Audi Q5: MMI Map Update Causes EEPROM Error
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
GTD22
Post14-10-2016, 13:06    Subject: Audi Q5: MMI Map Update Causes EEPROM Error Quote
Errors after map update in the MMI and hidden menu.
Friday, October 14, 2016, 1:30:22:60845
VCDS version: RKS 16.8.1 running on Windows 10 x64.
Address 5F: Information Selection. Label file: DRV\4E0-035-6xx-5F.clb
Control unit part number: 8T1 035 666 M. Hardware: 8T1 035 666 E.
Component and/or version: H-BN-EU H52 0187
Encoding: 010100060305E1EF05000F1E000000030001
Company number: WSC 06335 123 12345
VCID: 4480EEB6C7767262CA-8010
2 error codes found:
16367 - Control unit - Error in flash ROM.
014 - defective - intermittent.
Environmental conditions:
Error status: 00101110
Help...
Error priority: 5.
Error frequency: 2.
Lost Count: 255
Mileage: 31,331 km
Time: 0.
Date: 2016.10.13
Time: 19:55:52
Voltage: 12.20 V
Power-on time: 1958 hours.
01043 - Control unit: Incorrect software version.
000 - - - Sporadically
Error status: 00100000
Error priority: 5.
Error frequency: 1.
Lost Count: 219
Mileage: 31,381 km
Time: 0.
Date: 2016.10.14
Time: 13:26:17
Binary value: 00000000 00000000
Binary value: 00000000 00100000
 File size:  38.82 KB
 Viewed:  4341 times
Translated on 01-09-2026, 7:33.
Post18-10-2016, 17:02    Subject: Audi Q5: MMI Map Update Causes EEPROM Error Quote
If flashing the original firmware doesn't help or is no longer possible, the options for non-expert users in electronics are likely to be exhausted.
If it were my navigation system, I would try to identify the flash memory and obtain a data set from an identical donor device with the correct software version.
Translated on 01-09-2026, 7:37.
Karma: +1349 / -0   Thank you, like it!
Post19-10-2016, 19:50    Subject: Audi Q5: MMI Map Update Causes EEPROM Error Quote
was genau wurde denn gemacht ? Kartenupdate oder auch Update der MMI/Navi Software? Or...
It's possible that a software update is required along with the map update.
Please provide more specific information about the vehicle and the MMI system (year of manufacture, MMI 3G or 3G plus, and the year of the old maps).
If not already done: Reset the MMI (Multi Media Interface), and try using a CD with the older navigation software.
And don't play around too much in the "Hidden Menu" = development test mode. icon_wink.gif
Translated on 01-09-2026, 7:38.
GTD22
Post22-10-2016, 20:59    Subject: Machine Learning: A Beginner's Guide Quote
Okay, yes, I have installed the latest firmware.
8R0906961DQ K0257 new map, then unlocked.
The car is an Audi Q5, model year 2011, with the mmi3G infotainment system.
It's not possible to reinstall it because there are no newer updates available, unless I do a custom installation, but I'm not sure what options I should select.
Does anyone have a suggestion?
Translated on 01-09-2026, 7:40.
Post23-10-2016, 19:05    Subject: Audi Q5: MMI Map Update Causes EEPROM Error Quote
Hi (we always greet at the beginning and the end),
Perhaps you skipped a software version during the installation of the latest version, and the MMI doesn't handle that well (at least not initially).
Therefore, the questions are: What was included? Is there a software history? Where did the new version come from? Does it even work? And what instructions were followed?
Here is a link to read: http://www.a5oc.com/forums/attachment.php?attachmentid=112842&d=1456063238
Translated on 01-09-2026, 7:41.
GTD22
Post24-10-2016, 19:58    Subject: Audi Q5: MMI Map Update Causes EEPROM Error Quote
That was on it.
 c
 File size:  1.62 MB
 Viewed:  1125 times
Translated on 01-09-2026, 7:42.
GTD22
Post24-10-2016, 19:59    Subject: Audi Q5: MMI Map Update Causes EEPROM Error Quote
That's on it now.
My friend downloaded the software from the internet.
 File size:  2.04 MB
 Viewed:  1391 times
GTD22
Post24-10-2016, 20:00    Subject: Audi Q5: MMI Map Update Causes EEPROM Error Quote
Thank you in advance, Herbert, for your help!
Translated on 01-09-2026, 7:43.
Post24-10-2016, 21:23    Subject: Audi Q5: MMI Map Update Causes EEPROM Error Quote
There is someone on the line icon_rolleyes.gif.
- Good morning!
- Maybe 0253?
GTD22
Post25-10-2016, 18:56    Subject: Audi Q5: MMI Map Update Causes EEPROM Error Quote
Okay, I think I had a mistake somewhere. This is the last photo I took, and yes, they are right. I think I updated directly from 0253, and I probably skipped a version, just like they claim.
What does that exactly mean now... is the MMI screwed up?
 File size:  1.59 MB
 Viewed:  1494 times
Translated on 01-09-2026, 7:44.
Post29-10-2016, 12:18    Subject: Audi Q5: MMI Map Update Causes EEPROM Error Quote
I would first try to restore the original software version.
If that doesn't work, your supplier might have an idea of what to do in case of an error. Such an error could also occur during an update at the Audi service center.
By the way, if your map data is demonstrably legal, and you just wanted to do the update yourself, they might be willing to help you for money and good words if necessary. However, if your map data is a pirated copy, that's a different story.
Translated on 01-09-2026, 7:45.
GTD22
Post29-10-2016, 17:59    Subject: Audi Q5: MMI Map Update Causes EEPROM Error Quote
Okay, but that's not possible because I have the latest version installed, and I can't install the older version. When I try to select "Update," it doesn't work; I can only choose "Custom," but I don't know where to find the files or what to do.
Translated on 01-09-2026, 7:46.
No new posts Audi Fan Error: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 documentation, fault in the secondary air system Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4: Airbag System Error - Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A6, Error after trailer hitch retrofit On-Board Diagnostics (OBD)
No new posts EPROM Steuergerät 038906019FF Diesel Engine Technology
No new posts TDI Passat: Original EEPROM Chip for Sale Diesel Engine Technology
No new posts EPROM Programmer: Reprogramming Engine Data on eBay Diesel Engine Technology
