Hidden MFA Menu: How to Access It
benmen
Post07-10-2003, 14:22    Subject: Hidden MFA Menu: How to Access It Quote
I found this information, but it doesn't apply to my situation. What is the MFA button if you have a rocker switch with up/down controls and a reset button?
I have a Golf IV manufactured in 2000.
Benjamin.
MFA features.
Static values.
- Engine and ignition off.
- Set the MFA save button to storage slot 1.
- Press and hold the MFA button.
- Turn the ignition on and off.
- Ignition on only (do not start the engine!)
1. Engine characteristic map code.
2 Country codes.
3. Speed setting.
4 upper speed limits.
5 lower speed limit.
6. Shut-off pressure (mbar)
7-segment test (displays all elements at once).
'Feature 8 is not available in some MFA solutions, while it is in others. There is no information available about its meaning.'
'Feature 9 is not available in some MFA solutions, while it is in others. There is no information available about its meaning.'
Dynamic values.
- Set the MFA storage key to storage location 2.
- Start the engine!
1. Checksum
2. Intake manifold vacuum pressure in mbar, or as a decimal value (important for turbochargers).
3. Speedometer display (provides an accurate reading and can be used to calculate the exact speed).
4. Instantaneous power consumption.
5 counter pulses from the speedometer.
6. Oil temperature in °C.
7. Outside temperature in °C.
Translated on 27-08-2026, 11:17.
Michael II
Post07-10-2003, 14:26    Subject: Hidden MFA Menu: How to Access It Quote
To my knowledge, that was the MFA (multifunction display) of the Golf III. I'm familiar with it from the VR6 models.
Tschüss
Michael II
Translated on 27-08-2026, 11:20.
benmen
Post07-10-2003, 14:50    Subject: Hidden MFA Menu: How to Access It Quote
So, does that not exist in the Golf IV?
I've also read about hidden menus on Golf IV forums, so I'm a bit surprised...
Benjamin.
Post07-10-2003, 14:55    Subject: Hidden MFA Menu: How to Access It Quote
This only works on older VW models with MFA (Multi-Function Display), including the Golf I Cabrio, Golf II, Golf III, Passats from model 35i to 3b, and probably also the Corrado. However, it definitely doesn't work with this trick on any newer models.
Translated on 27-08-2026, 11:21.
WarLord
Post07-10-2003, 20:50    Subject: Hidden MFA Menu: How to Access It Quote
Can the 35i not display the oil temperature by default, or is that only possible after unlocking it? Are the displays then activated by default, or do they disappear again after the next restart (ignition)?
Best regards, WarLord.
Translated on 27-08-2026, 11:22.
Mampf
Karma: +8 / -1   Thank you, like it!
Post07-10-2003, 20:59    Subject: Hidden MFA Menu: How to Access It Quote
WarLord wrote:
Can the 35i not display oil temperature by default, or is that only possible after unlocking it? Are the displays then activated by default, or do they disappear again after the next restart (ignition)?
Greetings, WarLord
It can display the oil temperature as a standard feature.
In check mode, my display shows the oil temperature, current power consumption, and outside temperature (which is permanently -40°C because the temperature sensor is connected to the control unit).
The displays will return to normal after the next restart.
Munch.
Translated on 27-08-2026, 11:23.
WarLord
Post07-10-2003, 21:06    Subject: Hidden MFA Menu: How to Access It Quote
Is the temperature sensor not normally split between the Climatronic and the MFA? Doesn't the MFA also normally display the outside temperature (which would make sense)? So, to avoid any more questions like that, I'll just ask the following question: What does the MFA display by default on a Passat 35i 3A5 (facelift), and what needs to be activated (and therefore disappears after the next restart)?
Translated on 27-08-2026, 11:24.
Mampf
Post07-10-2003, 23:10    Subject: Hidden MFA Menu: How to Access It Quote
WarLord wrote:
1. Is the temperature sensor not normally split between the Climatronic and MFA systems?
2. Does the MFA (Multi Function Display) also not display the outside temperature by default (which would make sense)?
Okay, to avoid any more questions like that, I'll simply ask the following: What information does the MFA (Multi-Function Display) typically show on a Passat 35i 3A5 (facelift model), and what information needs to be activated (and therefore disappears after the next restart)?
Greetings, WarLord
1: Apparently not.
Regarding point 2: If you don't have Climatronic, the outside temperature is displayed on the corresponding screen. With Climatronic, the outside temperature is also displayed on its own screen.
ad3: Standard: Time - Travel time - Average fuel consumption - Average speed - Distance traveled - Oil temperature.
Check mode: see my previous post.
Best regards & good night.
Munch.
Translated on 27-08-2026, 11:25.
WarLord
Post07-10-2003, 23:26    Subject: Hidden MFA Menu: How to Access It Quote
You're welcome.
Translated on 27-08-2026, 11:27.
DocSnydor
Post08-10-2003, 8:57    Subject: Hidden MFA Menu: How to Access It Quote
Regarding point 3:
...bla...bla - Outside temperature.
By the way, the trick with the hidden MFA menus also works with the digital mileage counters in Golf 3 and similar models. In this case, you need to hold down the reset button.
Mampf
Post08-10-2003, 22:45    Subject: Hidden MFA Menu: How to Access It Quote
DocSnydor wrote:
Regarding point 3:
Do you have the tire pressure monitoring system (TPMS) and the outside temperature display in the multi-function display (MFA)?
Okay, then the fuel gauge damping is also gone (I haven't checked yet whether the temperature gauge damping is also gone).
Munch.
Translated on 27-08-2026, 11:28.
DocSnydor
Post09-10-2003, 8:41    Subject: Hidden MFA Menu: How to Access It Quote
Oh, I see... No, mine doesn't even have manual air conditioning.
Right, then the damping of the fuel gauge is also gone (I haven't checked yet whether the temperature gauge is also affected).
Mampf
I, in turn, didn't know that. Mine, however, also doesn't have a temperature dampening feature... icon_rolleyes.gif
Translated on 27-08-2026, 11:30.
WarLord
Post09-10-2003, 12:18    Subject: Hidden MFA Menu: How to Access It Quote
Is the fuel gauge reading inaccurate? By the way, does this work with the mileage counter (i.e., the combination instrument without a Multifunction Display) in the Passat as well?
Translated on 27-08-2026, 11:31.
Mampf
Post09-10-2003, 17:37    Subject: Hidden MFA Menu: How to Access It Quote
WarLord wrote:
Dimming on the fuel gauge? By the way: Does this work with the mileage counter (i.e., the combination instrument without MFA) in the Passat as well?
Greetings, WarLord
By "dampening of the fuel gauge," I meant the fact that, during normal driving, movements in the fuel volume are not visible on the gauge because it is very slow to respond. If the instrument cluster is in check mode, the fuel gauge needle moves up and down with each braking/acceleration event, or when going uphill/downhill.
As far as I know, the mileage counter check mode works on all G3&35i keypads that have an electronic odometer.
Munch.
Translated on 27-08-2026, 11:32.
DocSnydor
Post10-10-2003, 8:49    Subject: Hidden MFA Menu: How to Access It Quote
Yes, it works, I can confirm. So, press and hold the button, turn the ignition on, turn the ignition off, turn the ignition on, start the engine, and then release the button. After that, you can use the button to navigate through the menu.
By the way, this works on all VAG vehicles that have a Golf III-like instrument cluster, including the T4 (with the corresponding year of manufacture), Polo 6N, Vento, Caddy, etc.
Translated on 27-08-2026, 11:33.
No new posts Hidden Menu Diesel Engine Technology
No new posts MMI Plus: Unlock Audi A6 (4G) Hidden Menu Electrical Systems, Vehicle Electronics, Multimedia
