Hello.
I know this might have been discussed before, but maybe someone has a tip on how to get rid of these vibrations.
My auxiliary drive belt is vibrating very strongly (amplitude of about 1.5 cm), which can also be heard inside the car. In addition, there is a fluctuation (about 2 Hz), so that the vibration gets louder and quieter.
The tensioner seems to still have good pre-tension (nothing is slipping).
What can I do about this?
I read in another forum that similar vibrations can also be caused by a loosening timing pulley. However, when I look at it from above, everything seems quiet, and only the pulley of the auxiliary belt might be wobbling slightly, perhaps by about 1mm. The engine starts perfectly, whether cold or warm. However, the multi-tooth screw is still of the old type (there's nothing marked on it).
I'm not really keen on replacing everything just based on suspicion, especially since I just installed the TDI engine (and all its components) into my Golf. Before that, I had an ABS engine in it, and the conversion wasn't something I could finish in a weekend.
Hi from Jan.
Golf III from 1994 with a 1Z engine (125,000 km).
