DPF Problem: 2.0 TDI BPW A4
TTaurus
Post13-10-2016, 19:54    Subject: DPF Problem: 2.0 TDI BPW A4 Quote
I have an A4 where the engine block was replaced due to a piston failure.
After the engine replacement, the regeneration indicator came on.
While driving on the highway, it suddenly turned off. However, after driving on a country road, it would always start up again immediately.
After that, I replaced the DPF and reset the ash value to 0.
During a stretch of highway driving, the warning light came on again.
A few kilometers further on, the indicator light started flashing, and the engine went into emergency mode. During this highway drive, I noticed that the coolant temperature repeatedly dropped. Consequently, I had the thermostat replaced.
Now, here's the problem:
Code:
                Adresse 01: Motorelektronik       Labeldatei: DRV\03G-906-016-BPW.lbl
   Steuergerät-Teilenummer: 03G 906 016 KN    HW: 03G 906 016 KN
  Bauteil und/oder Version: R4 2,0L EDC G000SG  9794
                 Codierung: 0000072
            Betriebsnummer: WSC 46493 XXX
                      VCID: 79F56EE760 XXX
1 Fehler gefunden:
008194 - Partikelfilter Bank 1
               P2002 - 000 - Fehlfunktion - Warnleuchte EIN
             Freeze Frame:
                    Fehlerstatus: 11100000
                    Fehlerpriorität: 1
                    Fehlerhäufigkeit: 1
                    Kilometerstand: 279871 km
                    Zeitangabe: 0
             Freeze Frame:
                    Drehzahl: 2184 /min
                    Geschwindigkeit: 109.0 km/h
                    (keine Einheit): 4.0
                    Tastverhältnis: 60.4 %
                    (keine Einheit): 168.30
                    Temperatur: 10.8°C
                    Zeit: 4492.8 s
Readiness: 1 1 0 0 0
It's stored in the error memory and cannot be deleted.
What can I do?
I hope someone can help me, thank you in advance.
Best regards, Oliver.
Translated on 17-10-2026, 20:57.
Post13-10-2016, 22:02    Subject: DPF Problem: 2.0 TDI BPW A4 Quote
I would like to review the following documents.
- Check the plausibility of the temperature sensor readings on the DPF.
- Differential pressure at the particulate filter when the engine is started, with the engine off.
- Differential pressure at the particulate filter when starting the engine, at idle.
- Compare the differential pressure at the particulate filter with the following topic:
Translated on 17-10-2026, 20:59.
Steffen W
Karma: +104 / -0   Thank you, like it!
dieselschrauber likes this.
Post14-10-2016, 4:30    Subject: DPF Problem: 2.0 TDI BPW A4 Quote
Is it regenerating now with the new thermostat?
Try going on a regenerative ride.
In August, while I was on my way to work during the regeneration cycle, the lamp turned on. It had interrupted the regeneration because the water temperature was too low.
The cause was a broken plastic tab on the thermostat flange, which is the mounting bracket for the thermostat. This tab had become lodged in the open thermostat.
The thermostat was stuck open, and the engine was not reaching its operating temperature. Consequently, no regeneration cycles were occurring. I then performed a regeneration cycle in August, using the auxiliary heater.
That worked. And then I replaced the thermostats.
Passat Variant BGW 2005
Translated on 17-10-2026, 21:00.
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission Problems: Audi A4 01N AFN General Tips
No new posts Fixed Issue, New Problem Arises Diesel Engine Technology
No new posts WFS Issues: Troubleshooting and Solutions On-Board Diagnostics (OBD)
No new posts Graphics Card Issues: Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts VTG Issue: Troubleshooting and Solutions Diesel Engine Technology
