[email protected]
02-06-2016, 10:58 Subject: Audi A4 2.7L: Specs, Problems, & More |
Hello, I have an Audi A4 2.7 TDI from 2010. The engine code is CGKA. The problem is that the differential pressure sensor triggered an error message. I replaced it. I wanted to perform a DPF regeneration, but unfortunately, I can't access the measuring blocks or the adaptation settings.
"These fields are grayed out. It also doesn't work regarding the access permissions. Currently, the car is running in emergency mode, and I can't perform a forced regeneration. Can anyone help me get it working without having to take it to the dealer?"
Translated on 13-10-2026, 0:44.
RedR32 Schrauber
Joined: 12/21/2008 Posts: 1071 Karma: +11 / -0 Location: Bad Lobenstein 1998 Volkswagen Golf Premium Support
02-06-2016, 12:16 Subject: Audi A4 2.7L: Specs, Problems, & More |
reflexsilber met.
Translated on 13-10-2026, 0:45.
Profile PM Garage |
[email protected]
02-06-2016, 12:21 Subject: Audi A4 2.7L: Specs, Problems, & More |
Hello, I've already tried that. But as I said, I'm unable to access the measurement data blocks with my program; I can't get into the fitting section.
Translated on 13-10-2026, 0:46.
RedR32 Schrauber
02-06-2016, 12:29 Subject: Audi A4 2.7L: Specs, Problems, & More |
Translating... |
reflexsilber met. |
Profile PM Garage |
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
02-06-2016, 12:30 Subject: Audi A4 2.7L: Specs, Problems, & More |
1. Measure whether the values from the differential pressure sensor are correct (0 mbar when only the ignition is on), and check the plausibility of the values under load. There is a topic about this: https://community.dieselschrauber.org/en/viewtopic.php?t=24222
2. Check the exhaust temperature sensor values for plausibility.
3. Read the article about forced regeneration, which was updated some time ago: https://community.dieselschrauber.org/en/viewtopic.php?t=17091
"Modern control units no longer have 'data blocks' in the traditional sense, but instead use 'extended data blocks' or other functions. The specifics can be determined by performing a vehicle scan."
Translated on 13-10-2026, 0:47.
Profile PM WWW Garage |
[email protected]
02-06-2016, 13:31 Subject: Audi Scans: Car History Reports & Vehicle Checks |
Here are the scans.
Mileage: 136,940 km
Vehicle type: 8K (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 72
Vehicle Identification Number: WAUZZZ8K2AA127722
Mileage: 136,940 km
01-Motor electronics -- Status: Error 0010.
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
08-Climate control/heating unit -- Status: OK 0000
09-Central Electrical System -- Status: OK.
Parking Assist 10 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
42-Door Electric Driver -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
53-Parking brake -- Status: OK 0000
55-Beam adjustment. -- Status: OK 0000.
56-Radio -- Status: OK 0000
5F-Information Selection. I -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein."
Address 01: Engine Control Module (J623-CGKA)
Label file: DRV\059-907-401-V1.clb
Part number SW: 8K1 907 401 K, Part number HW: 8K1 907 401 A.
Component: 2.7 TDI EDC17 H03 0008.
Revision: 15H03---
Encoding: 010C002C18070118
Operating number: WSC 06335 000 00000
ASAM Dataset: EV_ECM27TDI0118K1907401K 001009
ROD: EV_ECM27TDI.rod
VCID: 346CD7E59FA5119EAA-8060
2 error codes found:
5188 - Diesel particulate filter - Excessive sulfur content.
P2463 00 [167] - -
Warning light ON - unconfirmed - checked since last reset.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 1.
Mileage: 136,948 km
Date: 2016.06.02
Time: 12:54:42
5189 - Particle filter, bank 1.
P2002 00 [039] - Malfunction.
unconfirmed - checked since last deletion.
Error priority: 2
Error frequency: 1.
Mileage: 136,948 km
Date: 2016.06.02
Time: 12:54:42
Readiness: 0 0 0 0 1 0
Address 03: Brake Electronics (J104)
Label file: DRV\8K0-907-379-V1.clb
Part number SW: 8K0 907 379 BD, Part number HW: 8K0 907 379 BD.
Component: ESP8 front
H04 0030
Revision: -------- Serial Number: --------------
Encoding: 190D08
VCID: 7CFC3FC5FF7519DE22-8028
No error codes found.
Address 05: Access/Startup Authorization (J393)
Label file: DRV\8K0-907-064-05.clb
Part number SW: 8K0 907 064 DP
Part number HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0327
Revision: 00002001
Encoding: 030200
VCID: 01024E319897743671-8054
Subsystem 1 - Part number SW: 8T0 959 754 D, HW: 8T0 959 754 D.
Component: FBSAUDIB8 IDG H37 0060.
Subsystem 2 - Part number SW: 8K0 905 852 D, HW: 8K0 905 852 D.
Component: J764 ELV MLB H37 0042.
Address 08: Climate Control/Heating Unit (J255)
Label file: DRV\8Tx-820-043-1Z.clb
Part number SW: 8T1 820 043 AN, Hardware number: 8T1 820 043 AN.
Component: CLIMATE ZONE 1, part number H08 0171.
Revision: A1000000 Serial Number: 01020220100929
Coding: 36100000
VCID: 7DFA32C1E46F10D615-8028
Address 09: Central Electronics (J519)
Label file: DRV\8K0-907-063.clb
Part number SW: 8K0 907 063 P, HW: 8K0 907 063 P.
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000575567
Encoding: 260050914034AF010001000300001D0D4F1C070800010101000000
VCID: 3C7CFFC5BFF5D9DE62-8068
Subsystem 1 - Part number SW: 8K1 955 119 A, HW: 8T1 955 119, Label file: DRV\1KX-955-119.CLB.
Component: WWS 311008 H06 0070
Encoding: 00FD11
Subsystem 2 - Part number SW: 8K0 955 559 HW: 8K0 955 559 Label file: DRV\8K0-955-559.CLB
Component: RLS H04 0003.
Encoding: 035028
Subsystem 3 - Part number SW: 8K0 941 531 AL, HW: 8K0 941 531 AL.
Component: E1 - LDS H08 0090
Address 10: Parking Assist 2 (J446)
Label file: DRV\8K0-919-475.clb
Part number SW: 8K0 919 475 R, HW: 8K0 919 475 A.
Part: PARKING ASSIST 8K H06 0070
Revision: 11001001 Serial number: 50941003400383
Encoding: 100003
VCID: 48949315FB2D857EF6-801C
Address 15: Airbag (J234)
Label file: DRV\8K0-959-655.clb
Part number SW: 8K0 959 655 G, Part number HW: 8K0 959 655 G.
Part: Airbag VW-AU10 H39 0560
Serial number: 003EFD0BES7J
Encoding: 30343435363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 41828E31D017B43631-8014
Crash sensor for driver-side side airbag:
Serial number: 6334MSME50036B356
Crash sensor for side airbag, passenger side.
Serial number: 6344MSME5005014B0
Rear side airbag crash sensor (driver's side).
Serial number: 6352QSME244D2722D
Crash sensor for rear side airbag, passenger side.
Serial number: 6362QSME564D2110A
Crash sensor for front airbag, driver's side:
Serial number: 63732SME224E1938%
Crash sensor for front airbag, passenger side.
Serial number: 63832SME574E203A2.
Address 16: Steering Wheel Electronics (J527)
Label file: DRV\8K0-953-568.clb
Part number SW: 8K0 953 568 F, HW: 8K0 953 568 F.
Component: Steering module H16 0014.
Revision: -------- Serial Number: 90315JAT000AU
Encoding: 000017
VCID: 3D7AF2C1A4EFD0D655-8068
Component: E221 - MFL H02 0010
Address 17: Control panel module (J285)
Label file: DRV\8T0-920-xxx-17.clb
Part number SW: 8K0 920 930 D, Part number HW: 8K0 920 930 D.
Bauteil: KOMBIINSTR. H20 0255
Revision: 00200000 Serial number: CIY33AX1A
Encoding: 030D100003000008000000
VCID: 2E58C58D79893B4EDC-807A
Address 19: Diagnostic interface (J533)
Label file: DRV\8T0-907-468.clb
Part number SW: 8T0 907 468 T, HW: 8T0 907 468 K.
Component: GW-BEM 4CAN-M H09 0105
Revision: EB800053 Serial Number: 5300E101220154
Encoding: 00C303
VCID: 52A0B17D0D713FAE98-8006
Subsystem 1 - Part number SW: 8K0 915 181 E, HW: 8K0 915 181 E.
Component: J367-BDM H07 0170
Address 42: Door electrical driver (J386) Label file: 8K0-959-793.clb
Part number SW: 8K0 959 793 H
Part number HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000010048460
Encoding: 011C02204000410001
VCID: 458A9A21CC3F98160D-8010
Address 46: Comfort System (J393)
Label file: DRV\8K0-907-064-46.clb
Revision: 00002001 Serial number: 0125968731
Encoding: 01040620203900400320023280000000
Address 52: Power door lock, front passenger side (J387)
Label file: 8K0-959-792.clb
Part number SW: 8K0 959 792 H, HW: 8K0 959 792 D.
Component: TSG BF H11 0306
Revision: Serial number: 0000009946114
Encoding: 011C02204C00410001
VCID: 448C8725C705A11E1A-8010
Address 53: Parking brake (J540)
Label file: DRV\8K0-907-801-V1.clb
Part number SW: 8K0 907 801 H, HW: 8K0 907 801 H.
Part: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000421518
Operating Number: WSC 00000 000 00000
VCID: 346CD7E597A5119EAA-8060
Address 55: Headlight range control. Label file: DRV\8K0-907-357.clb
Part number: 8K5 907 357.
Component: Dynamic LWR, H01 0010.
Revision: 00000001 Serial number:
Encoding: 0000004
Operating number: WSC 06334 000 00000
VCID: 77F620E906533A864F-8022
Address 56: Radio (R) Label file: DRV\4F0-035-0xx-56.clb
Part number SW: 4F0 035 056 B, HW: 4F0 035 056
Component: Radio U STD H45 0020.
Revision: AB001007
Serial number: 342B$0A7756558
Encoding: 010003020100000001
VCID: 1F4628490E23A2C667-804A
Address 5F: Information Selection. I (J794)
Label file: DRV\4E0-035-6xx-5F.clb
Part number SW: 8T1 035 652 D, HW: 8T1 035 652 D.
Component: B-BN-EU H56 0048
Revision: -------- Serial Number: 323BU0A7552682
Encoding: 010100010106E1ED01000F0E000000030001
VCID: 3668EDED81D9038E94-8062
Subsystem 1 - Part number: 4G0 919 884 F.
Component: EUR 2010 1005
Subsystem 2 - Part number SW: 4L0 919 604, HW: 4L0 919 604.
Component: DU6 Basic H43 0306
Subsystem 3 - Part number SW: 8T0 919 609, HW: 8T0 919 609.
Component: E0380, Used. H08 0100.
Address 62: Door electric, left/right (J388) Label file: 8K0-959-795.clb
Part number SW: 8K0 959 795 C. Hardware: 8K0 959 795 C.
Component: TSG HL H10 0306
Revision: Serial number: 0000102785550
Encoding: 010C02204000210001
VCID: 4280813DDD11AF2E28-8016
Address 72: Door electric, high, right (J389)
Component: TSG HR H10 0306
Revision: Serial number: 0000102785548
Address 01: Engine Control Module (8K1 907 401 K)
12:56:13
017 Loading limit for field regeneration: 28.80 g.
230. Particle filter; oil ash volume 0.15 l.
376 Loading limit 3: 36.00 g
377 Loading limit: 4, 51.30 g
Translated on 13-10-2026, 1:19.
02-06-2016, 14:36 Subject: Audi A4 2.7L: Specs, Problems, & More |
It only has extended measurement data blocks.
Translated on 13-10-2026, 1:51.
[email protected]
02-06-2016, 14:38 Subject: Audi A4 2.7L: Specs, Problems, & More |
And how can I perform a factory reset? It doesn't work the way the instructions describe.
02-06-2016, 14:46 Subject: Audi A4 2.7L: Specs, Problems, & More |
Anleitung fĂŒr DPF Regeneration, SteuergerĂ€t mit UDS wrote: |
Forced DPF regeneration for 1.6L/2.0L R4 & 3.0L V6 CR-TDI engines (UDS).
"Background information:"
In newer common-rail TDIs, there are two types of DPF regeneration, depending on the soot load of the filter. If the calculated or actual soot mass is below a certain threshold, the regeneration can be performed while the vehicle is stationary or while it is being driven. If the soot mass in the filter is higher, regeneration can only be performed while the vehicle is being driven.
Prerequisites for regeneration:
Ignition ON.
The engine is idling (park position with automatic transmission).
Make sure the tank is filled to at least 25%.
Coolant temperature above 70°C (see corresponding extended measurement data block).
Hood closed.
Particulate filter loading status (see the corresponding extended measurement block) within the specified range. If the particulate filter loading exceeds the corresponding limit (see Screenshot below), the filter must be replaced immediately, as otherwise the filter may overheat during regeneration and potentially catch fire!
As many electrical consumers/loads in the vehicle as possible should be turned on (e.g., lights, rear window heater, air conditioning).
Regenerative braking: Engage when driving at a minimum speed of 60 km/h.
Regeneration during driving: Engine speed between 2000 and 2500 RPM, exhaust gas temperature in the exhaust manifold > 700°C.
Read the engine control unit's error memory to identify potential causes of errors and then fix them.
The regeneration process can take up to 20 minutes. Drive until the filter is as empty as possible (0%). Be careful, as high temperatures can occur in the exhaust system!
If the regeneration fails, it's either because the engine was running under too little load (e.g., driving downhill for a long time), causing the exhaust temperature to drop too much (approximately 170°C before the turbocharger, 150°C before/after the particulate filter), or there's another engine fault that needs to be addressed.
When regeneration is performed while the vehicle is stationary, and if supported by the control unit, no input is required at Security Access - 16.
[ECU Selection]
[01 - Engine]
[Default setting - 04]
Select the appropriate option from the dropdown menu to regenerate.
[Ok!Bitte gib mir den deutschen Text, den du ĂŒbersetzt haben möchtest.
Drive until the amount of soot or the volume of soot is as small as possible (0%, 0 ml). Find and observe the corresponding measurement value for this in the advanced measurement data blocks.
[Back]
[End connection, back - 06] |
Which of these points is not possible? Please provide a Screenshot of the VCDS dialog showing the control unit information and buttons.
Translated on 13-10-2026, 1:55.
[email protected]
07-06-2016, 19:31 Subject: Audi A4 2.7L: Specs, Problems, & More |
I've tried it several times. Unfortunately, it hasn't worked. It keeps getting interrupted.
But thank you for the instructions.
Translated on 13-10-2026, 1:59.
07-06-2016, 20:41 Subject: Audi A4 2.7L: Specs, Problems, & More |
Quote: | | Which point is not working? Please provide a Screenshot of the VCDS dialog, showing the control unit information and buttons. |
What did the measurement blocks show regarding ash mass/volume and soot content?
Are you getting any information, or was the entire question rhetorical?
[email protected]
07-06-2016, 20:56 Subject: Audi A4 2.7L: Specs, Problems, & More |
The volume was 0.15 liters, and I don't have the rest of the information anymore. I wrote what I had in the scan. I can check for errors again if you like.
Translated on 13-10-2026, 2:00.
[email protected]
16-06-2016, 19:41 Subject: Audi A4 2.7L: Specs, Problems, & More |
I can't retrieve the error code anymore. It had already been taken to an independent repair shop. I would have liked to know why it kept failing for me. I thought the conditions were met. However, the mechanic said that it also failed multiple times at the workshop because certain temperatures weren't reached. I think it was the exhaust gas temperatures. And I believe that was the problem for me as well. The car could then be regenerated while stationary.
Bad luck.
I would have liked to have achieved that too. I'm really frustrated right now.
Translated on 13-10-2026, 2:01.
16-06-2016, 21:28 Subject: Audi A4 2.7L: Specs, Problems, & More |
Well, unfortunately, you haven't addressed any of my questions, and no information was sent.
Then there's no point in speculating about which conditions might not have been met, as they are all listed in my instructions.
Translated on 13-10-2026, 2:02.
