intake manifold control valve stuck closed (Solution)
Post12-06-2016, 21:53    Subject: P2006 - Intake manifold control valve stuck closed Quote
Error code P2006 - Intake manifold control valve stuck in the closed position, functionally related to codes P2004, P2005, and P2007. It refers to the bypass valve in the intake manifold, which affects the length of the intake path (long/short).
Possible symptoms:
- MIL (Malfunction Indicator Lamp) light is illuminated on the instrument cluster.
- Power loss in P2006/P2007 models at higher RPMs, and in P2004/P2005 models at lower RPMs.
Possible causes:
- Check for vacuum leaks, inspect vacuum hoses, and test solenoid valves.
- Shift valves are mechanically defective or difficult to operate.
- Position sensor G336 is defective.
Ratings - P2006 - Intake manifold control valve stuck closed
No new posts P00AF: Turbocharger Malfunction - Causes & Fixes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Spoiler Grill: Open or Closed? Why? Transmission, Chassis, Body & Interior
No new posts Intake Manifold Wall Thickness Diesel Engine Technology
No new posts Golf 4: Glovebox Light On When Closed Transmission, Chassis, Body & Interior
No new posts AGR at 100% - Performance and Optimization On-Board Diagnostics (OBD)
