BPP 2.7 TDI 6 Glow Plugs Defective?
Hufe
Karma: +22 / -0   Thank you, like it!
2004 Audi A6 Avant
Post08-07-2016, 14:36    Subject: BPP 2.7 TDI 6 Glow Plugs Defective? Quote
Hello everyone,
I have been informed by VCDS that all 6 glow plugs are defective.
While I can theoretically imagine this with a mileage of 85,000 km, I still find it somewhat difficult to believe... Does anyone have any other ideas?
Installed are the Beru candles with a red sealing ring.
Car scan is in progress.
Thank you and have a wonderful, sunny weekend!
VCDS Auto-Scan Ausdruck-WAUZZZ8HX7K018335.pdf
 File name:  VCDS Auto-Scan Ausdruck-WAUZZZ8HX7K018335.pdf
 File size:  20.35 KB
 Downloaded:  1765 times
Beste Grüße,
Hufe
Post08-07-2016, 16:21    Subject: BPP 2.7 TDI 6 Glow Plugs Defective? Quote
Would first measure the resistance before disassembly. Should be between 0.7-1.1 Ohms.
Measuring and also replacing is fortunately very quick and easy with this engine.
Post08-07-2016, 16:39    Subject: BPP 2.7 TDI 6 Glow Plugs Defective? Quote
and should all 6 of them be missing at the same time? Very unlikely.
Sounds more like a loose wire or a faulty fuse.
First, clear the fault codes and see if they reappear or if the cable was simply disconnected when the ignition was on. icon_idea.gif
Best regards, Rainer
christians
Post08-07-2016, 21:39    Subject: BPP 2.7 TDI 6 Glow Plugs Defective? Quote
I think so too. Before they are identified as defective, they haven't been glowing properly for a long time. That should have been noticeable in the winter.
Gruß Christian
Hufe
2004 Audi A6 Avant
Post09-07-2016, 23:54    Subject: BPP 2.7 TDI 6 Glow Plugs Defective? Quote
Good evening,
Therefore, I cannot confirm that the exchange will be easy. They are completely blocked. Nundenn, I disconnected the cables on 2 candles for testing:
Findings:
1. Error deleted, but reappears after engine start. And specifically, for all 6 candles.
2. Diagnostic test for component 2 successful. Approximately 11% afterglow was detected. Measured in volts, the value was around 3V. (Whatever that means... I was previously assuming that there should be a battery voltage, i.e. 12V)
3. Resistance of both resistors: 500 Ohms and 560 kOhms. This means a tenfold difference. If the working candles have around 1 Ohm, then the two should already be in the trash.
Please provide the text you want me to translate. I will translate it accurately, keeping all s exactly as they are, and then I will be ready for your feedback.
Thank you!
...I just found out that the candles can only be operated with 4.4 volts.
One never learns enough...
Beste Grüße,
Hufe
Post10-07-2016, 0:25    Subject: BPP 2.7 TDI 6 Glow Plugs Defective? Quote
Hufe wrote:
Therefore, I cannot confirm that the exchange will be simple. These are completely out of the question.
For me, this is simply not feasible, but I am also familiar with the extreme cases (e.g., Mercedes-Benz B-Class, 8 hours specified, 12 hours actual, because there is a guaranteed minimum of 2 out of 4 components failing). icon_wink.gif
golf3schrauber
vwSchrauber likes this.
Post10-07-2016, 21:12    Subject: BPP 2.7 TDI 6 Glow Plugs Defective? Quote
In this car model, it's also a good idea to occasionally check the electrical box next to the battery.
This can also cause water to enter, which can then damage the control unit for the heating system. This is located at the bottom of the box.
The fuse for the light bulbs is also installed there. On my B7, a contact on the fuse was corroded.
This doesn't fit with the errors that have been discarded. The error code will then be different.
Hello, Oliver.
Gruss Oliver.
GolfIII,1Z,66KW,von94 mit 500tKm !
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
christians
dieselschrauber likes this.
Post14-07-2016, 21:22    Subject: BPP 2.7 TDI 6 Glow Plugs Defective? Quote
The light bulbs are not installed. That might look worse than it actually is.
All tools can be purchased at the hardware store, and uninvolved components do not need to be dismantled.
Whether 11% is a good value, I don't know, but definitely, the candles are operated with timing and not with a constant 12V.
Gruß Christian
vwSchrauber
Post21-07-2016, 12:30    Subject: BPP 2.7 TDI 6 Glow Plugs Defective? Quote
It's also a good idea to occasionally check the electrical box next to the battery on this car model.
I had a case with a 4F BPP where the glow device malfunctioned, and then there was a permanent 12V supply to the glow tubes, which caused them to melt.
In a (Cylinder 5), the pin has broken and fallen into the cylinder -> Engine damage icon_rolleyes.gif
Hufe
2004 Audi A6 Avant
Post22-07-2016, 22:18    Subject: Solution Quote
"Gentlemen,"
Here is the solution to the riddle:
I have replaced 4 candles. Specifically, the 4 I could achieve without adding any significant parts. (1, 2, 4, 5)
Currently, only 2 candles are still being recognized as defective. Interestingly, candle 2, which is still being reported as defective, is actually brand new. The report regarding Cylinder 6 is accurate.
Actually, it should read: Cylinders 3 and 6 still defective.
Does VCDS count the cylinders differently in any way?
Regardless, there are now 4 functioning light bulbs. This means winter can come. ...should be sufficient for starting.
2 kerzen.pdf
 File name:  2 kerzen.pdf
 File size:  11.38 KB
 Downloaded:  1148 times
Beste Grüße,
Hufe
vwSchrauber
dieselschrauber and Hufe likes this.
Post26-07-2016, 10:10    Subject: BPP 2.7 TDI 6 Glow Plugs Defective? Quote
Does VCDS count the cylinders differently somehow?
You can easily check this by disconnecting an injector (when the engine is stationary!), and then checking the fault memory to see which one is being reported there icon_wink.gif
TDI-GTI-4-Motion and Mpire likes this.
Post27-07-2016, 17:41    Subject: BPP 2.7 TDI 6 Glow Plugs Defective? Quote
Warning: During a vehicle inspection, the error memory is read out. Faulty light bulbs are recorded as entries and are relevant to emissions, which can lead to a failed inspection and also a failure of the HU (German vehicle inspection).
christians
Post30-07-2016, 21:46    Subject: Re: Solution Quote
That's not true. You can easily reach all 6 of them. Personal experience.
Even though you can't stand me anymore: I haven't read anything this stupid in a long time.
Gruß Christian
Mpire
Avatar-Mpire
2019 Skoda Octavia
Hufe likes this.
Post31-07-2016, 10:35    Subject: BPP 2.7 TDI 6 Glow Plugs Defective? Quote
@ Hufe
Ensure that all 6 are fully functional, as the afterburners are crucial for these engines, especially regarding the
Emissions levels during the warm-up phase. Both cylinders that do not misfire,
This results in more soot, which puts a greater strain on the particulate filter and also clogs the intake channels through the AGR.
icon_idea.gif Just type something into the YouTube search bar.
-> Replacing light bulbs Audi A6 / V6 TDI (VW Skoda Seat)
This video shows exactly how to change the oil in your 2.7TDI.
Cylinder 3 is not an issue, and at Cylinder 6, the throttle valve motor is located at the
Flat-head, to allow access with the key (1/4" ratchet with swivel).
You can also loosen the 3 fixing screws (T25) of the control motor even when the ignition is off.
Greetings, Mpire
Hufe
2004 Audi A6 Avant
Post12-08-2016, 21:44    Subject: BPP 2.7 TDI 6 Glow Plugs Defective? Quote
Hello Mpire,
due to your explanation, I have also replaced the two furthest back light bulbs:
Conclusion: All errors have been eliminated.
Thank you for your/your motivation!
Now the winter can come....
Beste Grüße,
Hufe
Post12-08-2016, 21:59    Subject: BPP 2.7 TDI 6 Glow Plugs Defective? Quote
No new posts P0380 Error: Glow Plug System Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0674: Glow Plug Circuit Fault, Cylinder 4 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Spark plug firing order Technical Data
No new posts Faulty Glow Plugs: Causes & Solutions Diesel Engine Technology
No new posts BLS Power Rail Glow Plugs: Repair & Replacement Diesel Engine Technology
No new posts Glow Plugs 1Z - Buy Online Now! Diesel Engine Technology
No new posts Spark plugs are oily!! Diesel Engine Technology
