Klimaanlage ohne Funktion | Posts 16+
Go to page: Previous  1, 2
Basti1605
DieselBär30x likes this.
Post25-06-2016, 17:36    Subject: Quote
Okay, so I disassembled the compressor today. Unfortunately, I didn't see anything that indicated the shaft was broken or anything like that.
Perhaps it would have been enough to simply tighten the middle screw again. Well, but that wouldn't have been a good solution either.
If you are interested in the pictures, I would be happy to send them all to you via email.
Best regards, Basti.
 File size:  3.27 MB
 Viewed:  815 times
 File size:  3.52 MB
 Viewed:  679 times
 Kolben
 File size:  3.32 MB
 Viewed:  762 times
 Verdichtungsraum der einzelnen Kolben
 File size:  3.52 MB
 Viewed:  705 times
 Druckregelventil
 File size:  2.79 MB
 Viewed:  713 times
 File size:  4.05 MB
 Viewed:  812 times
Translated on 24-08-2026, 20:58.
vag-driver
Post25-06-2016, 18:01    Subject: Quote
Tightening the screw wouldn't have helped because the driving element is located on the toothed section. Have you seen any shavings in the system?
Andreas
Basti1605
Post25-06-2016, 18:35    Subject: Quote
So, there were no shavings in the system. However, I still flushed it. But even when opening the compressor, I didn't see any shavings.
Translated on 24-08-2026, 20:59.
vag-driver
Post25-06-2016, 19:12    Subject: Quote
It's strange because nothing appears damaged in the pictures. Perhaps it was the control valve.
Andreas
Basti1605
Post25-06-2016, 19:33    Subject: Quote
As I said: The middle screw had come loose. It also exhibits the exact defect described in the Elsa documentation.
May I post this image?
"Edit:"
To put it in my own words: By loosening the central screw, the multi-tooth coupling between the clutch hub and the compressor shaft is damaged. This results in a loss of power transmission.
Translated on 24-08-2026, 21:00.
Post25-06-2016, 20:29    Subject: Quote
Basti1605 wrote:
May I repost this image?
From "Deine Mittelschraube," yes; excerpts from ELSA, no.
vag-driver
Post25-06-2016, 20:36    Subject: Quote
It might be. I've been reading a lot of incorrect information in official Volkswagen documentation lately, so I'm being very cautious.
Anyway, the main thing is that the air conditioning cools down, and hopefully it will do so for a long time without any further defects.
Andreas
Translated on 24-08-2026, 21:01.
No new posts A3 8P1 AC Not Working: Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Van AC Repair: 7-Seater, No Cooling Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J AC Repair: No Cooling - 2000 Model Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Manual AC Not Working? Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts Tiguan 5N air conditioning system not working Transmission, Chassis, Body & Interior
No new posts Audi A3 AC Not Working: 8P BKD Repair Guide Transmission, Chassis, Body & Interior
No new posts ESP Failure: Causes and Solutions On-Board Diagnostics (OBD)
